volodymyr379
- 4
- 0
- Homework Statement
- In all the sources, I've encountered, it is just stated that if you connect the plates of a capacitor by a wire, then the current from one plate will start to flow to another. However, if the plates of my capacitor are large, then, to a good degree of approximation, I can assume that they are infinite. In this case, the nonzero electric field will exist only between the capacitor plates, which means that no force will act on the electrons inside the wire. The electrons located at the surfaces of the capacitor plates will be "held" by the electric field between the plates. This brings me to the question of why charge will flow from one plate to the other when there is no force acting on the electrons?
- Relevant Equations
- E = sigma/epsilon 0 - the magnitude of the electric field between the infinite plates, sigma - surface density of the charge, epsilon 0 - vacuum permittivity.
E = 0 everywhere else.
I would be grateful if someone could explain where my reasoning or assumptions are wrong.
