Can someone help with this problem
  • Thread starter Jumpy Lee
In summary, the task is to find the derivative of y = (e^cx)(c sin x – cos x). The solution is c(e^cx)(c sin x – cos x) + (c cos x + sin x)(e^cx) and can be simplified to {(1+c^2)((e^cx)sin x)}.
Jumpy Lee
Find the derivitive of y = (e^cx)(c sin x – cos x)
None
The answer is { (1+c^2)((e^cx)sin x)
You're doing fine, they are the same! Try to simplify :smile:
it is right ... hey TD ..what he should simplify
If you look well, you see the terms in cos(x) are opposite, they cancel out.
ah ok he did it ... i thought there is somethin' else i missed thanks for the reply
Thanks TD i see how it works now :smile:
You're welcome!
When you see that the given answer doesn't match your "longer" answer, always think of simplifying, it may just be correct after all :smile: !
1. What kind of problem do you need help with?
As a scientist, I am able to help with a wide range of problems in various scientific fields such as biology, chemistry, physics, and more. Please provide specific details about your problem so I can better assist you.
2. Can you provide step-by-step guidance to solve the problem?
Yes, I can provide detailed instructions and explanations to help you solve your problem. However, it is important to note that the solution may vary depending on the specific problem and its complexity.
3. How long will it take for you to help with the problem?
The time it takes for me to help with a problem depends on various factors such as the complexity of the problem, my familiarity with the topic, and the availability of resources. I will do my best to assist you as quickly as possible.
4. Is there a limit to the number of questions I can ask for help with?
No, there is no limit to the number of questions you can ask for help with. I am here to assist you with your scientific problems and will do my best to answer all of your questions.
5. Will you provide references or sources for the information you provide?
Yes, I will provide references or sources for the information I provide to ensure accuracy and credibility. Additionally, I encourage you to do your own research and fact-checking to further understand the problem and its solution.
