Can a Wingless Plane Achieve Lift?
  • Thread starter Stanley514
    Plane Wings
43 replies · 16K views · last reply
cjl said:
To be fair though, I'd expect that you could probably make a remote control aerobatic plane work with no wings.
... or more more realistically, knife-edge flight where the wings are oriented vertically, and only the fuselage (and rudder) produce lift. Some models can perform knife-edge loops.
Spike Selig said:
I installed Real Flight model airplane RC flight simulation software on my computer and have been experimenting with one wing and no wing flight. I taxi the plane so that one wing hits the wind sock then taxi around and hit the other wing to knock them off. I copy flights using real flights software,. then open the copy and record it on my camera. The below one wing and no wing flight took 187 flights before one came out with good quality. The below video shows the plane flying and doing basic aerobatics with only one wing. At the end of the video, I fly through a tent and nock the other wing off. With no wings the plane takes off again flies around patern until it is facing the camera and makes a perfect landing, with again, no wings.
I have a second video of the same plane, an RC model of a Russian aerobatic Yack. This video has take off, fly by, then loops, snap spins, barrel roles, Cuban 8s, and loops, followed by and landing. All no wings. I am having the video remade by a professional videographer before I publish.
Can a plane (Radio Control model in this case) fly with no wings?? I have to say yes!
True. But helicopters have worse efficiency than planes, don't they?
Lighter than airships came at a time when airplanes were in their infancy. They flew and docked at their different ports all the time at the mercy of wind and storms. Germony was the leader in use of airship technology but had to switch to Hydrogen for lift because they were approaching and entering war with the USA who was the chief supplier of much safer inflammable helium. The Hindenburg and other disasters turned the world away from airships as a feasible mode of transportation.
Recently there has been a revival of airships, these equivalent to the Goodyear blimp. These blimps smaller and used today for platforms to cary camera equipment for areal video of sporting events, the crafts having the added advantage of large surface area for posting advertising to those at the events the blimp covers.
The side bar to this is that balloons have become popular as a recreation venue and to some extent a competition vehical. The sport of ballooning has many followers but is limited to those that can afford the purchase, maintenance, and storage of the equipment.
the balloons are mostly at the mercy of the wind direction as they only have means of gaining or loosing altitude. However winds aloft at different altitudes generally flow in different directions with altitude increase allowing the pilot to somewhat control direction by changing altitude.
Sport and recreational balloons can be made in different shapes though to date the different shapes are made for novelty and in some instances (a Coke Bottle shape) the shape approaches advertising.
In 2001, I filed a provisional patent world wide for a balloon that is shaped like a wing. As the balloon is descending, the wing acts like a glider an forces the plane to fly forward. The wings contain the necessary helium or heated air to cause the plane to rise. The wings also are reticulated with aeleorons to react with the forward speed to change direction of flight. In another version the invention called for rotating the wings along their axis opposite each other to eliminate the need for aeleorons.
When the balloon is in assention, the angle of the wing is changed so that the leading edge is higher than the trailing edge, the new wing forcing the balloon to again fly forward. Tilt of the wing is controlled by the relative postion of the heavy basket. Pull the front cables-ropes tighter and loosen the rear ones and the basket's weight causes the front of the wing to move below the rear of the wing. Tighten the rear and loosen the front lines and the wing tilts upward for forward ascending flight.
By controlling the angle of the wing, the pilot can controle the angle of descent or ascent.
Now we have a plane that forward speed with direction and we can "penetrate an apposing forward wind. We can take off and land from the same point or choose any destination. Forward speed generation on descent also lowers the descent rate for more prolonged hot air balloon flight.
Provision in the patenet also called for the cables-ropes between the basket and "wing balloon" to be attached in away that "bends" the wings airfoil shape so the the wing shape is correct for ascending or for descending.
In theory, the glide slope could be made efficient enough to approach modern gliders so that the plane-balloon ascends at say 30 to 1 ascending glide slope and 30 to one descending glide slope. The wing could have stiffeners in it to maintain shape with lower or no lifting element which would allow the craft to decend like a plane and land like a plane with no dependence of the lift of a failed heater.
If the balloon plane ascended to 16,000' then shut the heater off, and the vehicle had a 30 to one glide ratio, now glider would be capable of gliding 90 miles before reaching sea level. If the wind was out of the west and you wanted to go east, you could ascend quickly to high altitude where the winds that incease in speed with altitude are stronger, then you would fly up and down in these high altitude winds lowering only when approaching landing. If the forward speed of the up and down flight were only 10mphh and the winds aloft were30. the ground speed would be 40 and the glide slope would be close to 50 to 1! Now were talking.
Functions of rudder and elevator are replaced by changing the relationship of the gondola weight right to left and front to back. In the event of heater failior, the wing can be designed with front edge ports that ram air into the interior oft he airfoil creating pressure that keeps the wing shape acceptable.
If you were flying west, you would fly up and down in vary low altitudes to stay out of the stronger headwinds at higher altitudes. You would also adjust the glide angle for fast forward speed. Ie: If you forward speed in the air is 10 and the head wind is 10 your ground speed is 0! Increasing airspeed to fifteen would mean a 5 file per hour ground speed. Modern hand held GPSs have a VMG figure that can be used tell you what your VMG to your destination is. Simple fly the altitude, airspeed, and angle to destination that gives
How would such an aircraft effect the RC model industry? Imagine 20 or so wing balloons with heaters that heat the air (or helium), the wings being large enough to lift the vehicle when heated. The ascending and descending wing balloons take off and race around a triangular course then come back to land at a 0 miles per hour touch down!.
This could be great fun, low entry cost, and few expensive crashes that would cause structural damage. A workable size model with deflated wing and heater with helium bottled gas cold fit in a briefcase. Cost of production would be low.. Model could be packaged in vary small cube shaped box. Camera support platform in Indore basketball, football events? Quiet wildlife video camera platform? Stealth spy plane? Aluminized Mylar that causes much slower rate of thermal radiation of heated helium or air? this craft could possibly be designed to be capable of staying up all day.
Imagine fully heated helium wing with one side up and one side angled down taking off. The balloon goes in a helicopter like spin. flies around and comes down in a helicopter like spin. Using the winds aloft to maximum advantage, this could become the most efficient aircraft ever produced.
I have abandoned the patent quest and invite anyone who wants to put together a model to go for it.
What are your thoughts?
Spike Selig Upwind Technologies
I have been flying with no wings on real flight for a couple of months now. If you were in level flight with the fuselage's axis parallel to the direction of flight, inducing a right rudder would create a rudder vector that is above the axis of flight and fuselage. The rudder turns the fuselage to the right, but the rudder's vector being above the axis of role actually rolls the fuselage (no wings remember?) to the left in a counterclockwise direction. The flight attitude in level flight will causerappid loss of altitude as there is no lift component from the prop and no lift from the body. This coaxial flight also occurs when going straight up and straight down. Hense the death out of controle spin straight down and extremely difficult control flying straight up on the props vector. To avoid this I fly no wing with full up elevator. this puts the rudder below the axis of flight where a right rudder turns the plane to the right and, being below the flight axis rolls the fuselage to he right. this is why when flying with a real plane with the nose above full stall, the rudder works well to control the stalled airplane. In level flight of a normal plane the tall non tapered rudder can induce adverse yaw for the same reason, that reason being the rudder is above the axis of flight. A rudder that is "upside down and below the fuselage is much more efficient, a right rudder inducing turn to the right and roll to the right. Fllying with the nose high requires getting used to the rudder and elevator doing everything. To turn right at a high angle of attack, turn right rudder to roll on side, at the same time applying up elevator to push the tail around and causing a turning moment. to avoid catastrophic nose straight down dive into the ground fly in nose high to line of flight. The landing gear struts will give some lift, the bottom of the fuselage will give some lift, the props thrust being aboe the horizon will give lift. Don't fly straight up as the rudder does not work or works in reverse on roll control. When climbing ease off on the elevator a little to avoid going straight up.
When doing a no wing loop, just keep full power straight rudder, and full up elevator.. High powered Yacs will go over the top and do a complete loop. Let go of the rudder to keep from inducing roll during a loop as this role quickly turns the loop into a barrel roll. Landing no wings requires full up elevator for above reasons. Loose altitude with the throtal. The plane comes down vary quickly but with no wings, the planes mass is so low that vary fast descent landings without knocking off the landing gear are the norm. The Yack has a steerable tail wheel so keep the rudder straight on landing as any minor turn at sped on the ground will induce a role over with the plane lying on its side. Take offs are often long before a bump jumps the nose into the air. I often let the tail come up and wait for a bump, at which time I give full up elevator to change to the needed high angle of attack to create enough lift to fly. Be ready with the reset button and push when the plane crashes. In the real world a Yac crashing is a $3000 dollar loss. on Real Flight, just push the reset. record all you flights as sometimes unreal events occur. I hit the roof of the hangar in level flight, the plane bounced straight up in a high rate spin, I got it out of the spin with elevator and landed. The recorder was not on. Just get used to erasing. The video I presented took 187 tries before I got a flight I thought was worthy enough to publish on You Tube. Learn to use this technology on the simulator. Who knows where it will take us.
Let's go back to the original point of this thread. The OP wanted to know about removing the wings from a passenger airliner, not an RC plane. Running RC simulations in RealFlight is hardly suitable to say that the OP's idea is feasible or useful in any way, and that is assuming that RealFlight is even sufficiently reflective of reality to truly model an RC plane with no wings, which I doubt for several reasons.
Well the definition of an 'airplane' is
http://dictionary.reference.com/browse/airplane
The 'plane' part of the word is a direct reference to horizontal (more or less) plane which comprises the wings.
(Which is why early airplanes which had a double set of wings were called biplanes)
Any form of aircraft which does not have wings is there not an airplane but some other kind of flying vehicle.
In reply to the Now if we can only develop a means of controlling the role, I just posted this video on You Tube; Read the comment on the video to understand where the plane in the video is getting its extreme role rate. Role vectors come from the rudder vector not being on axis with the fuselage (no wings) and can be generated by eliminating half of the elevator (as happened in the below video). Right rudder in flight aligned with the fuselage roles the hull to the left. If the left elevator is missing, the right rudder, when oriented to nose down actually raises the tail (nose down) but also induces a torque vector on the hull just as the rudder does. This vector also rolls the hull to the left (counter clockwise looking to the front). The motor turning the prop generates a counter prop direction vector which if ligned with the rudder's and elevator's vectors spin up the hull to speed I do not believe a pilot could survive in the real world. I hope somebody slows down this video and tries to count the rotation rate. It is extreme! Real Flight simulation makes experimenting with these concepts practical, no $3,000 plane crashes, lost pilot lives, and loss of personel on the ground. These concepts must be done on simulator. The simulator may not get it exactly right, but it gets it vary close to "real flight". We don't take a 747 up and shut the engines off to teach emergency proceedures to a pilot.
Correction for above comment: A downward deflection of the right elevator (looking from the rear of the plane) would rotate the hull in a counterclockwise, left role(when looking from the Rear toward the front) . A great solution to no wing ailerons would be to split control of the elevator. Both would be used in unison to initiate pitch up and down of the wingless fuselage, however, the separate left and right elevators could be made to act like ailerons when roll is induced, a left role lowering the right elevator and raising the left elevator. A servo could push and pull a tray of 2 servos for instance. The push and pull operating up and down on the elevator. The 2 servos push and pull with the elevator servo but each of the 2 is connected to one or the other of the two halves of the elevator. operating left or right "aileron" would then cause a left or right role in addition to the up and down deflection. Since these controls are the only means of controlling role, they could be made longer with more surface area to give more stable control. This concept would work well in aerobatic and Harrier flight as the elevator- ailerons would be in line with the prop wash and work a "0" airspeed. I think most aerobatic planes would benefit from the added control in spin, nose high flying on the prop full stall, straight up flight. The coupled elevator aileron's should eliminate some of the mushy, dynamically instable control problems that make entering a harrier attitude so difficult and imprecise. In flying attitudes where the nose is high and the wing near stall, the set up would make the aircraft more controllable, that attitude known for poor role control, the poor control necessitating over exaggerated movement of the rudder. In no wing flight, nose high level flight means the rudder is below the axis of flight and right rudder roles the plane to the right. In level flight (climb or rapped descent) the rudder is above the axis of flight and right rudder creates a left role vector to the fuselage. This is one reason, I believe, that a no wing flight often "spins out of control" with rudder ineffective, the rudder on the wrong side of the axis of flight. No wing flying necessitates the nose be kept high. With the high nose, loss of altitude can be made by throttling back. My video showing aerobatics just got posted on You Tube.
Spike Selig
Again, Real Flight is not a suitable program for determining the flight characteristics of planes. It is not designed for that and does not have nearly enough computational power to react to the vastly different flow field around a plane with no wings. I really wish you'd stop acting like it is somehow a realistic simulation for things like this or else prove to the rest of us that it actually is.
First off, I generally don't trust simulators to get unusual/atypical situations right. They work fairly well within a normal flight envelope because they are calibrated based on measured and observed behavior of real objects. Aerodynamic simulations are very difficult to do in real time (or even not in real time), and a simulator's behavior is really not a great indication of how real aircraft would behave in that situation.
Secondly, that just looks like a reaction to the prop torque to me. With no ailerons and very little to resist a rolling moment, the engine torque being applied to the prop spins the fuselage in the opposite direction to the propeller. This is why you'd need some other method of roll control to make a wingless flight work.
I agree with you completely that Real Flight does not always get it right especially when it has to try and resolve unusual attitudes and circumstances. In the below video just posted, many things were going on in the simulated flight that were probably never imagined by the engineers at Real Flight, the most obvious being that the plane lands in flat spin, the tail bangs down and the plane tips over allowing the wing to absorb some shock, but, with full power, how did the simulator handle what happened after that?
Thanks for keeping the discussion positive. I do want to get a plane into the field and hopefully demonstrate the aerobatics I have developed on Real Flight. Cost is a major problem for me, being 73 and retired. I will be attempting to take off and land a model RC plane with no wings shortly, and I do expect crashes that will cost money.
If I am right, history will be made as I have found no internet material demonstrating no wing flight.
Spike
I think they did a pretty good job on this video also.
It's not a matter of what the engineers anticipated. It's a matter of how the software works and what it was designed to accomplish. The purpose of the software is to emulate flying an RC airplane. It is most likely doing this by solving a very simplified set of physics equations based on measurements made on each model, including wings. Removing wings fundamentally changes the aerodynamics of the situation and is almost certainly outside the scope of what this program can handle given its most likely mode of operation. It does not simulate aerodynamics to come up with new characteristics once a wings falls off, as that would take far more time than your videos. You can't do that in real time.
This Real Flight program is not a valid predictor of no wing flight. It was not designed to do this and doesn't likely operate in a fashion that would allow its extension to such a problem. Further., even if it was valid, the OP asked about doing this on a large scale, and what you've "developed" is certainly not going to be good for moving passengers.
You haven't found it because no one wants to fly with no wings. It's not really worth the massive simulation cost (as real aerodynamics simulations are far more complex than Real Flight). The closest you will get is a missile.
