Can anybody display the maths?
  • Level: Undergrad
  • Thread starter rob4586
9 replies · 3K views · last reply
rob4586
From another forum
Can you work this one out?
http://i44.tinypic.com/2hxu71s.jpg
It's supposed to be a ladder resting on a barrel. We've guessed the answer will be 12ft, and proven it with CAD! What the maths behind it?
I'd of thought that there isn't enough information there to give an answer! A height would have to be known? :s
A height is known. Look carefully.
there's enough info although it can't be solved simply thru geometry and algebra. You basically have three constraints:
1) ladder top constrainted to move along y-axis (ie xtop=0 and 0<ytop<12.5)
2) ladder bottom constrainted to x-axis (ie 0<xbot<12.5 and ybot=0
3) ladder is tangent to circle
you can use the pythagorean theorem to relate xbot and ytop to the 12.5
you need an equation for constraint #3
You've obviously got its height of 3 at a depth 1.5 from the y axis. So would you have to use the equation of the circle and then differentiate it?
I've considered similar triangles but as previously mentioned there isn't the correct info there I don't think.
rob4586 said:
Sorted it, can be done with Pythagoras!
solved it right?
"Sorted it" sounds like something from Harry Potter's sorting hat.
Also could you tell us how you did it.
jedishrfu said:
solved it right?
Attached the file of the workings, it almost was magic :p
  • Handwritten working on lined paper: a right triangle with an inscribed circle of radius r = 1.5, hypotenuse 12.5, sides labelled x and y, and a quadratic solved for x with the final answers x = 2 and x = 10.5.
Very nice, using the equation for the radius of an inscribed circle. Much simpler than solving for the angle.
