Can the Non-Homogenous Heat Equation be Solved Using Eigenfunctions?
  • Context: Graduate
  • Thread starter Thread starter JoernE
    Heat Heat equation
6 replies · 4K views
JoernE
Consider the following non-homogenous heat equation on [itex]0 \leq x \leq \pi[/itex]
[itex]u_t = k u_{xx} - 1[/itex] with [itex]u(x,0) = 0, u(0,t) = 0, u(\pi, t) = 0[/itex]
Find a solution of the form
[itex]\displaystyle \sum_1^{\infty} b_n(t) \phi_n (x)[/itex]
where [itex]\phi_n(x)[/itex] are the eigenfunctions of an appropriate homogenous problem, and find explicit expressions for [itex]b_n(t)[/itex]
So I think
[itex]\phi_n(x) = \sin \frac{n \pi x}{L}[/itex]
so I find solutions in the form
[itex]\displaystyle u(x,t) = \sum_1^{\infty} b_n (t) \ \sin \frac{n \pi x}{L}[/itex]
Am I on the right track? Is the eigenfunction correct?
on Phys.org
I have a different method...
Let [tex]u = w(x,t) + v(x)[/tex]
Then
[tex]\frac{\partial u}{\partial t} = \frac{\partial w}{\partial t}[/tex] and [tex]\frac{\partial^2 u}{\partial x^2} = \frac{\partial^2 w}{\partial x^2} + \frac{\partial^2 v}{\partial x^2}[/tex]
Sub these back into the PDE to obtain
[tex]\frac{\partial w}{\partial t} = k \frac{\partial^2 w}{\partial x^2} + k \frac{\partial^2 v}{\partial x^2} - 1[/tex]
Choose [tex]k \frac{\partial^2 v}{\partial x^2} - 1 = 0[/tex]
So
[tex]V'' = \frac{1}{k}, \ V(0) = V(\pi) = 0[/tex]
[tex]V' = \frac{1}{k} + A[/tex]
[tex]V = \frac{1}{k} + Ax + B[/tex]
[tex]V(0) = \frac{1}{k} + B = 0 \ \Rightarrow \ B = - \frac{1}{k}[/tex]
[tex]V(\pi) = \frac{1}{k} + A \pi + B \ \Rightarrow \ A = -\frac{1}{k \pi} - \frac{B}{\pi}[/tex]
[tex]V(x) = 0[/tex]??
Also since [tex]k \frac{\partial^2 v}{\partial x^2} - 1 = 0[/tex] we have
[tex]\frac{\partial w}{\partial t} = k \frac{\partial^2 w}{\partial x^2}[/tex] which is homogeneous.
[tex]u(0, t) = v(0) + w(0, t) = 0[/tex]
[tex]\Rightarrow \ w(0,t) = 0[/tex]
[tex]u(x, 0) = v(x) + w(x,0) = 0[/tex]
[tex]\Rightarrow \ w(x,0) = 0[/tex]
[tex]u(\pi, t) = v(\pi) + w(\pi, t) = 0[/tex]
[tex]\Rightarrow \ w(\pi, t) = 0[/tex]
Then we have
[tex]w_t = k w_{xx}[/tex] with [tex]w(x,o) = 0, w(0,t) = 0, w(\pi, t) = 0[/tex].
Since this is homogenous, we can solve by letting
[tex]w = XT[/tex]
[tex]\frac{T'}{kT} = \frac{X''}{X} = - \lambda[/tex]
[tex]X = A \cos(\sqrt{\lambda}t) + B \sin(\sqrt{\lambda}t)[/tex]
[tex]X(0) = A = 0[/tex]
but now I get a little lost...I think I know where to go, just not exactly how to get there. Already have calculated that [tex]v(x) = 0[/tex], which will lead to what I need to prove (I think).
Joerne, on this board use "[tex]", not "[tex]" to show LaTex. I have editted your post to correct that.<br /> <br /> Your first method is perfectly correct. You will, of course, have to expand the constant, -1, in a Fourier sine series.[/tex][/tex]
HallsofIvy said:
Joerne, on this board use "[tex]", not "[tex]" to show LaTex. I have editted your post to correct that.[/tex][/tex]
[tex][tex] <br /> Thanks.<br /> <br /> <blockquote data-attributes="" data-quote="HallsofIvy" data-source="post: 2951688" cite="https://www.physicsforums.com/goto/post?id=2951688" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> HallsofIvy said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Your first method is perfectly correct. You will, of course, have to expand the constant, -1, in a Fourier sine series. </div> </div> </blockquote><br /> Are you referring to my first post here?<br /> <br /> Are you saying that what I wrote in the second post (under "I have a different method") is not correct?[/tex][/tex]
JoernE said:
[tex]w = XT[/tex]
You have a typo, X is a function of x, and T is a function of t.
You need to find the value of A,B, and lamda.
The first b.c. gave that A=0. The second b.c. gives X(Pi)=B Sin(sqrt(lamda)*Pi), which is equal to 0. Unless, sqrt(lamda)=n/2 where n is an integer number . n=1,2,3,4,5,6...
Now that you know what lamda is equal to , solve for T, but do not apply the initial condition,yet!
Once you have the expressions for X and T, take their product (which is u), and apply the initial condition.
Thanks MasterX!
This should be [tex]\displaystyle X = A \cos(\sqrt{\lambda}x) + B \sin(\sqrt{\lambda}x)[/tex]
so
[tex]\displaystyle X(\pi) = B \sin (\sqrt{\lambda} \pi) = 0[/tex]
[tex]\displaystyle \ \sqrt{\lambda} \pi = \frac{n \pi }{2}[/tex]
[tex]\displaystyle \ \sqrt{\lambda} = \frac{n}{2}[/tex]
[tex]\displaystyle \ \lambda_n = \big( \frac{n}{2} \big)^2[/tex] for [tex]n = 1,2,...[/tex]
So
[tex]\displaystyle \phi_n(x) = \sin \big(\frac{n \pi x}{2} \big)[/tex]
and so
[tex]\displaystyle u(x,t) = v(x) + \sum_1^{\infty} b_n \sin \big(\frac{n \pi}{2} \big)[/tex]
[tex]\displaystyle \ = \displaystyle \sum_1^{\infty} b_n(t) \phi_n (x)[/tex]
and I think
[tex]\displaystyle \ b_n = \frac{1}{\pi} \int_0^{\pi} \sin(\sqrt{\lambda} x) dx[/tex]
Do not forget that u=X*T and T' = -lamda * k*T => T=C*Exp(-k *lamda*t)
Therefore b_n=D*Exp(-k*lamda*t), where D=C*B, but this is not important.
Substitute this equation into u, and apply the initial condition to get D.
EDIT:
Since V(x)=0, the above analysis will give you that D=0, which is wrong! Also, V(x) can not be zero.
I do not think this is the way to solve non homogeneous equations. I remember first solving the homogeneous equation (exactly as you did for w), then I assumed that A,B, C are function of x,t and I solved the non-homogeneous. In the end, I used the b.c and i.c. to compute the value of the constants.
