Can this projectile motion problem be solved with the given information?
14 replies · 3K views · last reply
Enochfoul
I came across this question in another forum and the members of the group said it can't be solved due to lack of information. Can anyone solve it?
  • Circuit schematic of a step-down switching regulator with TRx switch, oscillator, amplifier, Vref block, inductor L1, diode D1, capacitor C1, resistors R1 and R2, output VOUT and load RL, plus a table of E24 series resistor values.
That question has been posted on this forum recently. I don't think it can be solved. Too many unknowns. I think the best you can do is calculate R2 as a function of Vin for 3b(i) but then you are stuck for (ii).
And for (ii) solve for VIN as a function of R2. :doh:
Where did this problem come from?
any chance a Vout value is given on a previous page?
If you had Vout you could get both as a function of Vout
Its an assignment question which I believe they have messed up on by omitting information.
Hi
The missing piece has been found Vout= 7.5V
Using the formula: Vout=Vref*(R1+R2/R2)
Vout=1.25(10+2/2) = 7.5
R2 must be 2 does that look right?
Enochfoul said:
Hi
looks good to me!
rude man said:
What happened to part (ii)? We await with bated breaths ...
The problem stated had missing info. The Vout should have been 7.5V. Sorted it now thanks the lecturer missed it off by accident
Yes I know, and part (a) was I presume solved. But what about part (b)? It's still an interesting problem.
D=Vout/Vin. There are 2 knowns in the question Duty Cycle which is 30% and Vout which is 7.5V. So Vout is 30% of Vin.
Im happy to show the solution for 3bi if you would like
In post #7:
There seems to be some parens missing: Vout=Vref*(([/color]R1+R2)[/color][/color]/R2)
Which reduces to the usually seen: Vout=Vref*(1+R1/R2)
The answer is correct. Good going.
