Can a Set Be Measurable if Its Measure is Less Than the Sum of Its Parts?
The discussion revolves around the concept of measure in the context of sets, specifically addressing whether a set can be measurable if its measure is less than the sum of the measures of its parts. The focus includes the properties of Lebesgue outer measure and the implications of non-measurable sets.
  • Some participants inquire about examples of disjoint sequences of sets where the measure of their union is less than the sum of their individual measures.
  • It is noted that m* refers to Lebesgue outer measure, which is defined for all subsets of R, including non-measurable sets.
  • Some argue that discussing the measure of a non-measurable set is not meaningful, as sigma-additivity is typically a property of measures, not outer measures.
  • There is a suggestion that every non-measurable set could serve as an example of the inequality m*(U Ei) < Σ m*(Ei).
  • Participants discuss the implications of assuming a union of disjoint sets is measurable and how this leads to contradictions regarding the properties of measures.
  • The Vitali non-measurable set is mentioned as a potential source for constructing examples related to the discussion.
Participants express differing views on the significance of non-measurable sets and the validity of discussing their measures. There is no consensus on whether an example of the inequality can be provided, as some believe it is vacuous while others suggest it is possible.
Participants highlight the distinction between outer measure and Lebesgue measure, emphasizing that the properties of sigma-additivity do not apply to outer measures. The discussion reflects uncertainty regarding the visualization and implications of non-measurable subsets of R.
Thorn
I was told that you can find a disjoint sequence of sets...say {Ei} such that
m*(U Ei) < Σ m*(Ei).. That is the measure of the union of all these sets is less than the sum of the individual measure of each set... This is obvious if the sets aren't disjoint...But can someone give me an example of this? Thanks.
Is m* Lebesgue outer measure? If so you will need to use nonmeasurable sets, because equality always holds for measurable sets.
yeah... m* is the Lebesgue outer measure. So, you can say things like m*(E) when E isn't even measurable!? I didn't think m would be defined from a non measurable set...
That's the point of using outer measure: it's defined for every subset of R.
Yeah, it doesn't make much sense to talk about the measure of a non-measureable set. You could come up with ways to interpret the inequality in that case, but the result would be pretty vacuous, unless I'm missing something.
I'd always understood sigma-additivity (i.e., sum of a the measures of a countable set of disjoint subsets = the measure of the union of the subsets) to be part of the definition of any measure.
So I take it, then there isn't an example of this...even for non-measurable sets..?
The Lebesgue outer measure is not a measure for this very reason.
Ha...well then it seems that EVERY non measurable set would be an example of
What do you mean? What are you taking as your disjoint sets?
Be careful, as morphism is saying, what you are talking about is the outer measure, NOT the measure. A non measurable set still has outer measure.
In any case, have you looked at the Vitali non measurable set? You may be able to construct an example if you consider that.
Like someone mentioned above, the set E has to be non lebesgue measurable. Proof by contradiction. Remember that m* is the outer measure, while m is the Lebesgue measure (by assumption). Assume that U= disjoint union of (E_i) such that m*(U)<sum_i(m*E_i). Assuming U is measurable, m(U)=m*(U). Since the set of all measurable sets of R is a sigma algebra, you can easily prove that each E_i must belong to the sigma algebra and are therefore measurable. For each i, then m*(E_i)=m(E_i).Thus you have m(U)< sum_i(m(E_i)), which violates one of the major property of measure (not outer measure though). So U must not be measurable.
Now, back to your question, it's hard to visualize non measurable subset of R. In fact "m(U)< sum_i(m(E_i))" is the property that was used to construct a non measurable subset of R by using R/Q.
Vignon S. Oussa
  • · Replies 49 ·
  • · Replies 16 ·
