Can Electricity Flow Without a Complete Circuit?
  • Context: Undergrad
  • Thread starter Thread starter quietrain
    Earth Electricity
The discussion revolves around the concept of electricity flow and the conditions under which a person might get electrocuted when interacting with a power source. Participants explore various scenarios involving grounding, charge movement, and the nature of electric circuits, raising questions about the completeness of circuits and the behavior of electrons.
  • Some participants question whether touching a power source while insulated from the ground would result in electrocution, considering the need for a complete circuit.
  • There is a discussion about how electrons move from the positive terminal of a power source and whether the Earth's electrons contribute to this flow.
  • Participants speculate on the effects of shielding oneself from the Earth and whether it would prevent electrocution when touching a power source.
  • Questions arise regarding the implications of digging into the Earth and the distribution of charges according to Gauss's law, with some arguing that electrocution could still occur.
  • One participant proposes a hypothetical scenario where a large positive charge is placed in a cavity within the Earth, questioning the potential consequences for everyone on Earth.
  • Concerns are raised about the depletion of electrons from the Earth due to earthing practices and whether the Earth can be considered a good conductor of electricity.
  • There is a suggestion that if electrons are continuously removed from the Earth, it could lead to a buildup of charge, prompting further inquiry into the feasibility of storing such charge.
Participants express differing views on the conditions necessary for electrocution and the behavior of electric charges. There is no consensus on the completeness of circuits or the implications of grounding and charge movement.
Participants highlight various assumptions regarding the nature of electric circuits, grounding, and the behavior of charges, but these assumptions remain unresolved and are subject to interpretation.
This discussion may be of interest to individuals exploring concepts in electricity, circuit theory, and the behavior of electric charges in different environments.
quietrain
i was pondering over a few questions
1) if i were to connect a wire from the positive of a power source, and touch the other end to myself, would i get electrocuted? common sense tells me i will, but where is the close circuit? does electricity flow from source to me to the earth? and then how does it get back to the source to form the complete circuit?
2) if electrons were the moving charges in electricity, then how does it come out of the positive source ? does it mean that the Earth's electrons are the ones moving into the positive source? so i should feel the shock at my feet first and not at my hands touching the source point?
3) what if i were to shield myself from the earth, like maybe jump up, or be in space where that is no earth. then if i touch the positive source, will i get electrocuted? where is the complete circuit?
4) if now i were to dig myself into the earth. since by gauss law, all charges resides on the surface of the earth, then if i were to touch the source again, will i be electrocuted? since no charges are inside? the power source is essentially neutral right? so i will not get a cavity inside a sphere with balanced induced charges from the earth.
5) now if i were to put a +ve charge huge enough into a cavity in Earth to attract all the electrons in the Earth to balance it, then all the outer positive charges will be able to move freely, and does it mean it will start to electrocute everyone on earth?
6) also, when we talk about earthing, if we keep taking electrons out from the earth, when willl the Earth run out of it? and since electron can flow freely into and out of earth, does it mean that Earth is a good conductor of electricity? but i though metals are with free electrons, Earth is mainly soil and water right?
7) also when earthing, if i keep electrons off it, wouldn't the Earth get charged up?
thanks!
anyone?
Only if you are connected to something which is connected to the negative wire.
They don't. The direction of movement is into the positive source. And the direction of propagation of field changes is completely unrelated to the electrons' direction of movement. The current is established almost instantaneously, so you will feel the shock at the feet and your hands at the same time.
You will acquire a charge such that you end up at the same potential as the source. Unless the difference was at thousands of volts, you will hardly feel anything if at all.
Yes, as long as the source itself is not touching the earth, you will be electrocuted.
Yes, and it would also destroy the entire solar system.
At a rate of 1A, it would take approximately [tex]1.817\times10^{25}[/tex] years. In an electrolyte, electricity is conducted by ions.
Yes, but I don't see where you plan to store all these electrons.
Possibly. DO NOT TRY THIS WITHOUT SUPERVISION.
Small capacity (batteries) and/or low voltage sources are fairly safe, although you could get quite a nip from the 90volt positive terminal of an old fashioned HT battery for valve apparatus.
possibly? you mean that there is no certain answer to the first question? because i can't find the complete loop for electrons to flow assuming i insulate myself from the ground, but i know i will get electrocuted :( doesn't make sense.
erm, so you mean that if i were to touch the +ve live wire in the socket with my finger i won't die? since i am not connected to the negative wire?
oh but it comes from Earth then feet up right?
so the moderm day power socket is about 240v, and human resistance is about 1k ohms? so 240 / 1000 = 0.24A is this enough to kill? i read somewhere it says 0.2 A is enough to make your heart go haywire :(
but why? you mean if i were to touch the source and the Earth now, electrons from the outer surface of the Earth would flow through me into the source so as to balance the potential difference? then wouldn't that mean that the Earth gets charge up now? so i just need to have a potential step up to extremely high values in the Earth so that if i connect a wire from it to the earth, i literally absorb the electrons and Earth gets charged?
:O
well ok, let's say now i put a charge that is not big enough to kill everyone and the solar system but enough to free some electrons on the surface of the Earth then i could still get Earth to charge up right?
er how do we know it would that take long?
well , i am thinking if we could leave all the Earth surface charged, then wouldn't i be able to connect wires to space installations and send electricity with near infinite electricity? since the Earth takes so long to lose all its charges !
and now, thinking further, if i am able to use something else that conducts electricity besides wires, like maybe air when it reaches breakdown potential, then i could literally send jets of electricty outwards from Earth to maybe kill impending asteroids or aliens :X
I repeat my safety warning.
You asked if your would be electrocuted and later if you would die.
To which I replied possibly because the severity of the effect would depend upon the capacity of the supply and the quality of your insulation from ground.
You can safely tough the positive (or more likely negative) terminal of a Van Der Graff gnerator at 250,000 volts if you are well insulated from Earth because the capacity is low and the insulation is good.
But if you touched the +200V terminal of a (very) old fashioned DC mains supply you would probably be electrocuted. DC supplies are inherently les safe than AC because once grasped, you cannot let go of a DC one.
weird, i read a number of post online and some say ac is worse, some say dc is worse assuming equal voltages
they say ac cause burns jerks etc while dc make uninterrupted continuos flow
some say ac is alternating so safer, but some say the alternating is the one that kills because of jerks ... :(
oh well ... thanks anyway!
Think about the lightning strike version of this. If the voltage in your question is high enough it can jump from you to earth...which is essentially and infinite sink...
In fact some power generation uses positive voltages on lines and uses the Earth as the "return".
When electricity was first discovered, experimentalists assumed it was a positive charge so that's the conventional direction still used today...way back then the electron had not been disocovered...actual current flows opposite to conventional flow.
see my answer to (1)..can there be a "spark" form you to earth?
oh so you mean ionization of the air? so that electricity leaps off me through the air and into the earth?
now, what if i insulate myself in a box , if i touch the positive terminal of a source, will i get shock?
gigasoft mentioned earlier that i would just get the same potential as the source.
so does this mean that electricity does not need a close loop to flow? since the charges have to flow into me, for me to have the same potential as the source. there is no close loop at all.
in a sense i became an extension of the conducting source?
so if that is the case, why when we connect a resistor or capacitiy to just the positive terminal of a source, there is no current measured?
I am sorry I seem to be wasting my time, as you only listen to what you want to hear...
If you genuinely believe you can#t get a shock by touching only one terminal of a DC source, explain why some people experience shocks from touching door knobs.
well, that's the whole point i am asking. where is the close loop? i can't find the close loop for electricity to flow.
i never said i believe i won't get a shock, that's why i am seeking answers here. but in your post you only keep telling me that i will be shocked, but how? why? and now you ask me to explain my own question about why people get shock? if i knew, i wouldn't be wasting my time asking here :(
You actually asked 7 questions originally, and later tried to impose all sorts of trick conditions.
In my opinion that is not the way to understanding.
I actually only addressed the first of your questions and only for safety reasons.
However, since no one else seems to want to try to untangle your issues here is more.
There is no requirement that a 'circuit' be present for charge to move. A circuit may be present and this allows us to deduce certain useful circuit laws.
Charge can move or be moved on or in a body.
Charge can collect or be collected on or in a body.
The ease or difficulty of these processes basically take up most of the theory of electricity and depends upon many factors. The usual starting point for this is called electrostatics or static electricity - a bit strange really since the charge actually does move.
If we start with a system where everything is neutral or uncharged everywhere we can cause or allow this to change by causing or allowing charge to move and collect at certain places in our system. The system remains neutral overall because there is no external source of charge or external place for charge to leave the system to (a sink).
This may sound a pompous mouthful, but consider my doorknob example.
A neutral person walks across a nylon carpet in dry conditions.
In doing this some charge is transferred from the carpet to the person, who is no longer neutral.
This charge spreads out over the surface of the person, but cannot go further because the environment is dry and insulating. The nylon carpet itself is insulating and prevents the charges going to the floor underneath.
When the person reaches the door he reaches out and touches the metal knob.
Because the knob is conductive compared to the person, most of the charge collected by that person is rapidly transferred to the knob and is felt by the person as a (small) shock.
Each transfer of a small amount of charge from the carpet to the person is also a very small shock, but not perceived because it is a small change over a relatively long timescale.
This is why the person perceives the discharge process as a shock, but not the charge.
Indeed...
quietrain, go watch some youtube videos of guys moving off helicopters onto 220kV transmission lines watch the huge discharge between the transmission line that the probe rod the guy uses to get to the same potential as the line
and also because the transfer of charge is not directly against the sensitive skin, as in the discharge to the doorknob through the fingertips, rather it is over a wide area of the soles of the shoes :)
Dave
davenn said:
Indeed...
Dave
are you talking about this video? http://www.youtube.com/watch?v=9tzga6qAaBA&feature=related
i don't really understand what he's doing here
when he takes the probe rod and place near the transmission cable, there is electricity, but it looks fake? or is it real?
also, i assume the transmission cable is insulated? then how does charge fly out? or in?
anyway, so if charges are transferred, so that they are at same potential, so its the suit that he is wearing that is at the same potential? but he is insulated from the suit inside so he does not get the charges?
so when he wants to take something from the helicopter, he needs to zap the helicopter to be at the same potential so no electricity transfers? but since zapping also transfers charges, then why don't he just take directly? the helicopter is not grounded either?
There is no requirement that a 'circuit' be present for charge to move. A circuit may be present and this allows us to deduce certain useful circuit laws.Charge can move or be moved on or in a body.
i am sry but in my opinion, asking questions is the way to understanding. questions arise when you practise and practice makes perfect.
and if no one wants to answer my questions , then perhaps i have asked a complicated one , or it is just plain dumb. in any case, i don't see why i should be discouraged to ask questions.
and if i udnerstand what you are saying, that means if i were to connect a +ve source only to a light bulb , i would get an instantaneous flash as both potential become the same, i.e charges flow from source to bulb. but it ends when no more charges flow and potential are the same.
so if i were to add a connection to the Earth and use a mechanical device to create the source electricity, like charging glass with fur, then i would be creating electricity?
so now i am thinking is there a way to maintain a constant potential? like maybe tap the sun's energy? but i don't know how to translate heat energy to electric potential energy :(
It's only been half an hour. You need to be patient. Some of the easier answers:
Yes, it is real. No a transmission line is not insulated. It's the suit and the helicopter that get charged. No, he doesn't get charged and no, he's not insulated from the suit - people have higher resistance than a metal suit, so electricity won't flow through us when we're wearing a meatal suit. No, the helicopter isn't grounded - it's hovering!
Because you're earthed. You don't need to 'close the loop' so far as a physically wired circuit goes.
When you touch a live terminal the current flows through you into the ground (or whichever path is easiest).
Think of a lightning strike on a lightning conductor. It strikes near the top and flows away, dissipating in the ground below. It's the same basic principle as touching a live terminal, AC or DC.
In comparison, if you wear really thick rubber shoes you could probably grab a live terminal and experience no shock at all. I wouldn't try that though.
Thats the real deal mate :) you are seeing several 100kV arcing out to the probe which brings him and the helio up to the same voltage potential. He is wearing a wire mesh suit which produces a Faraday Cage around his body.
Him and his other mate on the other set of lines, work their way along each set of cables
looking for damage to the lines and to the line / insulator connection point.
nope... its bare cable you can see the multiple strands of aluminium wire making up each cable
correct, look up google about Faraday Shields
He doesn't go back to the helicopter till he's finished working his way along that length of cable. Now the interesting thing is that he has to re-establish the potential balance with the helicopter before getting back onto it. This infers that the helicopter must loose some of that charge ... leakage to the air ? I don't know ... as there is again lots of zaps from his rod to the helicopter platform.
I love the comments the guy makes right at the end of his narrative.
... I'm only afraid of 3 things, electricity, heights and women...
hahaha... he works on EHT power lines at a great height and he's married ! haha
Dave
just a comment and clarification about a mains power system
when you touch the HOT (phase ) terminal you are closing the loop
In most western countries and I assume the USA as well the neutral is grounded at the house, the power station and other points along the way.
So when you poke your finger into the phase socket you are completing the loop to the neutral return via your body and the ground.
Just as effective and putting the finger of one hand into the phase and a finger of the other hand into the neutral.
Dave
hehe... ok ,thanks everyone!
Questions are OK, but they are a very inefficient way of learning about a subject.
They certainly enhance the learning experience, but especially until you have some basic knowledge and understanding, you cannot know what questions to ask.
So keep asking questions, but take notice of what responders are saying. Their comments may be pointing to unasked questions that you don't realize you need to ask to attain understanding.
If a poster offers a response, apparently unrelated to your question, it may be that he knows more than you and is pointing the way to an aspect you should be also considering.
because of static charge
So?
Static isn't some magic form of electric. It requires you to complete the circuit.
When you touch the doorknob you do just that - exactly the same as when you touch the live wire.
I'm surprised he isn't insulated from the suit. Even if the metal in the suit have much lower resistivity than humans, the resistance will depend on geometry as well, and if he gets warm and sweaty inside the suit I wonder how a thin metal thread can compete with the much larger cross sectional area of the human body.
For example, If the Earth is considered to be at more or less constant potential, it must be thought of as a conductor, not an insulator. If it's a reasonably good conductor it can't be because its conductivity (specific conductance) is high compared with metals, but because of the dimensions, that the there are square meters rather than square millimeters for the current to flow through.
The suit isn't insulating you. It's providing a path of less resistance around you.
To insulate you it would have to be made of something like rubber (an insulator) - and that could be worse because the charge would then move through you not the suit.
You need to ensure the easiest path does not involve traveling through the body by using a good conductor.
The suit is acting as a Faraday cage - they are not insulation.
Adding a conductor around you isn't the same as insulating you. They are different ways of dealing with the problem.
Definition of insulating:
To prevent the passage of heat, electricity, or sound into or out of, especially by surrounding with a nonconducting material.
http://www.thefreedictionary.com/Insulated
http://www.dictionary.net/insulated
Hmm, I think circuit is a just a convenient way to set up an electrical field to drive current. For example, if you use a battery you can make sure that the two sides of your load are connected to the two terminals of the battery, which ensures that you have potential different across your load, and can thus establish electric field.
In theory you could drive electrical current so long as you have a way to drive a field. So I guess the question is whether or not you have set up a field in your proposed example, which I believe is to just connect the one terminal of the battery to a light bulb and leave the light bulb connected to something else other than the second terminal of the battery. What would you connect it to instead? and can you convince yourself that whatever you connected it to has less electrostatic potential energy than the connected terminal?
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 18 ·
