Can grandpa understand the Bell's Theorem?
  • Context: Graduate
  • Thread starter Thread starter miosim
    Bell's theorem Theorem
404 replies · 64K views
As I understand nobody here see the contradiction between the dogma of QM and the prediction of the discussed above Gedanken Experiment; and it is fine with me. Let’s move on and try the Gedanken Experiment #2.
This is the classical Aspect’s experiment with one exception: the source of entangled photon is replaced with UNTANGLED twin photons that maintain untiparallel polarization.
What is your prediction for this experiment?
miosim said:
As I understand nobody here see the contradiction between the dogma of QM and the prediction of the discussed above Gedanken Experiment...
That's because there isn't one ... and it's not just a Gedanken experiment ... Aspect and Zeilinger and others have done precisely that experiment many times (with the exception that they don't have "perfect" detection efficiencies), and they always obtain results that are consistent with the predictions from QM . So I really don't understand what your point is ...
Assuming that the new source produces counter-propagating beams with random polarizations, the statistics for the individual detector readings at A & B will be precisely the same (50-50 between |H> and |V>), and the coincidence statistics will be completely uncorrelated for any choice of detector settings and any setting of the "polarization rotation device".
Jonathan Scott said:
There's a pair of photons which are in a combined unknown state, as a pair.
If you do anything to either one of them which does not involve resolving the state into a pure state, such as rotating it, reflecting it or whatever, then that operation acts on that half of the pair but does not affect the other one and doesn't tell you anything about the state. If however you do anything which definitely does resolve the state, such as putting it through a polarizing filter or a beam splitting device then observing it with a photo-detection device, then that also means that the state at the other end is now also known.
Obviously if you rotate or reflect a photon before observing it, then when you've resolved its state you have to backtrack through those operations to deduce the original state and hence the state of the other photon.
Exactly; and there is nothing fantastic about us deducing that state. As I already remarked, this example demonstrates that the hypothesis that the measured photon magically and in no time communicates its state to its entangled photon is flawed, as that alone could not do the trick. Also information about its history would need to be communicated, which in turn would have needed to be remembered somewhere, which makes such a hypothesis increasingly implausible. :biggrin:
Given that entanglement violates locality anyway, you only need to assume that the particles are physically connected via their shared history (which is a connection back in time on one side and forward on the other). There is no need for a separate record of the history.
You could alternatively assume that the particles communicate via a spacelike connection along the traveled path, where the connection is subject to the same operations (rotation, reflection etc.) as the original photon, but I think that this idea may have been undermined by Aspect's experiments using a high frequency switch to select between alternative observations.
First, I don’t know any Aspect or Zeilinger experiment that “… have done precisely that experiment many times…” meaning installing the wave plate on one side. This experiment is intended to challenge the Bell’s theorem indirectly by demonstrating that QM entanglements and changes to one particle only are incompatible. This was the main point of my Gedanken experiment #1. However I could be wrong.
As I understand, you prediction is based on the Bell’s paradigm according to which to achieve the cos^2 correlation the photons need to be entangled (to preserve their superpositions by action over the distance). However the way I understand this experiment, the EPR correlated photons (that are untangled, but maintain antiparallel polarization) should produce the same cos^2 correlation without any action over the distance. Now we have a tangible disagreement.
How difficult is to perform this experiment?
miosim said:
First, I don’t know any Aspect or Zeilinger experiment that “… have done precisely that experiment many times…” meaning installing the wave plate on one side. This experiment is intended to challenge the Bell’s theorem directly by demonstrating the QM entanglements that in my opinion is sort of the “conservation of momentum” that couldn’t be violated without braking the entanglement. This was the main point of my Gedanken experiment #1. However I could be wrong.
I think that you are wrong. The Aspect and Zeilinger experiments use polarizing beam splitters (PBS) for their detection. For practical reasons, it is easiest to work with such devices when all the detection beams are parallel to the table. Therefore, I am pretty sure that the way that they "set the detection angle" for their detectors is to put a polarization rotator in front of each PBS, rather than physically rotating the PBS.
I also don't understand what you mean by the "conservation of momentum argument" ... could you please elaborate? Also, as Dr. Chinese said .. do you really expect to find something so simple that was missed by all of these extremely good and well-respected scientists? Not to mention all of the reviewers who have critiqued their work before accepting it for publication.
As I understand, you prediction is based on the Bell’s paradigm that to achieve cos^2 correlation the photon need to be entangled (to preserve their superpositions by action over the distance). However the way I understand this experiment, the EPR correlated photons (that are untangled, but maintain antiparallel polarization) should produce the same cos^2 correlation without any action over the distance. Now we have a tangible disagreement.
Hmmm .. I may have misunderstood your second gedanken experiment initially ... I guess I should have asked some clarifying questions before answering. As I now understand it, you are proposing a hypothetical source with the following characteristics:
1) It emits counter-propagating beams of paired (i.e. time-coincident) photons A & B.
2) The polarization of photon A is always randomly chosen to be |H> or |V>
3) The polarization of photon B is always guaranteed to be anti-parallel to that of A
If that is what you are proposing, then I don't see how that is any different than entanglement. In other words, the wavefunction written in terms of the detector states will be exactly the same as in the previous case. Thus I would expect that you see precisely the same results as for the first example.
As for doing the experiment, I am not sure how that could be accomplished. When you say the two beams have characteristics 1 through 3 above, but are UNENTANGLED, I guess you mean that they come from independent sources, or something like that? I cannot see how you could accomplish this experimentally ... the sticky point is condition 1) .. i.e. the photon pairing. I don't know how you can guarantee that two photons can be emitted at the same time from two different sources. If you are using lasers, you could synchronize the timing of pulses to very high accuracy, but each pulse contains a huge number of photons, and there is no well-defined relationship between any pair of photons in different pulses.
I guess your point is that there is nothing mystical about entanglement per se, and any source that has the characteristics of 1-3 will produce the same behavior as for entangled photons created by parametric down conversion. I think I agree with that ... remember what I have been telling you from the start ... all we can specify experimentally is what goes in (i.e. conditions 1-3 above), and the detector settings. The only issue I see is that it is not clear to me how we could satisfy conditions 1-3 without using entangled photons. However, having said that, I don't think it matters that the source you describe uses photons ... if you set up the same experiment with classical objects, the detection statistics would be the same.
Consider the following set up:
1) you have a machine that produces pairs of boxes with lightbulbs on them, A & B
2) the lightbulb on box A is randomly chosen to be on or off
3) the lightbulb on box B is always guaranteed to be in the opposite of box A
4) the state of the light bulb on box A can be "rotated" by passing it through a device that has some probability of flipping the state according to a user-specified "angle". The probability relationship is designed to be analogous to Malus' law for photons.
I am not 100% certain, but I believe the classical device described above will produce identical measurement statistics to the entangled photon experiment we have been discussing. I would appreciate it if someone more deeply familiar with these experiments (are you there, Dr. Chinese?) would verify this please. Obviously, if I am wrong about this, then I have a critical misunderstanding somewhere .. and I would like to rectify that. :biggrin:
SpectraCat said:
I think that you are wrong. The Aspect and Zeilinger experiments use polarizing beam splitters (PBS) for their detection. …
Indeed I was wrong. If no other, more important issues, I would try to understand why changing the polarization in one entangled particle doesn’t considered as a violation of entanglement. I may come back to this at another time.
This is just an analogy with the classical physics. Nothing important.
DrChinese said:
As to your opinion: it is clearly not based on the relevant science, as that has already been expressed to you many times in this thread. It makes me laugh to imagine you telling this to Bell, Aspect, or any other scientist (as if you discovered an important new fact that they failed to consider in their haste). But hey, otherwise good luck with that.
I don’t belief in authority. I also have a very little respect to the “well-respected scientists” who insist on the greatness of QM. Personally I’m not impressed with this theory at all. Actually I don’t think that QM is a theory, but application only. According to Wikipedia “…A formal theory is syntactic in nature and is only meaningful when given a semantic component by applying it to some content...” As far as I am concerned QM doesn’t have meaningful semantic component.
Regarding other scientists I respect Einstein (who in my opinion was born too yearly to be fully understood) and Schrödinger. I like John Bell’s bold thinking, but I wouldn’t hesitate to tell him what I think about his theorem.
I think that I provided enough material to ridicule my self-assurance.
It is correct, more specifically this beam consists of the the former entangled photons that were “striped” from their entanglement and become EPR photons.
It is correct.
I agree with you and this is my main argument against Bell’s theorem; he compared the behavior of the real QM model with the fake deterministic EPR model and find that “fake” model gives different prediction.
If the fake deterministic EPR model is replaced with the real EPR model it would be no inequity.
In the proposed experiment we would use the correlated (but not entangled) photons and would achieve the same result without any action over the distance. However according to Bell it is impossible:
“…It cannot be done, so long as action at a distance is excluded…” (from Bertlmann’s Socks And The Nature Of Reality.)
So if this could be done the Bell’s theorem is dead.
I think that we may use the same source as in the Aspect’s experiment but with beams passing through the media that causes the wave function collapse, but preserves the untiparallel polarizations. I see other potential solutions to achieve a similar result, but if you agree with me on the outcome of Gedanken Experiment #2 I see no need to perform this experiment.
I will respond on the rest of your comments later.
It is correct
Why would you need entangled photons if the Gedanken Experiment #2 (that doesn’t use entangled photons) would yield the same result?
1) you have a machine that produces pairs of boxes with light bulbs on them, A & B …
I am having problem with the expaining the physical phenomenon, that is far from being understood, in terms of analogy. Analogy is a simplification of phenomenon and therefore is distortion of this phenomenon. However if this phenomenon is fully understood the analogy could be selected to insure that at least the critical element of the phenomenon we try to explain isn’t distorted.
Therefore I can’t accept any illustration of Bell’s theorem in terms of light bulbs, coloring balls, socks, etc that oversimplified and further distorts already distorted by simplified reality portrayed in the Bell’s theorem where QM events are described in terms of algebra and Yes/No results. I also found unacceptable that Bell provides his interpretation of “what Einstein had in mind” by using a naive classical picture. I am not surprised that eventually Bell comes with the abstract EPR model which prediction contradicts with the empirical QM. I wish Einstein would slap Bell’s hand and remind him that EPR argument wasn’t about how QM predicts, but how it interprets results. If Bell believed that the EPR interperation indeed contradicts with the prediction of QM (and if Einstein isn’t around to defend him self) Bell must show that his interpretation of EPR is correct or at least Bell must collaborate this interpretation in more details.
The ovrsimplifying the reality and sloppiness in justification of initial conditions for Bell’s theorem discourages me from learning more about Bell’s paradigm and his definition of reality (if you let me to redefine a reality I can prove/disprove anything). Majority probably find my ignorance as non justifiable, but I wouldn’t spent more time to prove it, because a talk is cheap.
It is why I should better focus on the Gedanken Experiment #2 to conform or refute the Bell’s paradigm experimentally. If this experiment conforms the Bell’s paradigm I will buy a beer for DrChinese.
As I understand there may be a difficulty to produce the source of the EPR correlated photons. If there isn’t the optical media that would collapse the wave function and in the same time preserve untiparallel polarization of photons, we may use a different approach as follows:
We may produce the EPR correlated photons by using the two polarizers set in parallel and placed at the opposite sides from the light source of entangled photons. This will produce the corelated photons in one particle angle. Rotation of these polarizers in tandem will produce the the polarized correlated photons pairs of any chosen angle and the Aspect-like experiment will be performed for the any number of chosen angles. Would it work?
P.S.
Actually, do we really need rotating polarizers to produce untangled photons pairs or stationary would work as well for this experiment?
SpectraCat said:
[..] if you set up the same experiment with classical objects, the detection statistics would be the same.
If I correctly understand your example, there is a flaw there: the light bulb on box B is supposed to be always opposite to that what box A would have if it were not altered by your operation no.4. Just now (in post #364) Jonathan proposed "only" a "connection back in time" for that issue. :biggrin:
I have now come to regard Bell's Theorem as just another paradox; with paradoxes the devil is often in the details as they say. :-p For example, relativity theory has paradoxes based on "perfectly stiff" objects.
Something similar may be the problem here. As I mentioned in a parallel thread, according to Tim Maudlin's "Quantum non-locality and relativity", "real laboratory conditions at best allow some approximation of perfect agreement or disagreement".
Obviously, in order for such a classical example to reproduce an entangled photon experiment, the same level of approximation must be created.
Harald
Yes, that is indeed what I meant. I should have added
5) the result for box B is determined PRIOR to the operation on A performed in number 4.
As I understand it, time for photons is different from time as we experience it, because photons don't have a frame. So perhaps that is not as strange as it might sound.
Those are not paradoxes .. those are misunderstandings of relativity .. at least the ones I am aware of are. Personally, I think paradoxes are ALWAYS misunderstandings, and we as humans are prone to them because of the inherent bias associated with the development of our intellect and consciousness in an environment that is, at least ostensibly, governed by Newtonian mechanics.
Harald
Right, the way this is typically dealt with is that you make the "no conspiracies" assumption. In that case, the imperfections in the detection arrangements appear as random noise, which has the effect of suppressing statistical correlations, rather than enhancing them. Therefore it should always work against experimental demonstrations of Bell violations.
Sorry but wouldn't this be very different than entanglement?
Example using unentangled photons with anti-parallel polarizations:
Both detectors are set vertical. Photon A is polarized at 30 degrees from vertical, so photon B is at 120 degrees.
Photon A (if I understand Malus' law correctly) has a 75% chance of passing through the detector. So if it does pass through, photon B still has a 25% of passing through its respective detector.
But with entangled photons, if photon A passes through its detector then photon B is instantly determined to be at 90 degrees, which means it has no chance of passing through the detector.
Have I missed something?
Oh, hello all BTW. I'm very much a layman on this subject so please be gentle if I've got anything wrong! :)
Jon
Usually photons are detected after operations such as no.4
Photons have an infinite number of frames... probably you meant that they have no rest frame. For a photon time stands still; but that is irrelevant. Physical theory relates to our experience of time, as measured with "perfect" material clocks. And such clocks only run forward.
Paradox 1. a statement or proposition that seems self-contradictory or absurd but in reality expresses a possible truth. - http://dictionary.reference.com/browse/paradox
If that is true is perhaps part of the debate that is discussed in parallel threads as well as in the physics FAQ. However, I merely replied to your question "if the classical device described above will produce identical measurement statistics to the entangled photon experiment we have been discussing". Apparently your own answer here is that it won't.
Who said anything about detection? I was describing *exactly* the objection you raised in your previous post. You said that "the light bulb on box B is supposed to be always opposite to that what box A would have if it were not altered by your operation no.4.". My addition of 5) was to clarify that.
Of course I know the definition of paradox .. don't be condescending. Re-read what I wrote ... the first part of my I was expressing my doubts that relativity paradoxes you mentioned are actually paradoxes when fully thought through by someone with a deeper understanding of physics (see http://en.wikipedia.org/wiki/Ehrenfest_paradox" for the resolution of the rigidity problem you mentioned). The second part was about my opinion that paradoxes are actually artifacts of human consciousness.
No, what makes you say that? I have said that I think it *will* produce identical measurement statistics ... once we have clarified its operation according to the last few posts. Of course I might be *wrong* with that prediction, but so far I can't see why this wouldn't produce identical results.
Detection is measurement; commonly photons are measured after one of them passes through a wave plate. Your addition 5):
"the result for box B is determined PRIOR to the operation on A performed in number 4."
I wonder if that corresponds to the quantum description which has that the result of the measurement is only determined at the time of measurement (as also suggested by tests with ultra fast changing detectors).
Of course I know the definition of paradox .. don't be condescending. Re-read what I wrote ... the first part of my I was expressing my doubts that relativity paradoxes you mentioned are actually paradoxes when fully thought through by someone with a deeper understanding of physics [..]. The second part was about my opinion that paradoxes are actually artifacts of human consciousness.
I had already re-read what you wrote and was merely trying to be polite: First you made the erroneous claim that I was mistaken to call them paradoxes while they are paradoxes by definition, and immediately thereafter you invalidated that claim as you expressed agreement with the standard definition of "paradox".
Note: You are talking to "someone with a deeper understanding of the physics" concerning such SR paradoxes (I even published a corrected solution to another paradox in a main physics journal), and that's why I gave that SR example. From my experience with SR paradoxes and the similarities I am optimistic that this nut will also be cracked (if it did not already happen!). :smile:
I can see no reason why a classical example that in principle has no precision limit would exactly reproduce the QM precision limitations that I cited, and you seemed to agree. There may also be other objections; let's wait for drChinese! :smile:
I understand your objection, the word "result" was perhaps a poor choice, but I don't think the distinction is an issue for this explicitly classical simulation. However, perhaps a better way to phrase 5) so that it is consistent with QM is to say the following instead:
5) The state of the lightbulb on box B is always opposite to that of A for specific setting (say 0º) of the "rotation" device described in 4).
Actually, I think I really already said that, because I specified that the rotation device obeys the analog of Malus' Law for this example.
Hmmm ... I don't know ... I guess I read that definition differently that you do. To me a paradox is no longer a paradox once it has been resolved, but I guess I see your point. Also, it is true that these things retain the name "paradox" after they have been explained (e.g. Twin's Paradox, Zeno's Paradox), so I guess that is consistent with your usage as well. It sounds like we agree about the important part: namely that they are usually (and perhaps always) artifacts of human consciousness, rather than real contradictions.
Sorry .. which "nut" are you referring to? The original EPR Paradox?
My point before was, if you allow the "no conspiracies" assumption, then noise will only attenuate the correlations, rather than increasing them. Extra random noise can always be artificially added to systems where it is absent ... it is the opposite trick that is difficult :wink". So, although I didn't say it explicitly before, I think that you could induce an artificial precision limit in my classical example to match experimental reality.
I definitely agree that he will likely be able to clarify whether my classical model will indeed produce statistics consistent with QM entanglement.
SpectraCat said:
[snip our agreement about several things]
For me Bel's Theorem is a "nut to crack". Indeed I forgot that already EPR's paper is called a paradox, but I forgot why. :rolleyes:
I'm aware (perhaps not fully) of the difficulties that those people are facing who try to create local realist models models. :-p
So, although I didn't say it explicitly before, I think that you could induce an artificial precision limit in my classical example to match experimental reality. [...]
Good :smile:. I guess that with such a device your example can exactly simulate a quantum device - any other objections?
Cheers,
Harald
Lord, I hope you're not calling me a local realist! :smile:
I just want to make it clear that I think that it will only work for this particular example. The point I wanted to make to miosim that somehow appears to have gotten lost in all of this is that, if you add a SECOND "rotation" device (like the one described in 4) to the B stream, whose setting can also be arbitrarily chosen, then the results for coincidence measurements will be DIFFERENT from the predictions of QM, and from the experimental statistics with entangled photons. I thought I had put that into my earlier responses, but somehow it seems to have gotten left out.
miosim said:
It is correct
Well, there is an important point about your Gedanken experiment that we have been neglecting so far. Namely, as designed, it cannot lead to a Bell violation (at least I don't think it can). In order to make an experimental test of Bell's theorem, you need to be able to choose the detector settings at both sides of the experiment. So for your Gedanken's you would need to have a second polarizer for the B photon, which could be set to an angle independently of the polarizer for the A photon.
Now, in that set up, you would find very different results for the two gedanken experiments. For gedanken experiment #1, you would find perfect anticorrelation of the measurements any time the detectors were set to the same angle, so if you set them both to 45º, you would see perfect anti-correlation. For gedanken experiment #2, the you will only see perfect anti-correlation when the detection basis is identical to the basis in which the photons were polarized from their sources. If you were to set both the A and B detectors to 45º, you would see no correlation between the two sets of measurements.
Again, I am not 100% certain of this, but I recently went back and re-read some of the original papers linked from Dr. Chinese's website, and I believe this is correct.
No, I don't think this would work, because the photons will not be properly paired.
P.S.
As I said above, you need to be able to change the settings at both detectors if you want to test a Bell inequality.
This is the situation when you use a single Type I PDC crystal with a V> laser source: You get HH> all the time (never VV>).
It is also the case when you use a type II source with V> input: you get HV> all the time and never VH>.
In both of these cases, the photons are entangled but not on the polarization basis. So you end up with Product State statistics. There are perfect correlations at some special angle settings. In general do NOT follow the cos^2 rule except when one of the settings is H or V.
Finally, something I can sink my teeth into! :smile:
Hey, there is nothing wrong with questioning authority (I do constantly, though not so much in this forum). But the flip side is that it is useful to have a common language to discuss things. The reason scientific authority arises is from the UTILITY of the theory. It is not the person. That is just a label for an idea that can be applied and lead to something we can build upon further. That is why Bell was so important.
I wish that Einstein were alive to see Bell. I think he would have been astounded by that result.
A quick 2c: I am sure he'd be astounded that anyone believes it!
He'd simply run a sound Gedankenexperiment, like https://www.physicsforums.com/showpost.php?p=3259676&postcount=127, and get back to real physics: The experimental science that tests our theories; Bell's theorem being nowhere confirmed in our quantum world, except classically.
So, please, seriously:
1: What in the above experiment would Einstein object to?
2: Or Bell, for that matter? Given that Bell [1964: eqn (14)] acknowledges that:
B(lambda, b) = – A(lambda, b),
and its equivalent is to be found in the above Gedankenexperiment on a single (pristine, entangled) photon.
[My apologies for being on the fringe of PF at the moment; due other priorities.]
Grandpa has replied to the above:
"PS: There is an objection each would make, I'm sure! There is a mistake in my wording at https://www.physicsforums.com/showpos...&postcount=127 ! IT SHOULD READ:
7. Now, Alice; with added confidence in your retrieve-and-restore technique: Test and re-test retrieved-and-restored V1', at orientation b, many times: THE OUTCOME IS (say) b+; every time! But now test and re-test at b, many other "equivalent" particles; "equivalent" in that they too give a+ when first tested at a:
8. Outcome: P(b+|V1', b) = cos^2 (a, b). P(b–|V1', b) = sin^2 (a, b).
[NB: What if you had been working with a different photon-pair; say V1" and V2". And (say) V1" at orientation a had given the result a–? No problem. That a– notation says that the post-test polarization of V1" is orthogonal to orientation a. Then the multi-test outcomes of that photon's many "equivalents" at orientation b would yield:
P(b+|V1", b) = sin^2 (a, b). P(b–|V1", b) = cos^2 (a, b).]
Sorry, etc. I trust it's all correct this time."
Me too.
SpectraCat said:
… In order to make an experimental test of Bell's theorem, you need to be able to choose the detector settings at both sides of the experiment. So for your Gedanken's you would need to have a second polarizer for the B photon, which could be set to an angle independently of the polarizer for the A photon.
In my Gedanken experiment there are two independently rotated polarizers A and B, the same as in the Aspect’s experiment. The only difference is that instead of entangled photons there are EPR correlated photons.
SpectraCat said:
… For gedanken experiment #1, you would find perfect anticorrelation of the measurements any time the detectors were set to the same angle, so if you set them both to 45º, you would see perfect anti-correlation…
I am not sure what the “anti-correlation” refer to. The correlation varies only from 0 to 100%; I thing you mean “untiparallel polarization.
In this case, according to the gedanken experiment #1 all entangled photon pairs have 0% correlation when detectors set untiparallel.
SpectraCat said:
… For gedanken experiment #2, you will only see perfect anti-correlation when the detection basis is identical to the basis in which the photons were polarized from their sources. If you were to set both the A and B detectors to 45º, you would see no correlation between the two sets of measurements.
Again it is hard to interpret what “anti-correlation” means, otherwise according to Bell, there is no difference between entangled and EPR photons at angles 0º and 45º. (see figure at post #1)
DrChinese said:
… the photons are entangled but not on the polarization basis. So you end up with Product State statistics. There are perfect correlations at some special angle settings. In general do NOT follow the cos^2 rule except when one of the settings is H or V
If I understand you correctly, the correlated (vs polarization-entangled) photons in the gedanken experiment #2 do NOT follow the cos^2 correlation while per my understanding of EPR phenomenon they SHOULD follow the cos^2 correlation. This could mean that the gedanken experiment #2 may falsify the Bell’s theorem. Do you think that it is worth to try this experiment?
Please explain what distinction you are drawing between entangled photons and "EPR correlated" photons .. you probably explained that before, but I have lost track. It was my understanding that the original EPR gedanken dealt with entangled pairs. Are "EPR correlated" photons local realistic, where the polarization angles are determined by local hidden variables?
perfect correlation = coincident measurements on A & B reveal that they always have the same polarization state ... this is the case for Type I PDC entangled states when the detectors at A and B are set to the same angle.
perfect anti-correlation = coincident measurements on A & B reveal that they always have opposite polarization states ... this is the case for Type II PDC entangled states when the detectors at A and B are set to the same angle.
uncorrelated = coincident measurements on A & B show that, if A is in one state, |H> or |V>, then B has an equal probability of being in either |H> or |V>
The first two cases allow us to know the state of both photons from a measurement on only one of them. In the last case the measurements are independent; measuring A gives you no information about B, and vice versa.
I don't like to talk about "0%" correlation, because it can mean either the second or the third case above, depending on context. In fact, I think various people on this thread have used it in both of those ways at different times.
You have to be careful .. if you have specified a Type I PDC entangled state, then rotating one side by 90º (as in your gedanken #1) will result in anti-correlated statistics when the detector angles are parallel.
If you have a Type II PDC, then your statement is correct.
Sort of ... what I said was that you CAN get the cos^2 correlation for gedanken #2, but ONLY for one choice of detection basis, namely the original polarization basis for the photons. In other words, if you keep the A detector set at 0º relative to the original polarization basis (the |H> and |V> polarization defining the entangled state as it was emitted from the source), then you will get cos^2 as you rotate the B detector angle from 0º to 90º. However, if you start with A and B both at the same random angle (say 79º) with respect to the original polarization basis, and then rotate B from 79º to 169º then you will not get a simple cos^2 relation anymore. The coincidence statistics will reflect both the relative angle between the detectors, AND the angle of the detection basis with the original polarization basis.
However for gedanken #1, you ALWAYS get cos^2 correlation for ANY detector settings, whatever the polarization basis might be. For example, if you start with both A and B at an angle of 79º with respect to the original polarization basis, and then rotate B relative to A, you will get the same statistics as if you started with both A & B at 0º, or any other initial angle (provided they start out equal). You cannot FAIL to get cos^2 correlation.
... while per my understanding of EPR phenomenon they SHOULD follow the cos^2 correlation. This could mean that the gedanken experiment #2 may falsify the Bell’s theorem. Do you think that it is worth to try this experiment?
It won't falsify Bell's theorem ... because they won't show a cos^2 dependence for any choice of detector angles, as I explained above.
I guess, you can say that for EPR photons the polarization angles are determined by “local hidden variables”.
According to EPR paper (1935) both correlated particles (having antiparallel polarization) after separation “… no longer interact, no real change can take place in the second system in consequence of anything that may be done to the first system… thus it is possible to assign two different wave functions… to the same reality …” . My understanding of EPR particles is based on that description.
While within QM mechanics there two types particle pairs: entangled and untangled (produced after wave function collapse), I don’t believe in existence of entangled over distance particles.
My gedanken experiment #2 intends to demonstrate that there is no difference between “entangled” and “untangled” photons by producing the same cos^2 correlation.
I don’t fully understand |H> and |V> polarization and the difference between Type I PDC and Type II PDC. I need to do some homework on my own prior to continue.
|H> and |V> just refer to the orthogonal (i.e. perpendicular) directions "horizontal" and "vertical", which are always the two basis states for polarization. What changes is the starting angle in the laboratory frame. In other words, you can say that 0º in the lab frame defines |V>, then 90º defines |H> ... if 25º defines |V>, then 115º will define |H>, and so on .. just as long as they are always perpendicular. The way I used them in my last post .. |H> and |V> were the polarization basis for the photons as they came out of the source. As I indicated, that defines a basis that is "special" in the case of your gedanken #2, but is essentially irrelevant for gedanken #1.
Check Dr. Chinese's site for study materials on PDC crystals, and the rest of this stuff.
The EPR state IS the entangled state. There is no difference. What you specify in your #2 is completely different because you specified they are NOT polarization entangled. If they are not polarization entangled, they are not in an EPR state on that basis.
And of course this experiment HAS been performed many many times*. I doubt anyone would bother to write up such a result for fear of being laughed at, but who knows? (You are certainly welcome to try it yourself.)
*How do I know this? Every scientist who uses Type I entanglement MUST do it when properly aligning the crystals. They start with 1 crystal (which is your #2) and then add the second (which is your #1). The stats change as they are getting the second in place.
Just to be completely clear, the case we have been discussing for case #2 has a source with the following characteristics: (I was assuming type II PDC, but I don't think that changes the argument).
1) It emits counter-propagating beams of paired (i.e. time-coincident) photons A & B that are NOT entangled
I don't think such a source has been created. I believe that the type I PDC with only a single crystal produces a pair of photons with a single, known polarization relationship (i.e. |HA>|HB>). In other words, every pair of photons has that relationship between their polarizations. If you choose a different orientation for the crystal, you could also get all pairs having |VA>|VB>, but you never get a mixture of the two, so that is not quite the same thing as we were discussing. Right?
As I commented earlier, I don't think a source corresponding to the properties 1-3 can be created without generating entangled photons ... it might be theoretically possible, but I don't think the time coincident property in point 1 can be guaranteed unless the photons are generated in the same process, and are therefore entangled.
miosim has an incorrect idea of what an EPR state is, which is leading to the problem here. We will need to assist in him gaining this understanding.
miosim: The EPR state is defined as follows: "if, without in any way affecting Alice, you can predict an outcome of any (polarization) measurement on Alice with certainty..." Does this make sense to you?
In other words: if the polarization is known, then you cannot have the EPR state. (Well, I guess you could if we lived in a universe with different physical laws.) That is because when you have HH>, for example, you do NOT have H'H'> except where H' is either V or H. So, at H' = 45 degrees, there is only random correlation between Alice and Bob. Obviously, in such case you cannot predict Alice's outcome with certainty. You would just be guessing, and that is not what EPR specified as being an element of reality.
DrChinese said:
… The EPR state is defined as follows: "if, without in any way affecting Alice, you can predict an outcome of any (polarization) measurement on Alice with certainty..." Does this make sense to you?
This is the deterministic and as I think the misleading interpretation of EPR. However to defend my point Iit may take a separate thread. Instead I will refer to J. Bell’s “Bertlmann’s Socks and the nature of reality” where he mentioned that “… There is a widespread and erroneous conviction that for Einstein … determinism was always the sacred principle….”
It is why I prefer to use the interpretation of EPR as it was stated in the original paper (1935) according to which correlated particles after separation:
“… are no longer interact, no real change can take place in the second system in consequence of anything that may be done to the first system… thus it is possible to assign two different wave functions… to the same reality …”
