Can H/He Mixtures Safely Power Lighter-Than-Air Crafts?
  • Thread starter Thread starter DaveC426913
The discussion revolves around the feasibility of using hydrogen and helium mixtures to power lighter-than-air crafts, focusing on the required gas mix for safety and buoyancy. Participants explore the potential for reducing the volume of gas needed while considering the risks associated with hydrogen's flammability.
  • One participant inquires about the size of the envelope needed for a lighter-than-air craft and the potential for gas mixtures like H/He to reduce volume.
  • Another participant notes that while helium is inert and safe, hydrogen is explosive but offers greater lift potential.
  • Concerns are raised about the mixing of hot air with hydrogen, suggesting it may not be a viable option.
  • Some participants discuss the lifting capabilities of helium compared to hydrogen, with one stating that helium has nearly the same lift as hydrogen, while another challenges the claim of hydrogen providing four times the lift.
  • There are mentions of regulations regarding the storage of hydrogen gas, indicating potential safety concerns in certain areas.
  • A participant provides a buoyancy calculation to illustrate the lifting capacities of hydrogen and helium, arguing that the difference in lift is minimal and questioning the practicality of pursuing a gas mixture for significant volume reduction.
  • Discussions also touch on the lower explosive limit of hydrogen and its implications for safe gas mixtures, with one participant expressing skepticism about the feasibility of any hydrogen mixture being safe.
Participants express differing views on the safety and practicality of using hydrogen in mixtures with helium. While some acknowledge the potential for lift, others emphasize the risks associated with hydrogen's flammability and question the viability of achieving a safe gas mixture.
Participants reference various technical terms such as "lower explosive limit" and discuss the historical context of helium use in airships, indicating a complex interplay of safety, cost, and buoyancy considerations that remain unresolved.
DaveC426913
2025 Award
I've been playing with an idea for a lighter-than-air craft, and I'm trying figure out how large an envelope it might need to be to hold its own weight plus one person aloft. Have there been any advances in gas mix that can reduce the volume?
I've been reading a little about mixes, such as H/He or He and hot air, but not a lot of facts about it.
Has there been any study done on the H/He mix required to make a relatively safe non-explosive mix?
Well Helium is inert and therefore totally safe, Hydrogen on the other hand can be disatesterous explosive, but has approximately 4 times the amount of potential lift.
Mixing hot air with hydrogen sounds like a non runner to me.
Hot air plus helium might be a nice low risk idea though.
Yeah, He is expensive, and not as buoyant as H. I was reading some Arxiv about lower flash point and upper flash point or some such terminology - how much He you'd need to mix with H to make it nonexplosive.
Actually He is has nearly the lift of H2. He is monatomic and H2 is diatomic so, at worst it has half the lifting ability. But I seem to recall the US Navy found it is much better than this (see reference below, indicates He has 90% of the lift of H2). Prior to WW II the US had lots of He on hand, but withheld it from the Germans to cripple their Airships ability to be weaponized hence the Hindenburg incident.
While He is relatively expensive, the word is relatively. The small amount you are looking for, the difference in cost from hydrogen probably is not significant.
http://en.wikipedia.org/wiki/Lifting_gas
A lot of areas have limits on the amount of H2 gas you can have in one area at given time. IIRC its a fairly small amount here where I live. But this was years ago, I don't know if or how the laws have changed.
rootone said:
...but has approximately 4 times the amount of potential lift.
The lifting capacity of He and H2 are very similar, and not close to a factor of 4. The following example explaines why.
Lets say we have a balloon with exactly one mole of gas inside which will have volume of around 24l. If we fill the balloon with H2, the mass of the gas inside the it will be 2g and if we fill it with He the gas will weight around 4g. It will displace one mole of air, which has a weight of around 29g. The boyancy of the H2 balloon will be:
29g-2g = 27g
and the He balloon will have a buoyancy of
29g-4g = 25g.
The difference between the lifting capacity between the He and the H2 balloon is:
(4g-2g)/25g = 8%
...which is far from the factor of two stated in the quote.
If we could "invent" a gas with a weight of 0 the increase in the lifting capacity would be the weight of the helium which would increase the lift with a factor of: 4/25 = 16%, and the volume of the balloon could be reduced by the same amount. 16% is so little, that I do not think it is worth the effort. To do better than that, you need a stuff with a negative mass, and if someone can come up with that, I think they are sure of getting a Nobel price.
H2 is easy to produce and therefore cheap, but has the option of going "Hindenburg", whereas He is difficult to produce as it is inert. There may be a point in dissolving H2 to below a combustable consentration with He to reduce the cost of the gas, but lift wise, there is little point in doing it. Likewise reducing the already low density of He by heating it, makes only a little increase in lift, and is likely not to be worth the energy cost.
The buoyancy calculation is pretty straightforward, Dave -- have you tried it?
For mixing, look into the "lower explosive limit" of hydrogen. That would be a good starting point for determining the highest fraction of hydrogen allowable. It isn't perfect because the oxygen is external and only mixes in the event of damage, but it should provide a safety factor (however, I'm not going to look it up for you, but if I remember correctly, it is pretty low).
Yeah it's less about the buoyancy and more about the mixes I'm asking. Wondered if the flammability problem had been "solved" recently.
well originally you asked:
so It was natural to think that that was what you were what you were looking for. As my previous post suggests, that is probably not possible. If you want to reduce the volume significantly, I think the way to go is to reduce the weight of the balloon, not the gas inside it.
I'm not sure if you looked up the LEL for hydrogen, Dave, but i checked and as I remembered, it is very low. So I would say that no mixture involving hydrogen will be feasible/safe at any concentration.
  • · Replies 24 ·
  • · Replies 47 ·
12K
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 59 ·
