Can someone explain how they got this?
  • Thread starter Thread starter gvcalamike
    Explain
The discussion focuses on calculating the angular speed of a solid cylinder with a radius of 10 cm and mass of 12 kg as it rolls down a 6 m inclined roof at a 30-degree angle. The conservation of mechanical energy is applied, where the initial potential energy (Ui = 352.8 J) is converted into kinetic energy (Kf). The kinetic energy is expressed as Kf = (3/4)mr²ω², demonstrating the relationship between linear velocity (v) and angular velocity (ω) through the equation v = ωr. The discussion clarifies the conditions under which conservation of energy is applicable, emphasizing the importance of understanding the rolling constraint.
  • Understanding of conservation of mechanical energy principles
  • Familiarity with rotational dynamics and moment of inertia
  • Knowledge of the relationship between linear and angular velocity
  • Basic trigonometry for calculating height from an inclined plane
  • Study the principles of conservation of mechanical energy in physics
  • Learn about the moment of inertia for various shapes, including cylinders
  • Explore the rolling motion equations and the relationship between linear and angular quantities
  • Investigate scenarios where energy conservation applies versus when it does not
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to rotational motion and energy conservation.
gvcalamike
The question was:
A solid cylinder or radius 10cm (.1m) and mass 12kg starts from rest and rolls without slipping a distance L=6m down a roof that is inclined at the angle 30 degrees. What is the angular speed of the cylinder about its center as it leaves the roof?
Step 1: I got the vertical height of the roof: (6.0m)sin 30 = 3m
.: I really don't know when to use the conservation of energy or conservation of mechanical energy, but it seems like most of the problems I've been working use them. Can someone explain when to use it? Nonetheless, I guessed here and here's what I did. Btw, I got the answer right after I got a hint.
Step 2: Going with my guess I did this:
Ki = 0
Ui = mgh = (12)(9.8)(3.0) = 352.8 J
Uf = 0
Okay, here's where I get confused. I can get Kf = 1/2 mv2 + 1/2 Iw2 (w = omega). Then they used:
1/2 mr2w2 +1/2(1/2mr2)w2
So how does 1/2 mv2become 1/2mr2 w2
and 1/2 Iw2 become 1/2 (1/2mr2)w2
I have an idea, utilizing what you have at hand to come up with something, but I don't really understand how they came about.
So Kf would end up being (3/4)mr2w2 and I can solve it from here, but can anyone explain how Kf came about? Thanks
0+352.8 = 3/4mr2w2
hi gvcalamike! :smile:
(have an omega: ω :wink:)
gvcalamike said:
… I really don't know when to use the conservation of energy or conservation of mechanical energy, but it seems like most of the problems I've been working use them. Can someone explain when to use it?
generally, we can use conservation of (mechanical) energy if there's no collision (or jerk) …
so if a body rolls or slides down a hill that curves gently to become horizontal, energy is conserved
but if the hill is straight, so that it meets the flat ground at a "corner", then the body collides with the ground, with a jerk, and energy is lost :wink:
because v = ωr …
this is the rolling constraint, ie the relation between v and ω …
the instantaneous point of contact is stationary, but the c.o.m. is moving with speed v, so as a matter of geometry, the angular speed must be v/r :smile:
  • · Replies 44 ·
