T.O.E Dream
- 219
- 0
If we were to put two relatively small wheels on the side of a motorcycle would it decrease the performance of the motorcycle?
T.O.E Dream said:If we were to put two relatively small wheels on the side of a motorcycle would it decrease the performance of the motorcycle?
This is counterintuitive. Why do you say it is so?YellowTaxi said:(if you took away the inside wheel on the car it would fall inward). In effect a car is always leaning into the curve...
The main reason a car has more grip is that the size of the contact patches are larger on the car. Also if by "generally" you're comparing street cars with a typcial sport motorcycle, the bike has more grip because it uses a softer compound tire, compensating for the smaller contact patch. If you mean racing cars versus racing motorcycle, then the racing cars have better grip.YellowTaxi said:For example a car generally has more grip in a curve than a motorbike has simply because its outside wheel is further out from the centre of mass than it is on a leaning bike.
Jeff Reid said:The main reason a car has more grip is that the size of the contact patches are larger on the car.
Jeff Reid said:Also if by "generally" you're comparing street cars with a typcial sport motorcycle, the bike has more grip because it uses a softer compound tire, compensating for the smaller contact patch.
No, the car is leaning out of the curve. If it takes the curve too fast, it will start to flip; its centre of mass will rise, lifting its wheels and losing traction and skidding.YellowTaxi said:In other words (the more complicated part), the line drawn from the centre of mass of the car to the outside wheel(s) is always 'leaning closer' to the ground than the same line taken from the centre of mass of a motorbike taking the same curve at the same speed. That's always true.So the car is always 'leaning into the curve' more than the bike is.
In fact it has to, otherwise it would flip over. ;_)
YellowTaxi said:Sorry for any confusion dave, but maybe you didn't quite understand what I was trying to say. My fault for not being more explicit, or more articulate.
I mean the car is 'leaning into the curve' because almost all of the grip from a car pushed hard through a corner is generated from its 2 outside tyres. The car is now a 'motorcycle', pretty much balancing all its weight on those 2 outside tyres. OK? It's one of the reasons that motor racing is something of an art, the dynamics of the car are constantly changing depending on the situation, and keeping the car on the road takes a lot of skill.
That's one of the reasons I don't agree with Jeff when he says a car has more grip than a bike in a curve because it has 4 tyres etc.. Fact is, in a curve at around 1G, the car is only really using 2 wheels. Apart from that this was probably way off topic
Hope I explained myself properly this time.. (maybe ..).
In some cases, bikes can also out brake cars due to softer compound tires. At Willow Springs 2.5 mile race track, the fast guys can run around 1:28 on stock bikes (like GSXR 1000) with DOT tires. There are few stock sports cars that can match that time. The top race bikes run around 1:20->1:21, back in 2000 when AMA superbike was 1000cc, 1:19.029. Since AMA superbike is now back up to 1000cc again, I assume lap record will drop back down to the low 1:19's again.DannoXYZ said:There are three components to "performance":
1. acceleration
2. cornering
3. braking
When you compare a sport-bike to a sports-car, the bike will only win #1 due to its superior weight-to-power ratio. The car wins in #2 and #3
Because of the round profile, the contact patch on a motorcycle is small compared to a sports car with 250 to 325mm treadwidth, perhaps the overall contact patch area of the 2 tires on a bike is 1/6th or less than that of the 4 tires on a sports car. The bikes generally run softer compound tires than all but the lightest of cars. The Caterham CSR, at < 1400 lbs, is one of the lightest street legal cars, and is a somewhat popular track car in the UK and Europe.YellowTaxi said:I don't think that's true. I think the size of the contact patch on a motorbike is huge when taken in proportion to the weight of the vehicles.
Jeff Reid said:Because of the round profile, the contact patch on a motorcycle is small compared to a sports car with 250 to 325mm treadwidth, perhaps the overall contact patch area of the 2 tires on a bike is 1/6th or less than that of the 4 tires on a sports car.
If bikes have to resort to using softer, grippier tye compounds to keep pace with the cars through the curves then you're agreeing with my statement that with all else being equal, the car will have more grip in the curve than the bike. In other words the bikes have to 'cheat' to keep up. QED...The bikes generally run softer compound tires than all but the lightest of cars. The Caterham CSR, at < 1400 lbs, is one of the lightest street legal cars, and is a somewhat popular track car in the UK and Europe.
DannoXYZ said:Coefficient of friction for rubber changes with vertical loading in a non-linear fashion. I'll try to find a chart of CoF versus vertical loading. I think it was in one of Carroll Smith's "To Win... " series.
DannoXYZ said:No, a car doesn't just use 2 wheels in cornering. While it does have more weight & therefore traction on the outside tyres than the inside, but the insides still do contribute to cornering. The lateral weight-transfer is a function of COG-height and track-width.
There is precisely 100% load transfer (not weight transfer btw) just when the car tips onto its side.At no point in time is there 100% weight-transfer to the outside wheels..
Rather than speaking in all-or-nothing, black & white qualitative terms, why don't you give some equations and calculate the exact lateral weight-transfer of a 911 then? I have yet to see any bike that can pull 1.4x higher cornering-G than a 911. Here's one to get you started: f=muYellowTaxi said:grief that's obvious. But roughly speaking almost all the grip is coming from the 2 outside tyres at and above 1G.
By your logic, if we've got a go-cart with zero suspension travel and zero-lean at 1.5g, does that mean it has zero lateral weight-transfer in cornering? Meaning its outside tyres contribute 50% to total cornering grip?YellowTaxi said:Weight transfer is due to body roll which we are not considering in this debate, and in any case contributes next to nothing to the change in the coeficient of friction anyway.
This depends on the tire construction (sidewall stiffness, radial versus bias ply, ...) and the rubber compound used. Wiki has a small article:YellowTaxi said:coef of friction is proportional to load ^ -0.2.
Those cars are tracked prepped cars, not stock sports cars, and most of those times are similar to the 1:27->1:28 that the fast guys get on high end stock sport bikes at Willow, not the 1:19 to 1:20 that 1000cc racing bikes get there. The racing bikes run about the same lap times as SCCA GT3 class cars.DannoXYZ said:results from the Open Track Challenge.
A Caterham CSR 260 has a weight bias of 49% front, 51% rear without the driver, and with the driver virtually sitting directly above the rear axle, the actual weight bias is further rearwards. A CSR 260 with stock Avon CR500 tires pulls 1.05 g's in turns. With 13 inch wheels and bias ply racing slicks, the CSR pulls 1.4 to 1.5g's, since it can share the same very soft compound racing slicks used on light (< 1500 lbs) non-downforce race cars like the Formula Ford.YellowTaxi said:In corners at 1G and above the car's only really using the 2 wheels on the outside. Caterham is only popular with people who can't drive rear or mid-engined cars. Real sports cars have most their weight on the rear end to keep the vehicle more agile.
I'm trying to compare like-for-like. As mentioned before, stock sportsbikes are much closer to their race cousins than streets cars are to racecars. So a track-prepped street car using soft tyres is more similar to a stock sportsbike.Jeff Reid said:Those cars are tracked prepped cars, not stock sports cars, and most of those times are similar to the 1:27->1:28 that the fast guys get on high end stock sport bikes at Willow, not the 1:19 to 1:20 that 1000cc racing bikes get there. The racing bikes run about the same lap times as SCCA GT3 class cars.
That was part of my point.DannoXYZ said:I'm trying to compare like-for-like. As mentioned before, stock sportsbikes are much closer to their race cousins than streets cars are to racecars.
I'm aware that all out race cars, especially ones with downforce, are much faster than the all out race bikes, which are closer to the GT3 cars, dependinng on the track. Even without the downforce, the race cars have a lower load factor per unit area of the contact patch on the tires (much wider tires and 4 of them instead of 2), and they can dirft without risk of low or high siding.race cars versus race bikes
Beaten by a Champ Car in 2007:Laguna Seca F1 car: 1:06 Ricardo Zonta (Toyota)
YellowTaxi said:Jeff, you seem to forget that a car can't use all 4 tyres in a curve. That would be against the laws of physics as I'm sure you're aware. In corners at 1G and above the car's only really using the 2 wheels on the outside. So it's just a very heavy motorbike really. A porsche 911 for example weighs around 5 or 6 times that of a sport motorbike, and all of that weight is is on 2 tyres when its pulling 1G or more.
Same results on a real handling-oriented tracks like Laguna Seca (fastest cars are 20-seconds faster than fastest bikes):
SuperBikes: 1:26 Tommy Hayden
GP bikes: 1:23 Dani Pedrosa
250 SuperKart: 1:24 Eddie Lawson (compare with 800cc GP or 1000cc SuperBikes)
Jeff Reid said:This depends on the tire construction (sidewall stiffness, radial versus bias ply, ...) and the rubber compound used. Wiki has a small article:
http://en.wikipedia.org/wiki/Tire_load_sensitivity
So what, it's a very light car so it has more grip. Because grip is roughly prop to load^-0.2.A Caterham CSR 260 has a weight bias of 49% front, 51% rear without the driver, and with the driver virtually sitting directly above the rear axle, the actual weight bias is further rearwards. A CSR 260 with stock Avon CR500 tires pulls 1.05 g's in turns. With 13 inch wheels and bias ply racing slicks, the CSR pulls 1.4 to 1.5g's, since it can share the same very soft compound racing slicks used on light (< 1500 lbs) non-downforce race cars like the Formula Ford.
That simpliy isn't true Jeff. Tipping is a big problem on European Touring cars which are race cars built from stock, street legal cars like the Audi A4. The driver sits at low as possible in his specially low mounted seat, and the wheels are mounted something like 5 inches outside their normal position just to try and keep the car from tipping over. In other words they're cornering at around 100% load transfer. Occasionaly they do indeed lift both inside wheels or even flip. That's 100% load transfer, no doubt about it.The center of mass on virtually any sports or race car is low enough and track (distance between left and right tires) is wide enough that the car isn't tranferring almost all of its weight to the outside tires due to tire grip, as this could end up with car rolling over on it's side.
YellowTaxi said:that wiki article you quote says that coef is proportional to load ^-0.2
It states a range:YellowTaxi said:that wiki article you quote says that coef is proportional to load ^-0.2
What I stated was that cars have larger contact area, lower loading per unit area, but that sport bikes generally have stickier tires than sport cars which compensates in stock sport bike versus stock sports car comparasons. Once you're running DOT tires on both, the cars have an advantage.You keep saying that bikes can pull a lot of G, but only on very sticky tyres.
xxChrisxx said:Where?
Jeff Reid said:It states a range:
YellowTaxi said:It says the lateral force, also known as friction, is prop to load^0.8
well, Friction = Coef x Load
.'. Coef of friction is prop to Friction/Load.
ie [load^0.8]/[load]
ie Coef is prop to load ^ -0.2
OK ?
You said said the bike has around 1/5 or 1/6 the contact patch area of a car tyre.
And I said the car has around 5 or 6 times the weight of the bike all balancing on 2 wheels just like a bike. Therefore the 'loading per unit area' is the same...
Mentioning that adding stickier tyres gives more grip doesn't prove anything - by definition it's obvious anyway.
Jeff Reid said:Note, the guys who race modded Porsche 911's, generally run 18 inch wheels, and these are harder compound tires, that won't pull 1.5 gs in turns. If such tires did exist, and 1.5g's did cause 100% weight transfer, then the car wouldn't be safe. Cars generally roll because they get sideways, and dynamic compression forces (perhaps a dip or curb) on the leading side of the car are enough to create enough grip to roll the car. This amount of dynamic force isn't possible with normal turning. Most of the time, cars will spin without rolling.
YellowTaxi said:Jeff that's funny. Modified Porsches can pull more than 1.5G and they're modified for precisely that reason - they would would tip if they weren't modified. Even a stock porsche 911 will pull well over 1G on a race circuit, since there's more grip on a racing track than out on the street.
ps. I don't know why you sent me a pm claiming that only rally cars on rough surfaces can tip in a curve, and some other such nonsense. Was that a joke ? There's plenty of videos on the net showing cars like BMW M3's tipping purely due to G forces. I have videos of my own where cars tip purely due to pulling sufficient G to lift the inside wheels. This discussion is getting stranger with every post..
As to the other posters , if you're so smart and so disbelieving of what I say, then I suggest you go work it out for yourselves and show your reasoning on here. Instead of chanting childish "Oh no it isn't"s. You people should probably be in a pantomime somewhere.
http://en.wikipedia.org/wiki/Pantomime
What I meant was stock 3000+ lb Porsche modified for track use with suspension tuning and DOT tires, as opposed to a FIA racing Porsche at 2500lbs. Note also that lateral grip decreases with load transfer. A race car might be able to pull 1.5g's with a 50% load transfer (cg height = 1/3 track width), but a stock car with with a relatively higher CG won't be able to achieve that because the higher load transfer reduces the effective grip.YellowTaxi said:Modified Porsches can pull more than 1.5G and they're modified for precisely that reason
