Can a Mason Jar Maintain a Vacuum for Powder Paint Storage?
  • Thread starter Thread starter stryped
    Storage Vacuum
The discussion revolves around the feasibility of using a mason jar to maintain a vacuum for the storage of powder paint, specifically focusing on methods to prolong the usability of the paint by minimizing moisture exposure. Participants explore various techniques, including vacuum sealing, inert gas injection, and the use of desiccants.
  • Experimental/applied
  • One participant suggests using a mason jar with a rubber tire valve and a vacuum pump to create a vacuum for moisture removal.
  • Another participant warns that zip-lock bags may burst under vacuum pressure and questions the mounting of the tire valve.
  • Some propose "canning" the paint using a vacuum chamber, suggesting that this method could effectively seal the jars without needing a valve.
  • There are suggestions to use desiccants, such as uncooked rice or silica gel, to absorb moisture in the jar.
  • One participant introduces the idea of replacing air with a heavier-than-air gas, like argon, as an alternative to vacuum sealing.
  • Concerns are raised about the humidity levels in certain regions, which may affect the storage of powder paint.
  • Participants discuss the potential of injecting inert gases like nitrogen into the jars instead of mechanically evacuating air.
  • Some express uncertainty about the effects of different gases on the powder paint.
  • There are mentions of commercial products designed for preserving paint, which utilize gas injection methods.
  • One participant suggests using vacuum storage bags for clothes as an alternative method to reduce air exposure.
Participants do not reach a consensus on the best method for storing powder paint, with multiple competing views and techniques presented throughout the discussion.
Participants express varying opinions on the effectiveness of different storage methods, and there are unresolved questions regarding the impact of humidity and the specific conditions required for optimal storage.
stryped
I am wanting to start powder coating small items on my projects I am always working on around the house. To keep the small quantities of powder paint useable for as long as possible, I had thought about storing the paint in zip lock bags inside of a mason jar. I would install a rubber tire valve on the lid of the mason jar and use my harbor freight ac vacuum pump to create a vacuum to remove the moisture from the jar, which I hope will make the paint last longer.
Do you think this will work? Would the mason jar hold a vacuum for an extended period of time?
If not, is there another type of inexpensive container that would?
Any help is appreciated!
That should work if you grease the rubber sealing ring.
The zip-lock bags may burst and spill powder when the vacuum is created.
How will you mount the tire valve, backwards in the lid, and still make a vacuum connection?
Why not "can" the paint in the jars using the lids as the valve as one does making jelly. You would need to build a small vacuum chamber that could hold at least one jar (perhaps a dedicated slightly larger canning jar or a bell jar?). Lightly tighten the lid, put into chamber, evacuate chamber and release vacuum slowly. Jelly seal lasts for years. No valve required
Why do you need to think beyond what the manufacturers provide?
If moisture is the primary concern, you could also put a desiccant in the jar. A simple one is uncooked rice grains. That's how I store salt in humid environments in a small boat at sea. Fill the salt shaker half with rice and half with salt. Shaking before use breaks up clumps. And the sieve action of the shaker top filters out rice grains and remaining clumps.
Instead of pumping a vacuum you can just replace the air with a heavier than air gas, say argon. This should be much easier and just as efficient.
There are commercial products made specifically for preserving paint using this method. In the US there is e.g. a company called Bloxygen that sells products of this type (I've never used it myself since I live in the UK, but I've seen it used on many of the woodworking Youtube channels that I watch)
I am just trying to make the paint last longer in my garage
Would this “boil” off the moisture similar to pulling a vacuum for ac work?
Do you wish to "pull" moisture from the powder or minimize future ingress? If you pull 75% of the air from a container you remove 75% of the water vapor too. Seems equivalent to your original technique......
This source says that you can store for several years with 50-60% humidity.
https://tcipowder.com/media/2605/powder-coating-storage-requirements-3-17-21-1.pdf
Powder Coating Storage Requirements
These comments apply to uncured powder coatings as sold. Product storage life depends upon the storage conditions. When stored properly, the storage life should be more than six months from receipt. Experience has shown that many products can remain useful for periods of up to several years. Proper storage requirements include:
• Keeping product at temperatures less than 80 degrees F (26.7 degrees C) with the relative humidity in the 50-60% range
• Store product in a cool, dry, well ventilated area away from heat, ignition sources, and direct sunlight • Keep containers tightly closed
• Protect from physical damage
• Do not expose product to damp or wet conditions
• Avoid contaminating product during storage and use
Following these guidelines will optimize product storage life and application performance. Generally, older product is often usable if it displays good fluidization. Agglomeration and chunking indicate the product has deteriorated. Questionable product should be application/performance tested to confirm acceptability before use.
I live in southern ky. In the summer, our humidity is way above that.
Lnewqban said:
Could you inject an inert gas or Nitrogen into the jar rather than mechanically evacuating air?
Please, see:
https://en.m.wikipedia.org/wiki/Nitrogen#Applications
I have an argon/co2 mix for my welder. I could use that but not sure if it would do something to the powder or not.
I think the seal on the canning jars is much more robust if the inside is at lower pressure than outside. Particularly if ambient temperature is allowed to fluctuate.
So, in the humid summer time use air from your freezer (at 0F) to fill the jars, put on the lids "finger tight" and remove to vacuum chamber. The remaining internal air will be dry.
And you call that living ?
Buy a bag of silica gel crystal cat litter. Put the gel in a paper bag, in the container with the powder.
The spec for your storage is not so tough. Why not use one of those storage bags for clothes which you put the clothes in and suck most of the air out with a vacuum cleaner? By the time the bag has clung round the outsides of the tins (arranged in a sensible way, the total mass of air (and hence, water) inside will be very small. A flexible envelope would do the same job as a rigid container with 'less of' a vacuum.
  • · Replies 19 ·
10K
  • · Replies 82 ·
28K
