Calculus Help: Differentials (Rates)
The discussion centers on estimating the volume of paint required for a hemispherical dome with a radius of 48 feet and a paint thickness of 0.07 inches using differentials. The initial calculation yielded approximately 168.89 gallons, which was incorrect. The correct approach involves recognizing the need to calculate the volume of the outer hemisphere and the inner hemisphere to find the volume of paint needed, leading to a correct estimate of approximately 1,263 gallons. The key error was in misapplying the formula for the volume of a sphere instead of a hemisphere.
  • Understanding of differential calculus
  • Familiarity with volume formulas for spheres and hemispheres
  • Knowledge of unit conversions (inches to feet)
  • Ability to apply the chain rule in calculus
  • Review the volume formula for hemispheres: V = (2/3)πr^3
  • Learn how to apply differentials in volume calculations
  • Practice unit conversion techniques, especially between inches and feet
  • Explore the implications of coordinate systems in calculus problems
Students studying calculus, particularly those focusing on differentials and volume calculations, as well as educators seeking to clarify concepts related to hemispherical volumes and paint estimation.
buffgilville
A hemispherical dome with radius 48 feet will be given a coat of paint 0.07 inches thick. Use differentials to estimate the number of gallons of paint that will be needed to paint the dome.
Here's what I did:
f(x+h) = f '(x)h + f(x) and v=4/3pi*r^3; r=48ft.
volume of the dome:
V=4/3pi*r^3 = f(r)
I set (r+h) to be the radius of the paint volume
so, V=4/3pi*(r+h)^3 = f(r+h)
then, f(r+h) = f '(r)h + f(r)
The question just want the volume of paint needed, so I subtracted f(r)
f(r+h)=f '(r)h + f(r) - f(r), simplify
then, f(r+h)=f'(r)h
derivative, V(paint) = 4/3pi*r^3, then dv/dr(paint)=4pi*r^2
given: r=48 feet, h=0.07inches = 0.0058333feet
f(r+h)=f'(r)h => f(r+h) = 4pi*(48)^2*0.0058333
I got approximately 168.891056 gallons, but the correct answer is 631.7000268 gallons.
What did I go wrong?
Have you checked all of your work? (even the problem and your starting points)
Oh, and BTW,
then, f(r+h)=f'(r)h
You know full well what you have written is wrong: the left hand side of this last equation should not be f(r+h).
I just realized the question asks for a hemispherical dome, not a sphere. Can someone please help me with this question? Thanks
Doesn't this realization suggest a change to your attempt at solving it?
I keep getting the wrong answer. :confused:
Have you checked your arithmetic and conversions as well? For instance, I entered this into google:
4 * pi * (48 feet)^2 * (0.07 inches) in gallons
and the result was 1,263 US gallons, not then 168 you got.
Find the volume of the outer sphere and the inner sphere. What is the volume between the spheres? How can differentials be used to get a volume? Also, the choice of a good (bad) coordinate system will make the problem much easier (harder).
/s
  • · Replies 16 ·
  • · Replies 63 ·
  • · Replies 20 ·
