Can a flow created by a fan show an Edge effect when hitting a wall?
  • Thread starter Thread starter T C
The discussion centers on whether airflow created by a fan exhibits an "edge effect" when it encounters a wall, specifically in the context of a fan positioned in front of a flat plate. Participants explore the implications of airflow dynamics, including velocity changes and flow patterns, in both natural and controlled environments.
  • Some participants assert that airflow hitting walls can increase velocity, referencing the concept of edge effect as seen in natural wind flows.
  • Others challenge the definition of edge effect, questioning its relevance in the context of a fan and flat plate setup.
  • One participant emphasizes the importance of the size of the wall relative to the airflow, suggesting that it affects the radial velocity of the air.
  • Another participant discusses the geometry of the fan and plate, proposing that the area of the annular exit will lead to lower velocity compared to the fan outlet.
  • There is a suggestion that airflow may not wrap around the edge of the plate immediately but will spread radially, raising questions about whether this spreading could lead to an increase in velocity.
  • Some participants express skepticism about the term "edge effect," seeking sources to validate its use in fluid dynamics.
  • References to videos are made, with participants debating whether they demonstrate the edge effect and requesting timestamps for specific terminology.
  • One participant clarifies that the flow dynamics described do not align with the traditional understanding of edge effect, suggesting a distinction between flow hitting a flat plate and flow around a properly shaped object.
Participants do not reach a consensus on the existence or applicability of edge effect in the described scenario. Multiple competing views remain regarding the behavior of airflow in relation to the fan and flat plate setup.
There are unresolved questions about the definitions and implications of edge effect, as well as the specific conditions under which airflow dynamics change. The discussion includes varying assumptions about the geometry and setup of the fan and plate.
  • #31
renormalize said:
I am curious to see the velocity and pressure distribution part of this scenario. And, by the way, what's the source of this photo/drawing?
  • #33
Can't see it as I don't have an account. Whatsoever, I am curious about the velocity distribution and pressure distribution diagram of the second photo.
  • #34
Did you search the title in Google Scholar for a free PDF as I suggested? What did you find?
  • #35
russ_watters said:
Ok, I see it, and see that you capitalized "Edge" but not "effect" because that's how it is shown in the video subtitles. Near as I can tell, it's typically called "corner effect" and is about what happens whe a fluid flows around a sharp corner (it accelerates):
Is this your understanding if flow around a house, building, mostly low rise?
The reference given in the post 17 shows that flow around buildings, especially high rise downtown areas, can have complicated air movement patterns.
The upwind velocity U profile need not be that as shown in the figure below, especially if other buildings, or obstacles are in the vicinity. The U shown for the free stream is modelled as either an exponential or as a power function. At ground level, the U velocity is zero, producing the swirl under the stagnation zone. The dead zone is evident on the lee side of the building. ( Note the similarity to an idling car and carbon monoxide poisoning, where the noxious gas can enter the passenger compartment even if the exhaust is exiting at the rear ). ( And snowbank overhang extensions ).
Since the streamlines compress over the building ( and sides as well ), a velocity increase does occur.
It would seem the greatest velocity amplification occurs not at the actual edge but is a function of height and distance from the edge, surpassing Uroof_height, and possibly surpassing Uz under particular conditions.
https://www.aivc.org/resource/air-flow-around-buildings
Chapter 14 of Fundamentals 1981 ASHRAE , a copy of which these nice people have provided.
( Can't find my copy of Fundamentals, same year, ( dagnabit )
  • #36
If that's true, then from where the extra energy can come?
  • #37
Bernoulli
  • #38
That means the fall in temperature following the fall the pressure and the energy released in this way is being converted into kinetic energy, right?
  • #39
No.
Bernoulli says nothing about a change in temperature.
https://efficientengineer.com/bernoulli/
  • #40
It does seem clear from the diagrams @renormalize put in post #27, that the leading corners squeeze the streamlines together. That indicates an increased velocity.
  • #41
Condensation above aircraft wings are a very common phenomenon for a long time i.e. from subsonic to supersonic. Condensation occurs means there is fall in temperature otherwise it's simply not possible.​
  • #42
That is a consequence in certain situations of Bernoulli's equation. It is not Bernoulli's equation.
  • #43
Whatsoever, it's a proof that temperature fall occurs due to the increase in velocity. I am just curious to know that happened to the energy that has been released due to this phenomenon.
  • #44
256bits said:
Bernoulli
This answer may be too short/flippant for @T C to have grasped. To expand: Bernoulli's principal/equation is a conservation of energy statement: there is no extra energy. To put a finer point on it, any obstruction will result in a net loss of energy in the flow.
The question here is whether a localized velocity increase can be exploited to provide greater power from a given wind turbine vs the same turbine in freestream. The answer is probably but it is complicated and very situation-specific.
  • #45
Please look at the standard form of Bernoulli's equation @FactChecker provided and tell us what you see the answer is. You've been looking at related issues to this for years and this question is answered in the first hour of a lecture or chapter on Bernoulli's Principle. It's inexcusable for you to not grasp this by now.
  • #46
The energy "released" by the temperature-fall is exactly balanced by the energy required to increase the flow-velocity. Bernoulli's equation for a compressible fluid (like air) can be written ##v^2/2+C_pT=\text{constant}##, where ##C_p## is the specific heat of the fluid. So simple conservation of energy for compressible flow implies higher-velocity ##v## = lower-temperature ##T##.
  • #47
The Bernouilli equation that one mostly sees, and the one that is presented as an introduction to fluid flow, is of the form in post 42 by @FactChecker. Below about Mach 3, this form can solve the velocities and pressures from one point to another along a streamline quite adequately for a great deal of phenomena.
This form has several assumptions that need explaining
- flow is streamlined
- steady flow in time
- no change in density along a streamline
- viscous effects neglected, ie fluid is considered inviscid, and thus no internal friction
- volume work is considered to be zero, so no work done on or by the fluid
- no change in temperature, so no change in internal energy of the fluid
A general energy equation of the form from the first law of thermodynamics.
Q + W = ΔU + ΔPE + ΔKE + ΔPV
Since Q = 0, W = 0, ΔU = 0, we are left a constant energy from point 1 to 2 along a streamline in terms of the changes in only KE, PE, and PV of the fluid.
  • #48
Good point. I think that is the unexpressed question of the OP. The diagrams that @renormalize included in post #27 seems to indicate that the velocity can be higher than the freestream velocity. The streamlines appear closer together at the leading corners of the obstruction than they were in the freestream.
  • #49
I don't think that's the right interpretation. The flow-speed plots in fig. 6 of my post #26 show lower speeds (blue) everywhere around the building compared to the higher incoming freestream speed (yellow/green). But what you can say is this: if you have a turbine of finite aperture-width ##w##, placing it at the corners is better because it will capture a higher average flow speed (since the streamlines are more closely spaced there), compared to putting it nearer the stagnation point on the front wall. But in neither location will those average speeds be as high as the freestream speed. Obstacles always diminish nearby flow speeds to below that of the unperturbed freestream.
  • #50
Sorry. I stand corrected. I was thinking about incompressible fluid flow. Thanks.
  • #51
In short, a part of enthalpy has been converted into this extra velocity. There is no other explanation.
  • #52
Those colors don't make any sense to me, given the streamline compression. & @256bits here's what AHRAE Fundamentals says (I'm trying to access the digital version or I'll scan my book):
"Flow accelerates as the streamlines compress over the roof and decelerates as they spread downward over the wake on the downwind side of the building."
"For an isolated high-rise building...high wind speed at pedestrian level can be caused by.... the corner streams."
I interpret both of these to be saying higher than freestream.
Note, Post #27 is showing flow around the sides of a long cylinder, not over the top of a building low to the ground (more like the second scenario than the first in the ASHRAE quotes. Note also, as you make your "cylinder" more aerodynamic it will start looking like a wing, where you certainly do get flow speeds above freestream.
The wikipedia article, for what it's worth, has images of flow around a cylinder showing velocity vectors with magnitude based on arrow size:
  • #53
I am unsure of your point. Have there been "other explanations" proposed to explain velocity increase?
  • #54
I don't think this is very useful for low flow velocity situations, where the temperature and density changes are negligible and therefore ignored (incompressible), and that form of the equation doesn't describe the interplay between velocity(pressure) and static pressure. I think it's a Prego thing; "It's in there", but doesn't show it.
Plugging in a reasonable wind change of 10 m/s yields a temperature change from standard of 0.05 K.
  • #55
I'd like for @T C to answer the question based on the incompressible flow form of Bernoulli's equation provided in Post #42.
  • #56
Plain and simple explanation, the compression-expansion and related fall in temperature is small in comparison to the overall temperature and therefore it can be neglected and we can consider it to be "practically" incompressible. The condensation over aircraft wings is a reality and can't be overlooked.
  • #57
So then what does the equation say is going on?
It can be overlooked if it's irrelevant to the topic we were discussing.
  • #58
The equation simply says that as the velocity increases, the pressure decreases. And the decrease in pressure is proportional to the square of the increase in velocity (the gz part can be neglected).
  • #59
Yes. So that is where the velocity can come from -- decreased pressure. This just means that the random directional movement of atoms causing pressure can be somewhat redirected to the forward direction of motion, causing an increase of airflow velocity and a decrease in pressure.
  • #60
Decreased pressure means fall in temperature and that means energy is released. That energy is being converted into the kinetic energy.
11K
9K
  • · Replies 77 ·
23K
