Can this work? Moving in a vacuum
  • Context: Undergrad
  • Thread starter Thread starter preaceps
    Vacuum Work
The discussion centers on the feasibility of using a paddle-wheel type arm equipped with coiled wiring to create a magnetic field for propulsion in a vacuum. Participants concluded that generating a magnetic field alone does not produce force to move a spaceship, as magnetic fields do not perform work. The concept was likened to maglev trains, but it was determined that any potential propulsion would be limited and impractical for space travel. Ultimately, the idea was deemed implausible and not viable for actual use.
  • Understanding of magnetic fields and their properties
  • Basic knowledge of propulsion mechanisms in space
  • Familiarity with solenoids and their function
  • Concepts of magnetic levitation and its applications
  • Research the principles of magnetic propulsion systems
  • Explore the physics of solenoids and their applications in engineering
  • Investigate the limitations of magnetic fields in vacuum environments
  • Learn about alternative propulsion methods for spacecraft, such as ion propulsion
Aerospace engineers, physicists, and anyone interested in the principles of propulsion and magnetic fields in space exploration.
preaceps
Can this work?? Moving in a vacuum
Okay, so i have been bugged by this idea for about a week now. And unfortunately it has been quite some time since I took any real in depth science classes. I am wondering if this idea is even plausible.
In the vacuum of space, would you be able to have a spaceship with a paddle-wheel type arm on the back. Instead of the paddles though, it is an arm with wiring coiled around it so that you can run a current through it and create a magnetic field. If that arm could be put on a rotating joint to allow say 180% movement, so as to allow for turning, would the magnetic field( if it was strong enough) be able to move the ship?
ATM i am not so much concerned with the mass, current required, or speed gained as I am as is this even possible. Also I tend to have weird ideas, so do you think that this is just completely insane? Plausible but not practical?
Thanks,
Rob
If you had a wire coiled around a paddle you really just have a solenoid, the magnetic field outside the solenoid is zero for the surface of the cylinder as each component is canceled by the components generated by the next turn of wire. So there is only really a B field at either ends of the arm but one end would be the ship itself.
How would generating a magnetic field into space cause a ship or whatever to move? Magnetic fields do no work
No, it's not plausible.
A magnetic field in itself generates no force to move the ship.
Thanks guys, i don't know. I was thinking of kind of like the maglev trains. Like have the metal ship being repulsed by a larger magnetic force.
Was just an off the wall idea i had but i don't know that much about this stuff. :)
You want the magnetic field to repel the ship? It would work, but you couldn't carry the magnet or solenoid along with you, you'd have to leave it behind so it would push you away from it. Even then, the propulsion would be good for only a few metres before the field strength was too small to do much more. So not practicable. Myth busted.
  • · Replies 24 ·
  • · Replies 27 ·
  • · Replies 72 ·
9K
  • · Replies 23 ·
  • · Replies 146 ·
20K
