Can someone explain this to me?
  • Thread starter Thread starter reesespieces2
    Explain
The discussion focuses on creating a mechanism to make a soda can roll autonomously down a hallway using a spring mechanism, as electric motors are prohibited. The proposed solution involves using a flywheel, which can be spun by a wound-up spring, transferring energy to the flywheel to initiate motion. The user seeks clarification on executing this concept, emphasizing the need for a mechanical solution without battery power.
  • Understanding of mechanical energy transfer
  • Familiarity with flywheel dynamics
  • Basic knowledge of spring mechanics
  • Experience with simple mechanical assemblies
  • Research the principles of flywheel energy storage
  • Learn about spring-loaded mechanisms and their applications
  • Explore mechanical design concepts for energy transfer systems
  • Investigate the construction of simple mechanical toys for practical insights
Students in physics, hobbyists interested in mechanical engineering, and anyone looking to create simple machines using mechanical principles.
reesespieces2
I'm trying to make a soda can roll on its own down a level hallway and someone gave me this explanation on a possible way to do it, but I'm having trouble understanding how to execute it. Can someone explain it in different words?
"One complicated mechanical way is to put a flywheel inside, on bearings, and with a brake, and a coupling of some sort. If you temporarily connect the flywheel to a motor and get it spinning, set the can on the surface, then turn on the brake, the can will take off.
Or you can get it spinning with a crank and some gears. Or a spring.
with the spring, you don't need to get the flywheel spinning beforehand, the wound up spring will transfer it's energy to the flywheel and make it spin, and make the can rotate in the opposite direction."
I'm not allowed to use a motor (or anything battery powered) so I'd have to go with the spring method.
There once was a toy. It was the figure of a man inside a ball-shaped cage. The figure had a weight in its feet, and a rubberband was wrapped around the axle that connected the man to the ball. I think you wound it with a key on the outside. Anyway, as the rubberband sought to raise the man's feet the ball would roll forward (assuming you wound it in the right direction).
There have been devices built on the same principle where a real man with a bicycle drive is suspended below a central hub connected to something like a gerbil cage (without the supporting apparatus).
  • · Replies 53 ·
  • · Replies 17 ·
  • · Replies 18 ·
