Can a hose spray higher than the water tower?
The discussion revolves around the mechanics of water pressure and the capabilities of water towers and pumps, particularly in the context of whether water can be sprayed higher than the height of a water tower. Participants explore various theories related to water supply in tall buildings and the principles of fluid dynamics, including the use of ram pumps and the conservation of energy.
  • Some participants argue that the diameter of the pipe alone cannot allow water to be sprayed higher than the water level in the tank due to conservation of energy principles.
  • Others suggest that a ram pump could achieve this by using a mechanism that allows a portion of the water to be projected higher than the source, contingent on the flow and pressure pulses.
  • It is noted that for a steady flow without mechanisms, the height of the fountain is limited to below the height of the water tower.
  • Some participants emphasize the importance of splitting the flow to allow part of it to do work on the part going back up, which is crucial for adhering to conservation of energy.
  • A comparison is made to a simple experiment involving water drops and splashes, illustrating how energy transfer can result in higher projections.
Participants express differing views on the mechanics of water flow and pressure, particularly regarding the role of ram pumps and the implications of conservation of energy. There is no consensus on whether water can be sprayed higher than the water tower without additional mechanisms.
Participants discuss various assumptions about fluid dynamics and the conditions under which water can be projected higher than its source, highlighting the complexity of the topic without resolving all mathematical or physical claims.
This discussion may be of interest to those studying fluid dynamics, engineering principles related to water supply systems, and the mechanics of pumps and pressure systems in tall buildings.
ChemEngrMom
TL;DR
Can a water hose theoretically spray higher than the water tower that supplies it? In other words, is it possible for the water pressure created by a water tower to push water higher than the tower itself if a small enough diameter pipe were used to constrict the flow enough to push the water up?
As our family drove along the highway, one of my 3 college boys started commenting about the water towers we were seeing. We started a deep discussion about how water towers work and that led to a fascinating discussion about water supply in skyscrapers that are clearly taller than your average water tower. We are aware of the many wooden water towers on the roofs of buildings across the New York City skyline, but we wondered, does the Empire State Building have a water tower on top of it? Do really tall buildings use the same kind of water tower?
That led to all sorts of theories floating around about how tall buildings and big cities deal with water pressure needs.
A friendly argument developed about whether it's possible for the water pressure created by a water tower to push water higher than the tower itself if a small enough diameter pipe were used to constrict the flow enough to push the water up.
Can you settle this for us?
The diameter of the pipe itself would not do it.
First, let's look at the "central problem" here. If the entire water stream was capable of going higher than the water level in the tank, it could be directed at the tank with energy left over. You would be getting energy for free. And since that violates conservation of energy, it can't happen.
But what if only a portion of the water went that high?
Doesn't matter. You'd still be getting free energy (just put a little water wheel above the water tower) so it would still be a PMM
I believe a ram pump will accomplish this. I am looking for a link now...
... Looks like this one is good: Ram Pump explained - video
Yes, a ram pump will do it. There is no free energy. For a ram pump to get water up above the source requires more water to go down than goes up. The center of mass of all the water still goes down.
For a steady flow without any mechanism the height of the fountain is limited to be less than the height of the water tower.
When flow and pressure pulses are employed, such as in a ram pump, some of the water can be projected higher than the water tower.
There are also hydraulic flow dividers, also called intensifiers, that can operate continuously like a hydraulic motor driving a pump to increase the pressure of part of the fluid only.
Welcome!
Pumps at the basement of very tall buildings give water the energy it needs to reach the penthouse.
Please, see:
https://www.cibsejournal.com/cpd/modules/2019-10-wat/
Here is an explanation of a ram pump. There is an explanation about the physics at 2:40, the installation starts at about 11:00, and the rest is agricultural stuff that I enjoy.
Wow. I'm blown away. As a chemical engineer by training my gut was saying conservation of energy, but my sons kept entertaining ideas of the constriction and flow and that was showing some insight that I couldn't put my finger on. The ram pump and your explanation about flow and pressure pulses brought it all into focus! Thank you, you very intelligent people!
The rest of the water also leaves the tower, but doesn't go up.
Simple experiment: If you drop water from a cup into a filled bathtub, the splash can go higher than the drop.
It is important to note that simply constricting the entire flow cannot work. You must split the flow and have the part of the flow going down do work on the part going back up. That is key to using the conservation of energy. If you don’t split, but merely constrict, then your gut was right.
A related trick is to put a small ball in contact with the top of a basketball and drop them together. The basket ball doesn't bounce very high, but does give some of its energy to the small ball which will easily bounce above the initial drop height (wear goggles!).
Demo:
Reminds me of back in the day when I had my first real job. I'd just graduated with lots of book learning about switching power supplies. But as a city kid, I'd never heard of a ram pump. An older engineering mentor was explaining them to me, when I suddenly got it and exclaimed "Oh, you mean, it's just like a boost converter!"
  • · Replies 39 ·
17K
9K
