Can a harmonic be louder than the fundamental frequency?
The discussion centers on the phenomenon where harmonics can appear louder than the fundamental frequency in acoustic instruments, specifically using a steel string acoustic guitar. The recorded first harmonic at 131 Hz peaked at -34.5 dB, while the second harmonic at 263 Hz peaked at -12.4 dB, suggesting that the string's plucking position significantly influences harmonic intensity. Techniques such as muting strings at specific intervals (L/2, L/3, etc.) can isolate harmonics and demonstrate their relative loudness compared to the fundamental. This variability in harmonic dominance is dependent on playing technique and instrument characteristics.
  • Understanding of harmonic frequencies and their relationship to fundamental tones.
  • Familiarity with acoustic guitar construction and sound production.
  • Basic knowledge of sound recording techniques using Audacity.
  • Experience with string instruments and playing techniques, particularly plucking methods.
  • Research the physics of sound waves and harmonics in string instruments.
  • Learn advanced techniques for muting and plucking strings to manipulate harmonic output.
  • Explore the acoustic properties of different string instruments, such as the bugle.
  • Investigate the role of the human ear in perceiving sound intensity and frequency response.
Musicians, particularly guitarists and string instrument players, sound engineers, and anyone interested in the acoustics of musical instruments and sound perception.
Jon.G
This is not a homework question per se, but rather something I have come across during a homework project. Using Audacity, I recorded a few different instruments playing the same notes (investigating timbre). I noticed that (using a steel string acoustic guitar) the first harmonic at 131 Hz (~C3) peaked at a decibel value of -34.5, whereas the second harmonic at 263 Hz peaked at -12.4 dB. I didn't see this happen for other instruments.
I was under the impression that the fundamental frequency would always be the most dominant component. Will it just be the string/body resonance that causes this? If so, could you try and help me understand it a bit better. and if not please help me understand why this occurs :)
My estimate is that it's more a matter of where the string is plucked: in the middle the fundamental frequency is favoured, more near the ends higher harmonics get a chance. Extreme case: pluck very close to the bridge and you'll get a high frequency.
You're right, I didn't think of that :) I read this and quickly recorded the same note a few times but plucking at different points and it definitely has a noticeable effect on the relative intensities of the spectrum.
If I remember correctly, plucking at L/n should remove every nth harmonic (in an ideal environment, I'm sure this won't happen perfectly in practice for me :P )
In nature, the higher harmonics certainly can be "louder" than the fundamental, and often are, depending on the instrument, and how the instrument is played. There is no rule which says the fundamental must be dominant.
As an experiment, you can isolate the higher harmonics by using this method: Pluck the strings as normal with one hand, but use your other hand to "mute" the strings at certain intervals such as L/2, L/3, L/4, L/5 or whatnot. You'll see what I mean. [Edit: to do this, very gently place your finger atop the string such that your finger barely touches it. Don't squeeze the string; that's not what I mean. Just hold your finger to the string in the right place, so that it barely touches. Immediately after plucking the string, remove your "muting" finger, and let the harmonic ring.]
This technique is often used in music . As an example it is used, in part, in the introduction to this song (Band: Yes, song: Roundabout)
Furthermore, there are instruments that rely completely on harmonics to differentiate pitch. One such instrument is the bugle. The bugle has no keys, no finger-holes, nothing to induce a particular note, besides the way the player blows into the thing. All tunes played on the bugle are simply formed from harmonics.
Using the method I described earlier of plucking a single string with one hand and muting the string with your other hand at L/2, L/3, L/4, L/5 and such, you should be able to play this tune on a single string, without even "fretting" the string:
By the way, this method of using harmonics is also a good way to tune up your guitar, at least to itself, to standard tuning, if you don't have an electronic tuner around.
Get a harmonic going by plucking and lightly touching (and immediately releasing) the first string, seventh fret (the 7th fret is L/3) and again with the second string at the fifth fret (the fifth fret is L/4). These should produce the same note. Listen for beats and adjust the tuning knob accordingly.
You can use this process all the way up the neck, to get all six strings in tune with each other, with the exception of the second and third string, where you will have to fret something.
This method is nice, because it once the harmonics are produced, it frees up both hands to adjust tuning knobs, except for that one string (when comparing the second and third string).
(Of course as mentioned, this method only works verbatim for standard guitar tuning.)
[Edit: and conceivably you could get around this limitation with the second and third string using the following technique. Get the first string and sixth string in tune by muting the sixth string at the 12th fret (L/2) and compare that to the first string, plucked, but not muted, near the twelfth fret. That should produce the same note (an E). Then tune up the second string using the previously method. Then, go backwards tuning up the 5th string, comparing it to the 6th string, using harmonics. Repeat for the 4th string comparing harmonics to the 5th string, and again to tune up the 3rd string.]
Wow, thanks a lot!
Some very interesting points there. I knew about "muting" the strings at the different intervals but never really make the connection :P
In an acoustic or classical guitar, can the harmonics sound "louder" than the fundamental? In other words, which produces the more, or most energy? Thx
Welcome to PF.
Wasn't this question already answered in this old thread? Your question is pretty much the same as the question in the Original Post (OP), no?
Those are two different questions. What sounds louder depends partly on the acoustic response of the human ear. Consider a fundamental below the audible range.
I'm lead to believe that if the acoustic/classical guitar is strung and played normally, most of the energy of a given string comes from the fundamental. Normally. Most of the time, anyway.
As mentioned previously though, it can depend on how you play it. I'll update my example link below (Yes, Roundabout).
If you want to get as much fundamental as possible out of an acoustic or classical guitar open string, take the index finger of your fretting hand and place it right on the nut (near the guitar head), barely touching the very end of the strings on the neck. Then strum the strings using the thumb of your picking/strumming hand right on the 12th fret. Don't use your thumbnail, just the skin of your thumb. That should get you as close as possible to the fundamentals of the open strings.
Now strum the guitar normally and compare.
This is true for an arbitrary instrument. Of course for a acoustic/classical guitar in standard tuning, you're not going to get much below 82.41 Hz. Even if you tune the strings flat, the instrument isn't capable of amplifying* the sound at such low frequencies.
*(by "amplifying" here I mean converting the string energy into sound energy.)
Now if you had a really big, monster double-bass acoustic guitar with the strings tuned flat, than maybe you could get down closer to 20 Hz. ...
Anyway, my previous link to Yes' Roundabout link seems to be dead now. Here's an updated link. Since it's music, you'll still have to watch it on YouTube (licensing reasons, probably), but at least the link should get you there.
As a reminder, this is an example of isolating some of the harmonics, not the fundamentals.
18K
  • · Replies 37 ·
