Can I safely install 1.5 GB of RAM on a computer that can only handle 1.0 GB?
  • Thread starter Thread starter Problem+Solve=Reason
    Ram
Installing 1.5 GB of RAM in a computer that is factory-rated for only 1.0 GB raises concerns about compatibility and potential hardware limitations. Users suggest that a BIOS update might help, but the motherboard likely has restrictions that only allow for 512 MB per slot, making the 1 GB stick unrecognizable. If the motherboard is limited to 512 MB DIMMs, the new memory may not function at all, and there are warnings about the risk of damaging the motherboard if incompatible RAM is used. It is advised to test the 1 GB module alone by removing the 512 MB stick, but the consensus is that the hardware constraints may prevent successful installation. Selling the extra memory is also recommended if it proves incompatible.
Installing more RAM than...
Im trying to install 1.5 gb of ram on a computer that the factory says can only handle 1.0 gb. Now, if i try it and it doesn't work then I am out 15% of 93 bucks for a restocking fee (cheap basterds). So I am wondering if anyone has done this before and know someway that it can work. This is not a 1.5 gb stick, but right now i have 512 in and just bought a 1 gb stick. So in total 1.5 gb.
All and any help appreciated...
Tom
Computer science news on Phys.org
A bios update may do it, but other than that, you're probably out of luck.
If it does not work at all, then remove the 512MB module and try using the 1GB module by itself.
I think the motherboard probably has 2 spaces for RAM that are only capable of handling 512MB RAM sticks.
Thats it. Spose to only hold 2 512.
It's probably a hardware impediment. If the board can only handle DIMMs up to 512MB, then the 1GB stick likely won't work at all.
Sell the extra 512MB memory on ebay.
If the hardware only recognizes 512MB per slot, then the new memory may not be recognizable at all by the machine.
I would be careful here. It is possible that certain 512 chips won't work either. It sounds like the chip density is the limiting factor here.
Yah the 1gb chip probably wouldn't even work on its own...
i wonder what happened to the OP
Mobos are programmed to run with a certain amount of everything and set at speeds. It probably won't work, and even if it did it would be very dangerous to run. (fry your mobo.)
  • · Replies 23 ·
