Can Electrons and Muons Revolutionize Alternative Energy Sources?
  • Thread starter Thread starter ~()
    Electron Muon
32 replies · 9K views
I was actually pondering the existence of modern electronics, and the ability of a magnetic generator which applies a force to move electrons in a copper wire. As another energy source is used to turn the turbine (e.g coal, fuel - combustion, nuclear), the magnets apply a electromagnetic force against the electrons in the coil, and so too in the wire connected to the generator. Thus the power source alternates (i.e it move either way, the poles are changing - A.C) and the electrons are slammed across the resistors connected to the wire, applying energy to them.
I was thinking would there be any other ways in which we could use particles like the electron to supply energy to devices? Maybe even slightly modifying the key fundamentals so that we could dramatically increase the energy output (yeild) ?
I was considering the existence of a muon (i.e the heavy electron, ~207 greater in mass then the electron). What if we replaced this with the electron? Obviously there are major problems, - the first that the muon apparently has a finite life-time. Also they would probably be too unstable in a simple metal wire - they would probably not act the same as an electron, so material engineering would need to be considered to encase such a particle. - Still its interesting to think about such possibilities? Does anybody have any thoughts on this subject?
What if we replaced this [muon] with the electron?
I think you meant to write, what if we replace the electron with the muon.
Well, as was mentioned, the muon has a short life-time, ~2.2 microseconds, so by that alone using muons for any energy source is impractical. Secondly, if the muon could replace an electron, it is much heavy, which means its response to a given electric field is considerable different - it moves more slowly.
I doubt that we will be changing the 'key fundamentals' in order to make energy generation more efficient.
Astronuc,
I concur. Besides the inefficiencies in our methods of generating electricity are not
in the generator. The generator is actually a very efficient devices.
No - practically all the inefficiency is in the steam cycle - and the problems there have
to do with the 2nd Law of Thermodynamics - one can't "get around" the laws of physics.
Dr. Gregory Greenman
Physicist
Well I agree based on the fact (which I too mentioned initially), that simply due to the relatively short half life of the muon this is a impracticle idea (amongst other things). However, because we simply limit ourselves to using electronics as the means to transfer energy, we must also realize that this will have serious consequences on the future of technology - largly due to these physical limitations. As engineering systems become more complex, larger and more sophisticated, eventually we will see drawbacks which limit us seriously due to the lack of power available, this is already a very real fact with 'chemical source' space propulsion.
Perhaps this discussion is a little over my head, but it is not true that electrons, given their size, have the highest charge density? How is that a limitation?
Are you talking about something like light to transfer energy, the same as fiber optics are being used for information transfer?
To echo Candyman, I don't see a definite limitation there. The biggest problem I see with power transmission is the loss of energy in the form of heat due to resistance in the wire. Potentially, we can (nearly) eliminate that problem through the use of super-conducting materials, so high temperature super-conductors are an active area of research. If that happens, we'll be able to get the same amount of energy at the end of the wire as was originally transmitted, using electrons. You can't ask for anything better.
As we try to maximize the efficiency of energy production systems such as fossil, nuclear ect. the physical limitations that we are dealing with are initially due to the in-efficiency of the respective system (in large part due to the conversion rates of one form of energy into the other - into the usuable electrical energy which runs appliances).
However systems will increase to their maximum physically limited efficiency and then ultimately the limitiations will lie in the electrical transfer system (electrons transferring their energy to an appliance). Note: I am not talking about undersirable resistance - energy loss as heat. To a certain point, the generator will only be able to turn so fast, the density of the electric current can only physically be so much and the needs of more power for more sophisticated and complex systems will increase in magnitude.
Scientists are already experiencing major diffuculties in trying to convert nuclear energy to electrical - so maybe there has to be another way? - I am simply postulating this - I mean surely there been research done into this? - Other forms of energy transfer?
Whatever it is, it certainly has not been using muons considering the ADDED problems and issues surrounding them.
Zz.
Energy losses during transmission are not so significant as compared to the inherently limited efficiencies of current thermdynamic cycles. For example, in most commercial nuclear power plants, the conversion from thermal to mechanical energy is about 33%, based on the steam Rankine cycle. Increasing the temperature to that used in coal plants could increase efficiency to 37-38%. Improvements in turbine design have actually increased the efficiency of the most modern nuclear plant to about 36% or so. Gas-cooled reactors have a potential efficiency of 42% based on much higher steam temperatures.
HOWEVER, there is a problem associated with higher temperatures and that is degradation of the structural materials over time. That involves corrosion, erosion and creep (mechanical deformation) which degrades performance and ulimately leads to 'failure' of the system. Certainly one can replace a component before failure, but replacement costs money.
Aeroderivative gas-fired (natural) gas turbines can get about 42-45% efficiency (Brayton cycle), and if one adds a steam (Rankine) cycle on the back end to catch the output of the Brayton cycle (for a so-called combined cycle plant), one can realize about 60-62% conversion efficiency.
Still, fusion plants with 'direct conversion' would theoretically obtain efficiencies of something like 85-90%. BUT, commercially developed fusion is still theoretical (hypothetical).
Transmission losses are about 1 to a few %.
Superconducting transmission lines would be nice, but are impractical given the length of lines and necessary cooling over such distances.
In relation to the last post, by astronuc, one can easily see the energy conversion rates - in terms of the efficiency of current reactor/generator systems. Though these are the efficiencies now, future designs will obvisouly increase in efficiency - even if by a little, to a value which will approach closer and closer to the actual physical limit.
But again I mention that I was not initially talking about the in-efficiencies of converting energy from one form to another (as done by a reactor/generator assembly), nor the losses incurred in electrical systems. Merely, that we are physically limited by the amount of energy that electrons can transfer to appliances, which are due to factors such as speed, mass and forces applied (of and by the electron). These physical limits are due to the particle and its interaction in an electrical system. I was wondering if there was any work done into other 'particle-energy-transfer' methods, apart from using electronics?
And yes, Zapper, it has been mentioned several times that the muon is un-plausable for this - this was merely an example to convey the idea.
I mean, if we increase efforts in space exploration, one can understand that energy requirements will gigantically increase. Also the method of trying to convert one form of energy to electrical - like nuclear scientist are working on, more so for fusion, is a rigorous and lengthy battle , simply just trying to convert the energy. If other methods were hypothesised maybe we could eliminate using other forms of energy to turn a generator - which already has limits - and be looking at a new branch of energy tranformation and supply? > surely this has been postulated somewhere.
But see, this is what you keep missing. Most of us DO NOT SEE that there is any "problem" here. It has been mentioned several times that the electrical conduction is not where the problem lies. If we ever get room temperature superconductors (probably not in my lifetime), then this issue is even moot. You are talking about trying to eliminate probably less than 10% of the total energy loss in the whole transfer chain. So it is puzzling the rest of us why you are picking on this 10%, while you are ignoring the source of the other 90%.
One would think you would put more emphasize on the main culprit. Try justifying that to a research funding agency.
P.S. There ARE other means of energy/signal transfer. Optoelectronics and spintronics are ways to transfer signal in "circuits" from one location to another. However, these can only carry a small amount of energy at any given time and does not approach the amount of energy that a typical household circuit has to transfer.
Zz.
I have already mention 3 times that I am not talking about in-efficiencies in an electrical wire - try and read the posts carefully. Who is interested in 10 % losses - did I not mention that these systems will get more efficient as technology progresses ?
I am simply saying that energy production at the moment is concerned with developing systems (such as nuclear - fusion, and others) to turn a electrical generator. Trying to convert energy from one form to another (i.e. creating fusion reactions to turn the generator) has massive problems. Is there not any other ways of providing energy rather than trying to turn a generator? - Supplying energy without using electronics, - perhaps other forms of particle collisions?
Nobody has mentioned transferring signals?
The first paragraph mentions copper wire and "the electrons are slammed across the resistors connected to the wire, applying energy to them." The only reason to generate electricity is that it is "transmitted" by a continuous network of wires from source (generator) to user (lights, appliances, machines). The major inefficiency has to do with thermal to mechanical conversion. The conversion efficiencies from mechanical to electrical and in transmssion are relatively high.
Direct conversion in an MHD/plasma system might achieve 80-90%, as opposed to the efficiency of a steam (Rankine) cycle of ~34-38%, or gas combustion system (42-45%), or combined cycle (60-62%). Electrons are still involved since atoms are composed of nuclei (p and n) and electrons. Other particles don't enter into the process - except for gamma rays in fission and fusion - and they are not useful sources for electrical energy.
One is pretty much stuck with chemical energy, nuclear energy, or more benign forms such as solar energy (PV), wind energy or hydroelectric.
Fusion is problematic at the moment regardless power conversion method.
Microwave? Need line of sight to avoid significant losses, and one would need a lot of antennaes at source and user points.
Because that's where the real problem is - where do you get the intial source of energy.
Not really - fusion reactions can give you heat - and we know how to turn heat
into electrical energy just as we do now.
Transferring energy via heavier particles is going to be more inefficient than electrons.
Heavy particles don't like to travel through materials - and they lose energy as they
do. The movement of electrons through metals is many, many orders of magnitude
more efficient than other particles.
In essence, we're already using the "best" particle for transferring energy - and that
is the electron.
Physicist
Not really - fusion reactions can give you heat - and we know how to turn heat into electrical energy just as we do now.
So your saying that there isn't major problems with fusion reactors (i.e. tokamak - ITER, ect.) and trying to convert the little plasma achieved (due to low density) into turning a generator?
Yes but I am saying that we are focussing on converting one form of energy to another (mainly fossil or nuclear --> electricity) by turning a generator. You and various other people have mentioned that the problem lies in the inefficiencies of the coversion of mechanical energy to electrical (other posts mention 30%-60% for steam/generator cycles). I am not interested in these inefficiencies - I am talking about the physical limitations of electricity (i.e. electrons, their mass and speed - slamming into resistors and applying energy) - and if there is other methods that have been previously theorised, hypothesized or looked into to do with other forms of energy transfer - INSTEAD OF USING ELECTRICITY - use some other particle/energy/transfer system. I am not interested in turning a generator because I am talking about electricity, I am talking about other supposed methods of energy transfer to devices.
Transferring energy via heavier particles is going to be more inefficient than electrons. Heavy particles don't like to travel through materials - and they lose energy as they do. The movement of electrons through metals is many, many orders of magnitude more efficient than other particles.
Yes, that's a nice summary of modern particle physics and energy transfer. I was actually referring to the existence of credible data that supports that fact; that currently with our knowledge of physics, the electron is indeed the best candidate for energy transfer. Even though this is true currently (simply because it is use), has there been work done on other possible methods? - This is an area in physics that seems to be non-existent.
In the future when we have worked out these small inefficiencies with the transfer of mechanical energy to electrical, surley electrical energy will have a physical limitation to energy transfer. What then - how will we continue to advance upon energy transfer? I mean electricity will be at its maximum potential - will this be enough for energy requirements in the human races advancement into space?
So you either didn't care, didn't read, or simply didn't understand the other examples that I gave on possible signal/energy transfer using opto-electronics and spintronics?
And what exactly is the "physical limitations of electricity"? Electrons don't "slam" into resistors in a superconductor, so this really, in principle, shows that in principle, "resistors" can be insignificant. So what else?
Zz.
Fission and fusion produce thermal energy by virtue of the kinetic energy of the products. This thermal (kinetic energy) has to be converted into a form that can be transmitted.
If one uses electromagetics (photons), then the kinetic energy of the fission or fusion products has to be transformed into photons - by excitation of some material, then the photons have to be collected and directed into some transmission system.
As for the examples ZapperZ mentioned, opto-electronics and spintronics, they appear suitable for transmission of low energy densities.
Spintronic devices are used in the field of mass-storage devices, not power conversion.
http://www.nanotech-now.com/spintronics.htm
http://www.glue.umd.edu/~jfabian/spintronics.html
Opto-electronics seems to be a broad field, including lasers, but I find no examples of power conversion systems.
The Optoelectronics Group (http://www.ee.ucla.edu/~photon/) at the UCLA School of Engineering and Applied Sciences focuses on optoelectronics, high speed optical communications, high efficiency light-emitting diodes and nano-cavity lasers, photonic crystals at optical and microwave frequencies, and quantum computing and communication. However, power conversion does not seem to be a factor.
You have a misconception of how you get energy from a fusion prlasma. You don't
get the energy from the low density plasma. You have to study up on the physics
here. In the most probable fusion reaction that would be used - "D-T fusion", there
is an energy realease of 17.6 MeV of energy. Of that only 3.5 MeV goes to an alpha
that can be trapped by the plasma. The rest of the energy, 14.1 MeV; goes into the
neutron produced in the reaction.
When a fusion plasma ignition is achieved - it will be a large neutron source - and
most of the energy it produces will be in these neutrons. The neutrons and their
energy will be captured by a "blanket" probably in the form of a "shower" of liquid
lithium. The neutron energy will be captured as heat in this "blanket" which will be
cooled - and the energy used to generate power in a conventional manner.
WRONG! The inefficiency is NOT in the conversion of mechanical energy into
electrical - that process is VERY efficient. The inefficiency is in the conversion of
HEAT to mechanical. There are very good reasons WHY - due to the physics - that
this must be so.
Your whole way of thinking about this is in error. Electrons don't "slam into
resistors"
If you think that this is an area of physics that is "non-existent" - then you haven't
studied the physics. Additionally, I wasn't talking about "particle physics" in the
way that term is used in physics. I was talking about how these "non-electrons"
that you want to have tranport energy will do the job.
We know very well the physics of how particles transport through matter - which
happens to be my particular specialty. These other particles are going to LOSE
ENERGY at a rate MUCH GREATER than the passage of electrons.
Most of the "volume" of an atom is taken up by the "electron cloud" - the nucleus is
a very small portion of the atom by volume. As electrons flow through a metal or
other conductor - they are essentially "handed off" from one portion of the electron
cloud to another. Electrons have an easier time "flowing" through this cloud because
they are the same type of particle as the cloud is made of . Other particles would
react with, and and disturb the electron cloud - which would result in energy loss. For
example, any positively charged particle would feel a continuous "drag" force in
traversing through the negatively charged electron cloud.
You have to dispel yourself of this notion of "electrons slamming into resistors" -
because it is just plain flat out WRONG - the physics doesn't work like that. When
you study how electrons and other particles truly do move energy - a field that is
very well understood - then you'll see why we use electrons.
Physicist
Who is interested in transferring signals and small amounts of energy? How can this be used for large scale energy transfer like electricity - it can't.
Opto-electronics, electro-optics and spinotroics are basic forms of small signal and energy transfer (astronuc metioned this - the "transmission of low energy densities", optical telecommunications, LED's) - these are tought in high school - nobody is talking about this...
Furthermore I was talking about electrical conductors (wires) and how electrons are applied across resistors ( i.e. Alternating Current) transferring their energy to them. - I havn't mentioned anything about room temperature superconductors and what not...
You have a misconception of how you get energy from a fusion prlasma. You don't get the energy from the low density plasma.
Firstly what is prlasma?
Secondly nobody is saying that nuclear engineers are using low density plasma to do anything. All I was saying is that the tokamak (and similar fusion reactors) are currently unsucessful because they achieve creating low density plasma through nuclear reactions. This is not sustained for very long and therefore is not sufficient for power production. Furthermore the nuclear energy from this is siphoned off to create electricity - so you must turn a generator. Whether you collide these particles into a "blanket" to produce heat which creates stem and then turns a generator is irrelevant - the heat is used to operate mechanisms (generator/magnet assembly) which create electricity.
Indeed the inefficiency is in coverting the initial form of energy to cycle (or turn) the generator - this was a error on my part. I should indeed say this instead of saying that it lies in converting mechanical to electrical. However, it is in the mechanical stage that the inefficiency lies since the initial energy source (fossil, nuclear ect.) which is used to create steam is considered apart of that system.
We know very well the physics of how particles transport through matter - which happens to be my particular specialty. These other particles are going to LOSE ENERGY at a rate MUCH GREATER than the passage of electrons.
Obvisouly using other particles in a manner that is similar to the nature of the electron is improbable - since the metallic lattice (combined of cations, localised and delocalised electrons) is a already viable state which occurs in nature. However magnetohydrodynamics is an area which seems to hold plausible prospects for future efforts in using nuclear reactions to create energy.
Whoa nellie! Remember, YOU asked this:
OTHER METHODS! And so I brought up OTHER METHODS that have been experimentally shown. And even *I* have mentioned why these are NOT considered as feasible. You asked if there are others. I showed you examples and why they aren't feasible! You continue to ask why aren't there examples. I told you again about these and why you ignore them. And now you're telling me you don't want these because they carry such low energy! Well of course! I have said that already! It was my point that there have been other methods of transfering signals and energy, and they all cannot do what simple electricity can do.
And superconductivity IS relevant to this because of your wrong impresson of what "resistance" actually is! If I can remove resistivity in the transport of energy, then do you still have an issue to discuss?
Wait a second. You want to deal with MHD, but then you asked this?
Firstly what is prlasma? <sp>
Er.. what gives? Shouldn't you understand plasma physics first before jumping into MHD and touting it as the next best thing since sliced bread?
Zz.
Plasma is the fourth state of matter. Matter exists as solid, liquid, gas, or plasma
depending on temperature, density, specific energy... Plasma is an ionized gas.
The plama isn't created through nuclear reactions. In fact, it's the reverse; the plasma
is created by other means to facilitate the fusion reactions that we seek. The hope
is that tokamaks will be developed that can hold the plasma for longer periods.
The fact that the reactions aren't sustained very long is not an argument here. The
plama created in a thermonuclear weapon, i.e. hydrogen bomb; isn't sustained for
very long either - but you wouldn't say a hydrogen bomb doesn't produce a great deal
of energy?
For example, the other proposed method for nuclear fusion production - inertial
confinement fusion or "laser fusion"; the plasma doesn't last very long either.
However, there can be enough energy released via nuclear reactions in that
very, very short time to be very useful. So time isn't a factor if the rate of
energy release is large enough.
How is the fact that the neutrons produce heat in the blanket irrelevant? That's how
one captures the energy of the fusion reaction - most of which is in the kinetic
energy of the neutrons.
Actually the inefficiency is NOT in the mechanical stage. Mechanical systems are
very efficient. The inefficiency exists in the HEAT stage. Unlike mechanical energy,
heat energy carries "entropy". It is dealing with the entropy that causes the
inefficiencies imposed by the 2nd Law of Thermodynamics. You'll learn about this
if / when you study Thermodynamics.
One can use magnetohydrodynamics when one has hot charged particles. One can
capture the energy of these hot charged particles with magnetohydrodynamic devices.
For some fusion reactions, this may be an option.
However, the most energetic hydrogen fusion reaction, and the one that will most
probably be used; is the D-T reaction. As I stated previously, most of the energy
of the D-T fusion reaction is released as the kinetic energy of the neutron produced.
Magnetohydrodynamics won't work on neutrons - because they have no charge.
Physicist
Plasma is the fourth state of matter. Matter exists as solid, liquid, gas, or plasma depending on temperature, density, specific energy... Plasma is an ionized gas.
Really that's what it is - I didn't know that (sarcasm...)
My goodness, can't you see that you mispellt plasma as plarsma - the r.
I was mearly making a joke...
Below this I clearly went on to clarify low density fusion reactions in reactors like the tokamak - so how could I not know what plasma is?
You must be as slow as zapper - who also tryed to clarify the same thing...
Furthermore zapper --> electro-optics and opto-electronics are already existent, they are not experimental...And they have zero relation to what I was initially discussing. I was not talking about LED's and insignificant electronics such as that - I was talking about high level energy transfer, and other forms of particles collisions apart from electricity. The key word in apart from electricity (electro-optics & opto-electronics are cleary to do with electricity). Notice how they have the words electro in them - relating to electricity.
The information you were discussing was besides the point - that is in no way optional forms of larger energy transfer (it is merely small signal and small energy transfer still using electronic systems).
The plama isn't created through nuclear reactions. In fact, it's the reverse; the plasma is created by other means to facilitate the fusion reactions that we seek.
? I think your a bit lost. Fuseable fuel is inserted into the tokamak - which is a toroidial tube that is surrounded by electro-magnets. These magnets cause the fuel to cycle around the reactor, eventually in certain regions the fuel is dense enough to cause a fusion reactions and create plasma.
plasma isn't created through nuclear reactions.
Intresting statement. I think these following sources, including modern physics would disagree with you:
http://en.wikipedia.org/wiki/Nuclear_fusion
http://en.wikipedia.org/wiki/Plasma_(physics)
To say that plasma isn't created through a nuclear fusion reaction is just plain wrong. The temperature, pressure and violence of a fusion system can easily ionize close by matter converting it to a state of charged ions - i.e. plasma (ionized gas).
The hope is that tokamaks will be developed that can hold the plasma for longer periods.
Yes, this has been mentioned by myself. That is what I was refferring to when I was discussing low densities and fusion reactors.
Zz.
You obviously don't read the posts carfully enough. If I am disussing MHD than I must know about plasma. - Read the posts more carefully next-time.
I was not discussing how heat is used to create electricity, in fact the opposite, I was discussing other forms of energy transfer - note neutrons colliding with the blanket creates heat which in-turn (after the generator) produces electricity. It is irrelevant because I am not talking about electricity - I was discussing other forms of particle/energy transfer.
You said nuclear reactions created the plasma in a tokamak. That's not
true - the plasma is created before you get nuclear reactions.
They don't disagree at all. In a tokamak, you have a gaseous state
until the gas is heated and compressed by the magnetic fields, neutral
particles... You don't get nuclear reactions in the tokamak until you have
created the plasma first.
You are confusing sustaining the plasma as opposed to creating
the plama. You don't get fusion reactions until you have a plasma conditions.
I've read your posts and noted numerous errors in your understanding.
I don't know how much you know about plasma and MHD and how much
they are just words that you've heard.
As long as we are getting nit-picky about spelling; I assume you meant
"then" instead of "than" in your second to last sentence above.
Physicist
As long as we are getting nit-picky about spelling; I assume you meant "then" instead of "than" in your second to last sentence above.
Yes, very funny.
It's interesting how you are supposedly a physicist, yet you have so much time to reply to any post immediately (don't quit your day job, whatever that is). Its also interesting to note that your saying that I'm getting nit-picky about spelling when not too long ago I clearly remember you doing the same thing to me through other posts (I was under a different username at the time).
Furthermore MHD is a fairly straightforward concept which has not yet been put into practice for large scale energy production because it still has many developmental issues, and so there is not much that needs to be understood about it to discuss its basic ideas and precepts. Until we get the nuclear reactions right - there is no point discussing MHD in detail. Using plasma in a magnetic field to operate a conventianal AC generator is not that complex to understand.
You are sure that you wouldn't rather withdraw this statement that I have quoted you saying? Although the poloidal field heats the plasma initially within the chamber, any nuclear reactions which occur also too create plasma. Your effectively saying altogether that any nuclear reaction will not create plasma.
The initial ions within the tokamak are in a plasma state simply so that they can be controlled and heated by either fields - the toroidal and the poloidal fields respectively, however these ions exhibit different characteristics to the plasma after fusion - which exhibit strong radioactive properties. Usually all three major forms of radiation are present.
It is not quiet acceptable to accelerate paticles together who are neutral and cause fusion? - this doesn't need 'plasma conditions'. You are saying that fusion wouldn't occur? Electrons still have a charge which can be used for EM acceleration - in either case the positive repulsion of the nucleus is still present and has to be overcome (just as in plasma) - however in this case, the nucleus's must pass each others electron shells first.
No, it isn't. There has been a thread on here on this very issue, and I have responded why collision via accelerator isn't going to work to create the plasma needed. If we can, we would have used RHIC and the Tevatron as a fusion reactor. And we haven't even talked about the amount of energy required to accelerate such a thing.
You need to show how a plasma is created that initiates the fusion. If such a thing is that easy, we won't need the National Ignition Facility at all.
Zz.
P.S. How much time Morbius has or has not is none of your concern and should not enter into this discussion. Stick to the issues, which seems to have gone all over the place here.
P.P.S. And voila! Here's the thread on "fusion accelerator" and why I find it highly impractical.
https://www.physicsforums.com/showthread.php?t=90734
NO - I'm not saying that a nuclear reaction will not create a plasma.
The initial ions within the tokamak are in a plasma state simply so that they can be controlled and heated by either fields...
No - the ions are not in a plasma state simply so that they can be controlled. They are in a plasma state
because that's what's needed in order to get nuclear fusion. For example, in inertial confinement or
"laser fusion", the fuel is also a plasma - but there are no magnetic field coils to control the plasma
in laser fusion. The plasma is created because that's what it takes for nuclear fusion to occor.I'm saying that until you create the plasma in the tokamak - you don't get nuclear
reactions. It's a little like your home gas furnace. The burning gas will sustain
high temperatures - above the ignition point of the gas.
However, is it burning gas that originally creates the high temperature? If you have a
modern gas furnace - one without a pilot light - the high temperature is created first
by an electric heater that ignites the gas.
Likewise here. In getting nuclear fusion, you have two competing forces; the strong
nuclear force and the Coulomb or electric force. The nuclear force is the stronger of
the two - but it is short range. The Coulomb force, while weaker, is long range.
When you try to fuse two nuclei - they repel each other because they are both
positively charged. If the nuclei don't have enough kinetic energy, then they won't
get close enough for the nuclear force to take hold and fuse them.
Therefore, BEFORE you get a nuclear fusion reaction, you must get the nuclei to
conditions wherein they have enough kineitic energy to overcome the "Coulomb
barrier" as it is called - and THEN you get nuclear fusion reactions.
If the nuclei have high kinetic energy - that's just another way of saying that the
material has high temperature - it's hot. As you are heating the gas up to temperatures
at which fusion will take place - long before you get to fusion temperatures - you will
reach a temperature at which the gas becomes a plasma.
So in the tokamak, or an inertial confinement fusion capsule - you create the plasma
FIRST - THEN you get nuclear reactions in that plasma. But the plasma isn't
created by the energy from nuclear reactions. The plasma is created via energy put
in via the magnetic fields, ohmic heating, neutral beams - whatever method is being
used in that fusion device.
Physicist
NO! What "neutral particles" are you going to get nuclear fusion with?
In nuclear fusion - you are fusing nuclei. The nuclei of atoms are POSITIVELY
CHARGED! An atom is neutral, because it has electrons surrounding it.
However, because the strong nuclear force is so short range - you have to get the
nuclei closer than the electrons are to the nucleus. Because the nuclei are closer
together than the electrons are to the nuclei - the electrons don't neutralize the
the charge on the nuclei. The nuclei REPEL each other.
The way you get nuclear fusion is to get the nuclei moving fast enough so that they
can overcome the Coulomb repulsion. If the nuclei are moving fast enough so that
they overcome the Coulomb repulsion - then the gas is very, very HOT. It is so
hot that it will be a plasma.
As ZapperZ points out - one could accelerate one of the two nuclei - but you are not
going to get sustained fusion that way. Even if you use an accelerator - you are
accelerating ions - not neutral particles. So even in acclerator fusion - the gas is
ionized - hence a plasma.
So YES - you need temperatures high enough for the gas to be a plasma in order
or fusion to take place!
Physicist
Colliding beams of particles, proton, deuterons or other nuclei will produce a lot more scatter than fusion. Some neutron sources use deuterons accelerated into tritium-bearing targets, but those produce very low energy and are very inefficient.
If accelerators were the way to go for fusion, we'd be doing it already.
Astronuc,
Exactly. If one uses an accelerator to accelerate deutrons into tritons, for example -
then it's a "one shot" situation. You've expended all this energy to accelerate the
deuteron - and as Astronuc points out - the most probable result will be a scatter,
and not a fusion reaction. Hence, for the most part - you've "wasted" all the energy
that it took to accelerate the deuteron.
If you put your energy into creating a plasma - then there will be multiple chances -
multiple collisions of the deuterons and tritons - and with the multiple collisions - one
has a chance of getting nuclear fusion in some of those.
Physicist
