Calculation actual efficiency problem
The discussion revolves around calculating the actual and maximum theoretical efficiencies of a heat engine that takes in 1030 J of energy at 1000 K and exhausts 585 J at 250 K. The maximum efficiency, derived from the Carnot efficiency formula, is calculated to be 75%. The actual efficiency is determined by the useful work output, which is 445 J, leading to an efficiency of approximately 43%. Participants confirm the calculations and clarify the formulas used for both efficiencies. The thread concludes with a clear understanding of how to derive both efficiency values.
astru025
A heat engine takes in 1030 J of energy at 1000 K and exhausts 585 J at 250 K. What are the actual and maximum theoretical efficiencies of this heat engine?
For maximum efficiency I got 75 % by taking 1 - (250K / 1000K). For actual efficiency the equation is W/ Q or work out / heat in.
I am not sure where to start on this problem and any help would be very nice!
The max efficiency is the Carnot efficiency which you seem to have right (I think).
As for the actual efficiency...
Correct.
If 1030 J goes into the engine and 585J comes out of the exhaust how much is used elsewhere by the engine, presumably doing useful work?
445 j?
astru025 said:
445 j?
Yes.
So if 1030J goes in and only 445J comes out in the form of useful work the efficiency is ?
445 J / 1030 J = 43 % thanks very much!
  • · Replies 32 ·
  • · Replies 20 ·
