Can aerodynamic trajectories ever be shaped like this?
  • Context: Graduate
  • Thread starter Thread starter Elroy.LaSalle
    Trajectories
The discussion centers around the theoretical possibility of aerodynamic trajectories resembling a sideways sigma shape, particularly in the context of a trajectory program that includes aerodynamic resistance. Participants explore the implications of the program's calculations, especially at speeds exceeding Mach 1, and whether such trajectories can occur in real-world scenarios.
  • One participant describes a trajectory program that produces a sideways sigma-shaped trajectory with a near 90° downward turn, questioning its theoretical validity.
  • Another participant suggests that validation of the equations and software is necessary to assess the claims made about the trajectory.
  • A third participant asserts that such a trajectory cannot occur on Earth, although they speculate about extreme conditions near neutron stars.
  • A participant provides detailed equations used in the program, explaining the calculations for velocity and position updates.
  • Another participant critiques the independence of x and y calculations, suggesting that the drag formula should account for total velocity and its vector components, which may explain the observed trajectory shape.
  • This participant also notes that similar trajectory shapes can occur in real-world scenarios, such as with table tennis balls, particularly when spin is involved.
Participants express differing views on the feasibility of the described trajectory, with some asserting it is impossible under normal conditions while others suggest it may be possible under specific circumstances. The discussion remains unresolved regarding the validity of the trajectory shape produced by the program.
There are limitations regarding the assumptions made in the trajectory calculations, particularly concerning the treatment of drag and the independence of velocity components. The discussion also highlights the need for further clarification on the equations used in the program.
Elroy.LaSalle
I have recently written a trajectory program which includes aerodynamic resistance, that is, only form drag at this point. Out of curiosity I put in some ludicrous inputs such as speeds above Mach 1 (I know that wave drag becomes significant at that speed and my calculations would be rendered inaccurate), but either way, I get my program to give a trajectory that has a shape like a sideways sigma (not the circle-like one) and that the "projectile" takes a near 90° turn downwards. My question is, can aerodynamic trajectories ever look like this (in theory, at least) or is this an artifact of shoddy programming. I do not want speculations as much as I want a clear, well supported answer. I'll try to eventually get a picture here.
If you want validation of your equations/software, you'll need to post that too.
Welcome to PF, Elroy. (Please pass along my regards to Rosie and Astro. :smile:)
Having thrown, shot, and otherwise dispensed a significant number of projectiles in my day, I can honestly say that what you described can't occur on this planet. Maybe near a couple of neutron stars orbiting each other, but I doubt it.
As Haruspex said, however, you really need to provide a lot more information regarding how you arrived at your observations.
Here is a link to the photo:
http://www.flickr.com/photos/83181851@N04/
You're right, a better question to ask would be about my actual equations. Now my equations are written in such a way that a computer can understand them, not a human; I'll do my best to explain. First I'll post the raw code, then I will explain.
objvely=(objvely+(vectgrav*tstep))
objvely=objvely-(tstep*compdragcoef*sqr(objvely)/objmass)
objvelx=objvelx-(tstep*compdragcoef*sqr(objvelx)/objmass)
newx=(objvelx*tstep)+oldx
newy=(objvely*tstep)+oldy
Line 1:[new velocity of the object in the y direction]=[object's y velocity] + [acceleration due to gravity (-9.8)] * [time frame of calculation, a pre-selected fraction of a second]
Line 2:[new velocity of the object in the y direction]=[object's y velocity] - [fraction of time] * [composite coefficient of drag, gotten from the drag formula] * [square of the object's velocity as in the drag formula] / [the mass of the object, changing a force to a corresponding acceleration]
Line 3: same as Line 2, except in the x direction
Line 4:[new x coordinate] = [object's x velocity] * [time frame] + [old x coordinate]
Line 5: see Line 4
Here it is in dimensional analysis:
Line 1: m/s = m/s + (m/s^2 * s)
Line 2: m/s = m/s - (s * (kg/m) * (m/s)^2) / kg OR (s * N) / kg
Note: kg/m comes from the air density and the surface area in the drag formula: (kg/m^3)*(m^2)
Hopefully I have presented my case a little better this time. I will post the software once I improve its usability.
Thanks
You cannot calculate y and x as independent variables. The square root in the drag formula should take the total velocity into account, and multiply the drag with the corresponding vector components for x and y velocity.
This should explain the (wrong) upwards curved trajectory and probably a part of the downwards movement, too.
"nearly horizontal -> close to vertical" as general shape can happen, you can get similar shapes with table tennis balls in reality. Even the upwards curvature is possible there, but this is related to spin.
  • · Replies 26 ·
15K
