artis
- Messages
- 1,479
- Reaction score
- 977
Hi,
Is it possible to have a transformer/coupled inductors whereby current changes in once coil cause current changes (induction) in another coil but not vice versa?
To put it in other words, is it possible to have such a design of a transformer where for example changes in current in primary coil cause induction in secondary coil but any power fed into secondary coil does not induce any changes in primary coil?The reason I ask this is because I am trying to figure out a magnetic core with an airgap and in this airgap will be a flat strip of conductor where I want Lorentz force to take effect on the electrons. I will have a primary coil on the magnetic core causing a changing magnetic field which will induce a changing B field within the airgap, so far so good. The problem is that I will also get current in the flat conductor strip which will then cause an impact on the B field within the core causing some reverse transformer action in my primary coil.
Because even though the metal strip is not like a coil wrapped around the core , once connected in a circuit it will still form a single loop around the core in a sense so any changes in current in this circuit will affect the primary.
