The discussion revolves around the feasibility of using electrically heated thrusters for aircraft propulsion, specifically exploring the potential for unlimited range through the use of space lasers as a power source. Participants examine the mechanics of electric heating, thrust generation, and alternative propulsion concepts.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant proposes a thruster design that uses electric heating to lift 10kg, questioning its feasibility given a 5kg thruster weight.
- Another participant suggests that the concept resembles an electrically powered jet engine, indicating it might be possible but noting it has not been realized yet.
- There is a suggestion to calculate the thrust produced by an electric super-heater compared to an electric motor and propeller system, with some participants expressing interest in the outcome of such calculations.
- A hybrid concept is introduced, where a propeller or turbine drives air into a combustion chamber for super-heating, which is described as a jet engine configuration.
- A participant references NASA's work on engines utilizing alternative heat sources, specifically mentioning aircraft powered by laser beams from solar power satellites, which could theoretically provide unlimited range.
Participants express varying opinions on the efficiency and practicality of different propulsion methods, with no consensus reached on the best approach or the feasibility of the proposed thruster design.
The discussion includes assumptions about the efficiency of electric heating and propulsion systems, as well as the potential for hybrid designs. There are unresolved calculations and comparisons between different propulsion methods that remain open for exploration.
