Can Non Realism = Non Deterministic Hidden Variable Theory
  • Level: Graduate
  • Thread starter Thread starter Point Conception
    Realism Theory Variable
33 replies · 5K views · last reply
morrobay said:
So λ (dependent on θ2 - θ1) in this case involves not only all information of past variable but also involves the physical interactions during measurement: λt0 (ontic) , settings a and b, λ t1 (observed)
Two things that I don't understand about that one sentence: First, [itex]\lambda[/itex] is supposed to be something that is "set" in the backwards light-cone of the two measurements--in other words, at the moment the twin pair is produced. [itex]\theta_2 - \theta_1[/itex] is a fact about the measurement process, and is definitely NOT in the backwards light-cone. That quantity can be changed in-flight, right before the detection event.
The second thing I don't understand is how [itex]\theta_2 - \theta_1[/itex] is a local quantity. It depends on two distant quantities. By definition, I think that would be nonlocal.
When you say that λ is "set" in past light cone, produced at entanglement of pair, are you implying that λ does not interact with observable during measurement process ?
Ie ( λt0 + ontic unmeasured particle ). ---> interactions with detector setting a or b at A or B ---> ( λt1 + observed particle measurement.)
Maybe someone can elaborate on exactly how λ and particle interact physically starting from moment pair is produced ,
during measurement interaction , to observed outcome.
And I redefined contextual hidden variable to depend on experimental setting ,θ, at A or B for locality .And as you say detector angle can be changed in flight. So whether λ is a function, outcome ± 1 or outcome is stochastic I cannot see how counter- factual definiteness could apply.
So again is a local , non realistic hidden variable theory possible from the above : That can have perfect correlations when detectors are aligned and also predict inequality violations, Sqm = 2√2 when detectors at A and B are not aligned ?
The outcome at each detector is assumed to be a function of the variable [itex]\lambda[/itex], which is set at the moment of pair creation, and the detector setting.
There is a joint probability function, [itex]P(\theta_1, \theta_2, A, B)[/itex] which is the probability that Alice gets outcome [itex]A[/itex], and Bob gets outcome [itex]B[/itex], given that Alice's device has setting [itex]\theta_1[/itex] and Bob's device has setting [itex]\theta_2[/itex].
To explain this joint probability distribution in terms of local hidden variables would be to write it in the form:
[itex]P(\theta_1, \theta_2, A, B) = \sum_\lambda P(\lambda) P(\theta_1, A, \lambda) P(\theta_2, B, \lambda)[/itex]
where
  • [itex]P(\lambda)[/itex] is the probability that the hidden variable has value [itex]\lambda[/itex]
  • [itex]P(\theta_1, A, \lambda)[/itex] is the probability that Alice gets outcome [itex]A[/itex] given the hidden variable has value [itex]\lambda[/itex] and her device has setting [itex]\theta_1[/itex]
  • [itex]P(\theta_2, B, \lambda)[/itex] is the probability that Bob gets outcome [itex]B[/itex] given the hidden variable has value [itex]\lambda[/itex] and his device has setting [itex]\theta_2[/itex]
So, yes, the outcome for Alice is assumed to depend on some kind of interaction between [itex]\lambda[/itex] and [itex]\theta_1[/itex], and the outcome for Bob depends on some kind of interaction between [itex]\lambda[/itex] and [itex]\theta_2[/itex]. But [itex]\lambda[/itex] has nothing to do with [itex]\theta_2 - \theta_1[/itex].
We assume a probability distribution of the form:
[itex]P(\theta_1, \theta_2, A, B) = \sum_\lambda P_A(\lambda) P_B(\theta_1, A, \lambda) P(\theta_2, B, \lambda)[/itex]
Now, we use the fact that if [itex]\theta_1 = \theta_2[/itex], then the correlation (or anti-correlation) is perfect. So we have, for perfect anti-correlation:
[itex]P(\theta, \theta, A, A) = \sum_\lambda P(\lambda) P_A(\theta, A, \lambda) P_B(\theta, A, \lambda) = 0[/itex]
There is no way to have a sum of nonnegative terms add up to 0 unless each term is 0. So we conclude:
[itex]P_A(\theta, A, \lambda) P_B(\theta, A, \lambda) = 0[/itex]
(for all values of [itex]\lambda[/itex] with nonzero probability).
This implies
[itex]P_A(\theta, A, \lambda) = 0[/itex] or [itex]P_B(\theta, B, \lambda) = 0[/itex]
This is true for every value of [itex]\lambda[/itex] and [itex]\theta[/itex]. That means that for any value of [itex]\lambda[/itex], there is some angle [itex]\theta[/itex] such that either it is impossible for Alice to get result [itex]A[/itex] at that angle, or it is impossible for Bob to get result [itex]A[/itex] at that angle. So, if Alice gets result [itex]A[/itex] at some angle [itex]\theta[/itex], then it is DEFINITE that Bob cannot get result [itex]A[/itex] at that angle. That's contrafactual definiteness. It follows from the assumption of local hidden variables and the fact of perfect anti-correlation (or correlation).
