Can one photon trigger two detectors at both slits?
  • Level: Graduate
  • Thread starter Stavros
15 replies · 728 views · last reply
Stavros
Can two independent, non-destructive detectors each record the same single photon at a different slit in every run, while the photon reaches the screen and interference remains?
I would like to understand whether quantum mechanics, and specifically quantum electrodynamics (QED), permits the following experiment.
Proposed setup
Consider an ideal, symmetric double-slit experiment in which photons are emitted one at a time.
Place two separate, spatially localized, independent detectors at the two slits:
Detector A is located at slit A. Detector B is located at slit B.
The requirement is that both detectors produce a distinct, unambiguous, independently recorded detection event during every individual photon run.
In other words, for each single photon, detector A must register an event and detector B must also register an event. Both records must correspond to the interaction of that same photon with the two spatially separated slit regions.
The detectors must be non-destructive: the photon must survive both interactions and continue to a photographic screen behind the slits.
After many repetitions, the screen should still build up the ordinary double-slit interference pattern.
What I am specifically asking
I am not referring to weak traces, weak pointer shifts, or small statistical signals reconstructed from an ensemble of photons. I am asking whether two actual, distinguishable detector records can be produced in every individual run.
Nor am I requiring the detectors to avoid recording a local interaction. On the contrary, the central requirement is that each detector should produce a genuine record of an interaction at its respective slit.
I understand that ordinary which-path measurements generally destroy interference. However, I would like to know whether that familiar result establishes a general impossibility for the more specific arrangement described here, or whether a suitable non-destructive interaction could behave differently.
Questions
Does quantum mechanics, and more specifically QED, permit such an arrangement? If it is possible, can an explicit physical model or interaction Hamiltonian describe how both detectors register the same photon in every run while the photon survives and interference is retained? If it is impossible, is there a rigorous theoretical proof identifying the precise physical constraint that prevents it? Has this exact arrangement already been studied, either theoretically or experimentally?
I am aware of the 2023 paper Unambiguous joint detection of spatially separated properties of a single photon in the two arms of an interferometer. However, I am interested in the stronger requirement of two actual, independent detector records in every individual run, rather than weak-measurement signals obtained statistically over many runs.
I am asking about the physical possibility and its theoretical constraints, not about a particular interpretation of quantum mechanics.
No, this will never happen.
Please give a link.
Please give a link.
Here is the paper:
S. N. Sahoo et al., “Unambiguous joint detection of spatially separated properties of a single photon in the two arms of an interferometer,” Communications Physics 6, 203 (2023).
https://www.nature.com/articles/s42005-023-01317-7
The experiment demonstrates simultaneous weak measurements of two different photon observables in spatially separated arms of a Mach–Zehnder interferometer, using weakly coupled pointers and post-selection.
My question concerns a stronger requirement: two independent detectors, one at each slit, each producing an actual, distinct, unambiguous detection record for the same photon in every individual run, while the photon survives and interference remains.
I understand that the paper does not demonstrate this stronger arrangement. I cited it because it is closely related to the question of jointly detecting properties of a single photon in spatially separated regions.
The term single photon is misleading, it is properties of a single photon..
When a measurement is made then it's state is getting disturbed but you could try to weaking that or use an indirect method.
There are actually two photons involved but more importantly the single photon cannot be considered
a free particle. It is in interaction with the detectors and other devices.
In the end it is in principle impossible to tell if the photon that is getting detected is still the same one as the one that had left the beam splitter.
Yes, and the answer is no, your "stronger requirement" will never happen. For one photon emission you will never get more than one photon detection under the conditions you describe.
No measurement is made at the beam splitter, not even a weak measurement, so "the one that had left the beam splitter" is not even a meaningful concept to begin with.
Is this the problem with the OT's premise:
"The detectors must be non-destructive: the photon must survive both interactions and continue to a photographic screen behind the slits."
Perhaps this not true under all interpretations, but my impression is that the detector "does" have a fundamental interactive role (destructive?) on the photon causing the wave collapse (in some interpretations).
No. The problem is that anything that justifies the term "detector" will register a macroscopic, irreversible result when a photon passes through it, whether the photon is destroyed or not. And if only one photon is emitted, only one such detector can register a detection--meaning only at one slit, not both.
"Wave function collapse", regardless of which QM interpretation you are using, does not require the photon to be destroyed when it is detected. All that is required is, as above, that the detector registers a macroscopic, irreversible result.
I agree that an ordinary absorptive photon detector cannot absorb the same photon twice. However, that is not the type of detector I am asking about.
My question concerns two spatially separated, non-destructive interactions, each followed by amplification using energy supplied by the detector itself. The photon would not have to supply the energy required to produce the macroscopic record.
A non-destructive interaction can, in principle, change a detector's internal state while leaving the photon intact. Therefore, the statement that one photon can produce only one photon-counting event does not, by itself, establish that it can produce only one independent detector record.
I would like to understand the precise physical principle that rules out the latter possibility.
Is the restriction a consequence of locality, energy conservation, the structure of QED interactions, or the requirement that the two records preserve interference? In particular, why must two independent local interactions with the same spatially extended one-photon field be unable to trigger two detector records?
Regarding the 2023 paper, I agree that it does not demonstrate the stronger arrangement I am proposing. To clarify one point raised above: although the source produces an SPDC photon pair, only the signal photon passes through the Mach–Zehnder interferometer; the idler photon is used for heralding. The two pointer shifts are weak-measurement signals reconstructed statistically, not two macroscopic detection records in every individual run.
I am not claiming that my proposed arrangement is possible. I am asking whether there is a rigorous argument showing that it is impossible, beyond the familiar case of ordinary absorptive photon detection.
A single photon is characterized by its distribution of energy, linear and angular momentum, helicity, etc. Are you asserting that there exists, in principle, a detector that can interact with, and thereby detect, the existence of the photon, but without altering any of those properties, thereby leaving the photon unchanged (and thus "intact")? If so, can you cite one or more credible technical references that supports this claim?
Maybe you should read up on the observer problem in QM. Measuring a photon isn't non-destructive, it will collapse the wave function and change future results. This is the heart, the brilliance, of the 2 slit experiment, at least for me.
Yes, it's weird and doesn't really make sense, at least for me.
Thank you. I should clarify what I mean by "leaving the photon intact."
I do not mean that the photon must remain unchanged in every physical degree of freedom. I mean that the interaction must be non-absorptive: the photon must remain in the one-photon sector and continue propagating after the measurement. I fully accept that a QND interaction can produce back-action on other properties of the photonic state, and that this back-action may affect interference.
There is an experimental precedent relevant to this distinction:
E. Distante et al., "Detecting an Itinerant Optical Photon Twice without Destroying It," Physical Review Letters 126, 253603 (2021), https://doi.org/10.1103/PhysRevLett.126.253603.
The authors demonstrated two successive QND detection stages acting on the same propagating optical photon. I am aware that this experiment does not demonstrate two simultaneous detectors at separate slits, nor does it establish that double-slit interference can be preserved in my proposed arrangement.
My question is whether the back-action associated with two spatially separated, local QND interactions necessarily makes the two path components distinguishable, or whether a physical interaction could produce two detector records while preserving their coherence.
I am not assuming that such an interaction exists. I am asking whether there is a rigorous argument showing that it cannot exist.
I understand that measurement changes the quantum state and can affect subsequent results. However, this does not mean that every measurement must destroy the photon.
Quantum nondemolition (QND) measurements provide a counterexample. In 2021, Distante et al. experimentally demonstrated two successive nondestructive detection stages acting on the same propagating optical photon:
I agree that this experiment does not demonstrate my proposed double-slit arrangement. It does, however, show that the general statement that measuring a photon necessarily destroys it is incorrect.
I am not arguing that measurement has no effect on the photon. My question is whether two spatially separated QND interactions, one at each slit, must necessarily destroy the coherence between the two spatial components.
Does Feynman's lecture address this specific possibility, or does it explain the usual which-path measurement and its effect on interference?
A question from a "casual amateur": Is this what happens when light goes through a polarizing filter? Is the act of polarizing a "macro effect" that could be considered a "non-absorptive" detection?
PeterDonis said:
Are you referring to the paper the OP referenced? If so, what specific statements in the paper lead you to believe this?
Yes in the paper they are using a twin photon source for coincidence checking. Indirectly also indicating
the occurence of the other partner photon. You can call it a technicality.
