Can I Modify My Printer PCB Board to Run Multiple Stepper Motors?
  • Thread starter Thread starter happyuser123
    Board Pcb
The discussion revolves around modifying a printer PCB to control multiple stepper motors using a single signal from an existing microstepping driver. Participants explore the feasibility of this modification, including technical challenges and potential solutions.
  • One participant seeks guidance on modifying the Allegro A3977 Microstepping Driver to control two additional stepper motors from a single signal.
  • Another participant suggests checking the wiring configuration of the existing stepper motor and recommends using an oscilloscope or motor specs to understand pin relations.
  • A participant inquires about powering the additional motors and integrating a second driver for the new stepper motor.
  • One participant requests a diagram to clarify the proposed modifications for better understanding.
  • Another participant emphasizes the need for an economical solution and requests a list of necessary components for the project.
  • A later reply proposes replicating the existing driver circuitry to fan out control lines to new chips as a potential solution, while also suggesting the design of a unity gain H-bridge current amplifier as an alternative approach.
Participants express various ideas and suggestions, but there is no consensus on the best approach to modify the printer PCB or the specifics of the implementation.
Participants mention the complexity of the existing driver and the need for additional information from the motor datasheet, indicating that some assumptions and details may be missing from the discussion.
happyuser123
Hi,
I have a epson c88+ printer, I am trying to modify the Allegro A3977 Microstepping Driver, to move the incoming signal for the stepper motor and send it to 2 additional stepper motor drivers, so that I can run 2 stepper motors off that same signal.
I have little experience in this field and I would greatly appreciate your kind help and support in guiding me true this project.
Thanks in advance!
Welcome to PF.
From the pic it looks like 4 wires going to the stepper.
Is one pin connected to the ground plane/Vcc or do all 4 go to the IC.
You probably need an oscilloscope to check the pin relations when operating or you might get the same info from the stepper motor specs if you have that.
In the first case you can probably use three transistors as switches.
in the later you will probably need to use two pins to drive H-bridges.
Hi,
the stepper motor that's now connected is this: http://www.shinano.com/xampp/docs/SST41D.pdf
Also, how would I power the motors? and add that second driver for the second new stepper motor??
If it would be possible for you to draw a quick diagram, so that I can understand your suggestion better, that would be extra greatly appreciated!
Thanks in advance for everyone that's so kind to help me with this project!
I found the diagram for the driver that I am trying to switch the signal from/currently on the board:
http://www.allegromicro.com/en/Products/Part_Numbers/3977/3977.pdf
I am looking for the most economocal option for the project.
I would also greatly appreciate if you can please also list everything else I will need for this to work.
Thanks again!
Ok, That's fairly complicated.
I suspect the simplest solution would be to get a couple more of these chips, replicate the chip local support circuitry, and fan out the original control lines to the new chips.
The other option looks to be designing a unity gain h-bridge current amplifier as this does not look like simple on/off step switching. Page 41 of the motor datasheet probably has more info on this, but you didn't include that page.
Good luck.
24K
