Can I calculate the flow rate of a compressed gas from pressure?
The discussion revolves around calculating the flow rate of a compressed gas, specifically helium, from a gas tank at 50 bar filling a container to 6 bar. Participants explore methods for determining flow rate using pressure and temperature measurements, as well as the implications of using the ideal gas law in this context.
  • Experimental/applied
  • One participant suggests using the perfect gas law (PV=nRT) to calculate the change in moles of gas over time to derive mass flow rate.
  • Another participant emphasizes the need to monitor both pressure and temperature during the filling process, noting potential adiabatic cooling effects.
  • There is uncertainty about whether the temperature will stabilize quickly or continue to change due to increasing pressure in the vessel.
  • A later reply questions the accuracy of the proposed method and suggests that direct measurement of flow rate would be more reliable.
  • One participant mentions the decision to use a flow meter and pressure transducer, acknowledging the cost implications of needing multiple units.
  • Another participant supports this decision, highlighting the long-term benefits of investing in proper equipment despite initial costs.
Participants express differing views on the accuracy of using the ideal gas law for flow rate calculations, with some advocating for direct measurement methods. There is no consensus on the best approach to determine flow rate accurately.
Participants note the importance of monitoring both pressure and temperature, but there are unresolved questions regarding the stability of temperature during the filling process and the accuracy of the proposed calculations.
men5j2s
TL;DR
If I am using a pressure transducer to determine when a vessel has been filled to 6bar, can I use the information I gain from it to derive the flow rate mathematically?
I am using a compressed gas tank to fill an otherwise empty container, The gas tank is around 50bar and the container will be filled to 6bar.
If I am using a pressure transducer to determine when the container has been filled to 6bar, can I use the information I gain from it to derive the flow rate mathematically?
If not, how can I determine the flow rate whilst filling?
I'll be using helium for this
Welcome to PF.
If you have P and T, then you can use the perfect gas law PV=nRT to calculate the change in n (proportional to mass) between two time intervals.
anorlunda said:
Welcome to PF.
So I can obtain the pressure in the vessel that I'm filling at t=0 (1atm as its empty), then Pressure at t=1s, 2s, 3s...etc (likely to be in millisecs) and and use the mass in grams (derived from the mols of helium as given by the ideal gas law) to work out a mass flow rate in kg/s (m-dot).
Pressure will be constantly increasing, and there will be an initial drop in T for sure (adiabatic cooling?) so i will need to monitor temperature and pressure of the vessel throughout the filling to get an accurate measure?
Or can I assume that after a couple of milliseconds, the temperature will have stabilized to whatever the temp of compressed helium is?OR... will this be constantly changing due to the increasing pressure in a fixed vessel?
Thank you for nudging me in the right direction, I'm confident this can be done experimentally now, I'm just trying to understand which sensors I will need (thermo-couple and a pressure transducer so far) and where abouts I need to place them (at the mouth of the vessel i think).
You needed both P and T.
I would not call this method accurate. If you need accurate flow rate, then measure it directly.
I've decided to use a flow meter and pressure transducer, but this is going to be costly as I need 5 of each :(
You have made the right (if costly) decision and it will be money well spent. Building a poor system to save money up front will in the long run probably not be a savings at all, when it creates operational problems and costs more later to remove and replace it with the correct equipment to fix the problem.
Unfortunately, this happens often when there is pressure to keep cost low when building a new facility; and, afterward the system operators have to deal with the problems it creates and, in some cases, having to replace the problem components in the system.
18K
