Can I Safely Grow Microorganism Cultures for Microscope Observation at Home?
  • Thread starter Thread starter TylerH
    Fun Microscope
The discussion centers around the safety and methods of growing microorganism cultures at home for microscope observation. Participants explore various approaches to cultivating motile microorganisms in water, while also expressing concerns about potential dangers associated with growing certain bacteria.
  • Experimental/applied
  • One participant expresses a desire to grow motile microorganisms but is concerned about the safety of cultivating potentially harmful bacteria at home.
  • Another suggests using a fistful of cut grass or hay in water as a starting point for growing microorganisms.
  • Some participants propose using topsoil, yeast, stagnant water, or even moldy bread as sources for microbial growth, emphasizing the hardiness of microbes.
  • Concerns are raised about the chemicals in tap water, with recommendations to use rainwater, pond water, or distilled water instead.
  • One participant describes a method involving filtered water, dry grass, soil, and a shaded environment to cultivate microorganisms, noting that the ecosystem will evolve over time.
  • There are suggestions to monitor changes in the microbial population over weeks, with observations of bacteria and water fleas mentioned.
  • Safety precautions are discussed, including the use of gloves and disinfectants when handling cultures and equipment.
  • Another participant encourages documenting the process with pictures to aid in identifying the microorganisms observed.
Participants generally agree on the feasibility of growing microorganisms at home and share various methods, but there is no consensus on the best approach or the safety of specific practices. Concerns about potential dangers remain unresolved.
Participants mention various assumptions about the conditions necessary for microbial growth, such as the importance of avoiding chlorine in water and the role of organic material in sustaining cultures. There are also references to the evolving nature of the microbial ecosystem over time.
This discussion may be useful for hobbyists interested in biology, educators looking for hands-on experiments, or anyone curious about microbiology and home experimentation.
TylerH
Hi, so I have a little background in biology. I took AP bio in HS and got a 5 and really enjoyed it along the way.
I got a microscope for my own amusement and also to maybe spark an interest in my little brother.
What I'm having trouble with is finding good densities of moving microorganisms. I though motile microorganisms would be the best place to start, because I've always found them to be the most mind blowing part of simple bio.
I'm interesting in growing cultures in water to get some interesting stuff to look at, but first I want to inquire on the danger of doing so. I don't want to grow some deadly bacteria in my house.
Also, if it is safe, what should I put in the water to aid in growth? Will normal cooking sugar work? Should it be in sunlight? And how long for optimal results? (Conceivably, after a certain period when density would peak, I'm guessing things will start dying.)
Biology news on Phys.org
Form my young days - fistfull of a cut grass (or hay) in a glass of water should be a good start.
You are only limited by your creativity: put some topsoil in water to let the microbes swim free; get some yeast from the grocery store and add water; find some stagnant water puddle outside; cut off that moldy spot on bread/cheese; etc. etc. Microbes are incredibly hardy and tolerant of a wide range of physical conditions.
Tap water has a variety of chemicals added for safety- chlorine, fluoride, etc. that may kill the microbes. Use either rainwater/pond water/distilled water (from the grocery store). It may be helpful to add small amounts of sugar and salt, and don't worry about creating a 'superbug'- those appear when antibiotics are added to the culture.
TylerH said:
What I'm having trouble with is finding good densities of moving microorganisms. I though motile microorganisms would be the best place to start...
What you need is a pond and then you get pond water. You can make you own pond on a jar of small aquarium. You can go all out and buy an air pump and air stones. These create a vertical current and gas exchange. Or just use a a 1 qt mason jar.
Simply add filtered water (no chorine) and then a small about of dry grass and soil. some small sticks and a bit of sand and dirt to make a 1/8 inch layer on the bottom. Place it in shade but still where some light hits. You do NOT want the sun to heat the water
At first the water is nearly sterile but every day sample the dirt near the bottom with a tiny pipet and put a drop or two of the water and dirt on a slide, cover it and look at 100x or 400x.
Note what you find. It will change over several weeks. Some populations will explode and soe will crash. no need to add nutrients. the decomposing grass and so on will add enough. In time you will see green algae which is a sign of a healthy eco system
Air stones keep the system for becoming anaerobic. Nothing wrong there except it smalls bad. A thick layer of mud will grow anaerobic stuff too.
When I did this at first I saw bacteria and it took a month before the water fleas appeared. They, I think are top of the food chain (?) and need food to multiply first. Later I see dead ones in the soil with smaller microbes feeding on the remains inside the shell.
Make up two or more jars each with different stuff. Some from outdoors type samples, some with dirt from vacuum clearer bag. Get a thermometer and PH papers and record what's going on.
This can't kill you unless you start to isolate and culture un-known critters. Then just be careful. But even with the open jars use gloves, wipe areas with alcohol. Drop all the used slides and beakers and pipets in the "to be cleaned" jar that has disinfectant solution (I just use a drop of dish soap) Months f bad or no cleaning will create a mess so treat the area like a real lab.
Sounds like fun. My last final is Friday, so I'll start over the weekend. I like how this is a long term, evolving project with multiple aspects of biology involved. Not only the "ooo look cool little cell things" that I was originally intending, but also a good example of ecology. Thanks for the suggestions.
Yep, great idea.
enough talk, you need to take pictures, so we can identify what you see
18K
  • · Replies 35 ·
  • · Replies 29 ·
