Can drag force and lift force be in the same direction here:
The discussion centers on the relationship between lift and drag forces acting on a particle in a fluid flow. It is established that while lift (FL) acts in the Y-direction, drag (FD) can also have a positive Y-component but is generally at an angle to the vertical. The equation of motion for the Y-direction is confirmed as ma = −mg − FD + V(ρ)g + FL, where FD can be resolved into components. The distinction between lift and drag is clarified, emphasizing that they are perpendicular forces, yet both can contribute to upward motion depending on the reference flow direction.
  • Understanding of fluid dynamics principles
  • Knowledge of vector resolution in physics
  • Familiarity with aerodynamics terminology
  • Basic grasp of Newton's laws of motion
  • Study the principles of vector resolution in fluid dynamics
  • Learn about the equations of motion in aerodynamics
  • Investigate the effects of velocity gradients on lift and drag forces
  • Explore the relationship between lift and drag in different flow conditions
Aeronautical engineers, physics students, and professionals involved in fluid dynamics and motion analysis will benefit from this discussion.
Roul
In the attached picture, can I say that there is a lift force in the Y-direction, and a drag force too in the same Y-direction?
FL proportional to V_fx2 ?
FD proportional to V_py2 ?
Is this equation of motion for the Y-direction correct here: ma = − mg − FD + V(rho)g + FL
The lift force is because of the horizontal flow which is in fact lifting the particle (lets assume there is some small velocity gradient around the particle, as the particle bottom experiences zero flow velocity and particle top experiences the flow velocity), and the drag force is due to the resistance to the particle's upward motion. Is this correct to say?
Please assume that the picture is correct, and such an observation was made.
Edit: Just added the image.
https://imgur.com/x099TgP
Lift and drag are perpendicular to each other, but can both have a positive Y-component.
So the lift force will be in the Y-direction, but the drag force will be at an angle (say theta) to the vertical direction, in between the horizontal flow velocity and the vertical particle velocity. So in my equation can I use FL and FDcos(theta) and rest will be the same, right?
Lift and drag components are perpendicular to each other per definition. Their orientation depends on what you consider as the reference flow direction.
+1
Air flowing past an object exerts a force F acting on the object. You can resolve that force F into two components acting in any direction you want - provided the vector sum equals F. It's conventional to resolve it into two forces one acting perpendicular to the flow (lift) and one parallel to the flow (drag) but there is nothing that says you must do it that way.
For example consider a glider soaring in air flowing up a hill. You could define lift as the component acting perpendicular to the air flow or in a direction that opposes gravity. Depends what you are interested in.
In aeronautical engineering, lift is the aerodynamic force perpendicular to the relative wind, whereas in everyday vernacular, the term lift applies to any force that points up.
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 24 ·
  • · Replies 16 ·
18K
