Can Sonic Velocity Be Achieved in a Short, Constant Cross-Section Pipe?
  • Thread starter Thread starter arhanbezbora
    Flow Pipe
The discussion centers on whether sonic velocity can be achieved in a short pipe with a constant cross-section, under the assumption of isentropic flow and neglecting viscous effects. The scope includes theoretical considerations and mathematical reasoning related to fluid dynamics.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant questions if sonic velocity can be achieved under the specified conditions.
  • Another participant suggests that achieving sonic velocity is possible if the pressure differential is sufficiently large.
  • A further inquiry is made regarding the specific magnitude of the pressure gradient required to reach sonic velocity.
  • One participant proposes using Bernoulli's equation to estimate the pressure difference needed based on the flow diameter of the tube.
Participants express differing levels of certainty about the conditions required to achieve sonic velocity, with no consensus on the specific pressure gradient needed.
Assumptions regarding the neglect of viscous effects and the nature of isentropic flow are critical to the discussion, but these assumptions remain unexamined in detail.
arhanbezbora
Can sonic velocity be achieved in a short pipe with constant cross-section, assuming isentropic flow with no viscous effects being taken into account?
Thank you.
I can't think of any reason why not as long as the delta P is large enough.
Large enough? How large would the pressure gradient need to be? Thanks
For a quick calculation, use bernoulli knowing the flow diameter of the tube. Solve for P1-P2
  • · Replies 20 ·
12K
  • · Replies 31 ·
  • · Replies 21 ·
