Can Gravity Be Used to Rotate Pulleys?
The discussion revolves around the feasibility of using gravity to rotate a system of pulleys, as proposed by the initial poster. The scope includes conceptual reasoning about mechanical systems, force analysis, and critiques of the proposed design.
  • The initial poster describes a system of pulleys where gravity is applied to a stationary plate, which in turn affects the rotation of the pulleys.
  • Some participants argue that the reasoning is flawed, particularly regarding the application of forces at the contact points of the pulleys, suggesting that a free body diagram is necessary for clarity.
  • Others express confusion about the initial poster's intentions and the mechanics of the proposed system, questioning the validity of the design.
  • Several participants assert that the proposed system resembles a perpetual motion machine, which is fundamentally flawed due to the conservation of energy principle.
  • Critiques include the misrepresentation of forces acting on the pulleys and the neglect of additional weights from the pulleys and the stationary plate.
Participants generally disagree on the validity of the initial proposal, with multiple competing views on the mechanics involved and the feasibility of the design. No consensus is reached regarding the effectiveness of using gravity in this manner.
Limitations include potential misunderstandings of mechanical principles, assumptions about the forces acting on the pulleys, and the lack of a detailed analysis of the proposed system's mechanics.
Jigar111
Cross section of pulley1, pulley2 , pulley3 and pulley4 are as shown in figure. Centres of Pulley 1 and pulley 2 are placed on same horizontal line. Centres of pulley 1 and pulley 2 are fixed. Pulley 1 and pulley 2 can rotate about their centre. Centres of pulley3 and pulley4 are also placed on one horizontal line. Pulley 3 and pulley 4 can also rotate about their centre. Centre of pulley 3 and pulley4 are joined with one stationary plate.Pulley 3 and pulley4 are simply supported on pulley1 and pulley2.Now we apply some load or weight on stationary plate. Finaly this force is applied on pulley 1 and pulley 2 in vertical downward direction because pulley 3 and pulley4 are simply supported on pulley 1 and pulley2. Tengential components of these forces helps to rotate pulley1 , pulley2 , pulley3 and pulley4.Pl visit [crackpot link deleted]
If you are here to learn, great, but be advised that we will not support crackpottery here.
The flaw in your reasoning is simple: force on a single contact point of a pulley can only be along the line connecting their centers. To figure out what the forces are everywhere, draw a free body diagram at each pulley center.
I can't even tell what he is trying to do here.
It appears to me that he thinks that since weight acts straight down while the line of force between the touching pulleys is at an angle that there is a force component at the contact point of the pulleys, tangential to them. The error is drawing a fbd (if you can call it that) that shows the weight acting from the edge of the pulley instead of its center.
Regardless, any 2nd-grader playing with Legos could tell you this won't do anything.
Hi Guys,
And that ain't the only error! He also labels those forces as each mg/2 (so he is obviously not accounting for the weight of pulleys 3 & 4 and the stationary plate that conjoins them).
Regardless, any 2nd-grader paying with Legos could tell you this won't do anything.
Sure enough... but I too would like to know just exactly what problem he thinks he is solving with this Rube Goldberg special?
Rainman
It looks like the basis for a fairly decent printing press... :rolleyes:
Just another version of the classic counterweighted perpetual motion machine. Works as well as any other.
See Gardner D. Hiscox's "970 Mechanical Appliances and Novelties of Construction" Copyright 1904.
  • · Replies 48 ·
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 27 ·
11K
  • · Replies 16 ·
