Can someone explain this phenomena?
This discussion centers on the interaction of two like charges moving at relativistic speeds and the forces preventing their collision. Participants clarify that the Coulomb force acts between like charges, causing them to repel each other. The conversation also touches on the concept of observers perceiving the same event differently due to relativistic effects, emphasizing that while they may disagree on the timing and coordinates of events, the occurrence of a collision is universally agreed upon. The Liénard-Wiechert potentials are suggested as a method for analyzing these interactions across different reference frames.
  • Understanding of Coulomb's Law and electric forces
  • Familiarity with relativistic physics concepts
  • Knowledge of electromagnetic fields generated by moving charges
  • Basic understanding of reference frames in physics
  • Study the Liénard-Wiechert potentials for moving charges
  • Explore the implications of special relativity on electric and magnetic fields
  • Investigate the concept of relativistic mass and its effects on particle interactions
  • Learn about the differences in observer perspectives in relativistic scenarios
Physicists, students of electromagnetism, and anyone interested in the implications of special relativity on charge interactions and observer-dependent phenomena.
arda
Can someone explain? When two charge moving as fast as possible , what force is acting on for blocking to collide.I mean if you think you are not moving and you are looking 2 charge which are moving as fast as to near light speed, they must collide each other if charge is not increasing according to relativity.But if you moving with charges they must move away to each other.Which force is acting for blocking to charges collide? or is it possible to can 2 observer see same event differently?
arda said:
Can someone explain?When two charge moving as fast as possible , what force is acting on for blocking to collide.
Are you talking about charges of the same sign?
Why must they collide? Why can they not go about their way without interacting?
Why?
Probably the Coulomb force if the charges have the same sign.
If the charges collide, all observers will agree that there has been a collision. They will disagree about the time and coordinates of the collision.
yes they are same
because of charges will create magnetic field as i derived formula and they will have much mass when they are moving as fast as near light's speed
kuruman said:
Why?
coulumb's force says that same charge push themselves and if you looking at the charge when you the same speed you must see they are not moving so there is no magnetic or gravitational forces.
absolutely
actually this is what i want to learn.how is it possible 2 observer can see same event differently without time
i want to say differently this because of the forces they will disagree each other to there is any colliding exists or not
No. They will not disagree on that. You can just use the Lienard Wiechert potential in any frame to calculate the result and it will be the same
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 31 ·
10K
  • · Replies 61 ·
  • · Replies 36 ·
