Calculus III: Sketching Solids with Spherical Coordinates
The discussion focuses on sketching a solid defined by spherical coordinates (ρ, θ, φ) with specific ranges for each variable. The solid is described as resembling a bowl with a maximum radius of ρ = √3. The range of ρ is dependent on φ, starting from 0 to 2 when φ = 0 and decreasing to 0 to 2cosφ as φ approaches π/6. The participants emphasize that as φ increases, the values of ρ decrease gradually, affecting the overall shape of the solid. Finally, to complete the volume, θ should be varied within its specified range.
acid_rain
I really have difficulty with spherical coordinates graphings. can someone help me with this problem?
Sketch the solid consisting of all points with spherical coordinates (ρ,θ,φ) such that 0≤ θ ≤π/2, 0≤ φ ≤π/6, and 0≤ ρ ≤2cosφ
thanks so much!
i think this looks like a bowl with radius ρ= root 3,
then I don't understand how to graph theta and phi according to that range. that's where i got stuck.
The "range" of ρ is dependent upon the value of φ. So if you start at φ=0. At this point, all the ρ btw 0 and 2 are permitted. But as φ progresses towards π/6, ρ can ony take value btw 0 and 2cosφ. And at φ=π/6, it can only take values btw 0 and \sqrt{3}. In btw, the range of rho decrease as cosφ decreases btw 0 and π/6, i.e. very slowly at the beginning (the crest of the cos) and then steadily until π/6.
Now that you've got the range of ρ and φ covered, just complete the volume by making θ vary.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
