Can all electromagnetic waves carry information?
Electromagnetic waves, including infrared and radio waves, can carry information due to their ability to encode data through amplitude and phase manipulation. Higher frequencies provide greater bandwidth, allowing for more efficient communication, but also present challenges in transmission through materials. Radio frequencies can penetrate common building materials, while infrared and visible light require line-of-sight transmission. The concept of a medium for electromagnetic wave propagation has been debunked since the Michelson-Morley experiment, which supported Einstein's theory of special relativity.
  • Understanding of amplitude modulation and frequency modulation techniques
  • Familiarity with electromagnetic wave properties and behavior
  • Knowledge of signal encoding methods for digital and analog signals
  • Basic principles of fiber optics and their limitations
  • Research the principles of amplitude and phase modulation in detail
  • Explore the characteristics and applications of different electromagnetic wave frequencies
  • Study the design rules for microwave transmission systems
  • Investigate the implications of the Michelson-Morley experiment on modern physics
Physics enthusiasts, telecommunications engineers, and anyone interested in the principles of electromagnetic wave communication and signal processing.
ScienceNerd36
Hello there my fellow physics fact finders,
As the title suggests, I was wondering if we use infrared and radio waves to communicate information because they're the only waves that can carry information, or just because they're the safest.
Which actually brings me on to another question, how is it that information is communicated via electromagnetic waves?
Any wave can be used to encode information. However, certain frequencies are better than others. Higher frequencies generally allow for greater bandwidth, because a given frequency range will be smaller and smaller in comparison to the carrier frequency as we increase the frequency of the carrier. Other facts are the ability to guide the wave when needed. We can easily guide RF and lower frequencies using simple circuits. Microwave frequencies will start to require some thinking about layout and design rules and higher than that it becomes more problematic. For example, infrared and visible light can be guided using fiber optics but the basic nature of how fiber works can be more lossy than a traditional microwave guide that can use a conductor for shielding against leakage.
In addition, the transmission through materials plays a role. While radio frequencies can easily transmit through plaster, stone, and other common building materials (minus metals), higher frequencies like infrared (or obviously visible light) will be absorbed or reflected too much to be used to transmit with anything other than line of sight (and even then, stuff like water vapor can be highly absorptive of certain frequencies).
The information is encoded by making use of the amplitude and phase of the signal. By manipulating the amplitude and phase of the wave we can denote a certain bit stream for a digital signal or encode an analog signal using amplitude modulation or frequency modulation like with analog radio signals. Digital encoding is better because we only assign certain points in the phase space as being associated with a bit stream. This allows us to use error correction techniques since we can measure noise that gets introduced into the signal and remove it and find the most likely desired bit stream.
Thank you very much. I certainly have a bit of reading to do on this subject. I also have another question: Does anybody know what the medium of electromagnetic waves is, or at least has anybody come up with a good theory besides introducing hyperspace and all that higher dimensional majiggery-pokery. (I didn't have a better word.)
electromagnetic waves DON'T propagate in a medium. In the early 1900's were thought they might but the Michaelson-Morley experiment disproved that. This paved the way for Einstein's theory of special relativity. Hyperspace is what they use in science fiction, like star wars. Do you just mean higher dimensons (which I guess you could say is a hyper-space)? In which case I'm afraid you'd have to go a fair bit more 'down the rabbit hole' to reach that stuff. The fact that there is no lumineforous aether (what they called the medium em propogated through back when they though it existed) has been known for over a century.
  • · Replies 28 ·
  • · Replies 21 ·
