Can Time Dilation be Determined in a Constantly Accelerating Frame?
  • Level: Graduate
  • Thread starter Aer
    Relativity
74 replies · 10K views · last reply
Aer said:
Frames S1 and S2 are synonymous with frame S at the start of the experiment. Frames S1' and S2' are synonymous with frame S' at the start of the experiment. Now what I mean is S1 and S2 are stationary while S1' and S2' instantaneously accelerate to speed v wrt to frames S1 and S2.
How can frames instantaneously accelerate? An inertial frame is just a coordinate system for assigning coordinates to events, and it's assumed that the origin of this coordinate system never accelerates, otherwise it'd be non-inertial. Also, why is it necessary to define two identical frames S1 and S2, and likewise the identical frames S1' and S2'? Let's just say that frame S1 is the one where S is initially at rest and S' is moving at velocity v, while frame S1' is the one where S' is initially at rest and S is moving with velocity -v. Now, the symmetry of the situation is illustrated by the following:
1. If in frame S1, S' decelerates to zero velocity at the moment his clock reads 43.59, this will happen at coordinate time t=100, and the S-clock will read 100 at that time.
2. If in frame S1', S decelerates to zero velocity at the moment his clock reads 43.59, this will happen at coordinate time t'=100, and the S'-clock will read 100 at that time.
3. If in frame S1, S accelerates to velocity v at the moment his clock reads 43.59, this will happen at coordinate time t=43.59, and the S'-clock will read 19 at that time.
4. If in frame S1', S' accelerates to velocity -v at the moment his clock reads 43.59, this will happen at coordinate time t'=43.59, and the S-clock will read 19 at that time.
It's all completely symmetrical. If there's one of these statements you think is wrong, I can go into it in more detail. Also, if you still think you see some sort of contradiction, could you describe it in terms of the terminology I'm using, where the two ships are S and S' while the two frames are S1 and S1'?
It appears we are considering two different situations on a technicality. Let's define S1 and S2 as mother ships that exist at the position x1=x2=0 at the time t1=t2=0 in the frame S. S1' and S2' are scout ships for S1 and S2 respectively that exist at the position x1'=x2'=0 at the time t1'=t2'=0 in the frame S'. For the time being, the mother ships exist at x=0 for all t>0 in the S frame (They both can be at x=0 by having separate offsets in the y dimension).
Now your concern is a valid one in which how can we consider a frame to instaneously accelerate? I am not claiming that S' is the same frame before acceleration as it is after acceleration, it is just the instanteous frame according to S1' and S2' at any instant in time. Now if you have a problem with this, then I will refer you to the rocket equation presented earlier in this discussion. It uses the same concept.
Now that the initial setup has been fully defined, the rest of the problem as previously presented should be clear. However, I will reiterate it as follows:
The clocks of S1 and S2 are ticking in sync with each other as they share a common rest frame S. When the clocks of S1 and S2 read 100 as defined by the frame S, the S1 ship instanaeously accelerates to the frame of ships S1' and S2' which at this point is S' defined as a frame moving with velocity v=.9c wrt frame S. Now we know that any acceleration is not instanaeous in the literal sense. There is a finite interval over which it occurs and for our purposes here, we'll say that this finite interval is .5 unit of time as measured in the S frame. As soon as S1 reaches the frame of S', it, along with S1' and S2' decelerate to the frame of S. This deceleration also takes an interval of .5 unit of time as measured in the S frame. Therefore it should be clear that the clock of S2 reads 101 when all ships are back in the frame of S. My question to you is, what does the clock of S1 and S1' say right after S1 enters the S' frame and right before S1 starts its deceleration back to the frame S. And what is the time on the S2 and S2' clock right after the S2' ship is decelerated back to the S frame.
Please note the points in time of interest and do not confuse the issue with other points in time. The points in time have been defined in which frame they are considered, if you contest this issue, please explain why.
I redefined the terminology as I meant it, sorry about any confusion.
We're assuming that the frame S' has a velocity of v relative to frame S, correct? So are you assuming the mother ships start out at rest in frame S, and the scout ships start out at rest in frame S', so the scout ships start out moving at velocity v relative to the mother ships?
But in that case S1' and S2' will have different instantaneous inertial rest frames before and after the acceleration, you can't use the name S' to refer to both unless you want S' to be the label for a non-inertial frame. Isn't it easier just to analyze this problem using two different inertial frames, S and S'?
It's not, but you can consider the limit as the acceleration time goes to zero. If you want the acceleration time nonzero, then to solve the problem exactly you'll have to give a function for the velocity as a function of time (as seen by some inertial frame) during the acceleration period, and we'll have to do an integral of [tex]\sqrt{1 - v^2/c^2}[/tex] to find the clock-reading at the end of the acceleration. This seems needlessly complicated, why can't we just assume we're looking at the limit as the acceleration goes to zero?
If S1 just accelerates to v briefly and then immediately decelerates back to 0, what's the point? Why not just assume S2 accelerates quasi-instantaneously from 0 to v while S1 does not accelerate at all? What specific contradiction do you see when a finite period of acceleration is involved that wouldn't be present if we assumed quasi-instantaneous acceleration?
If you think the acceleration is essential to formulating the problem you're having, then I need more details on how the acceleration works--are you assuming that both the acceleration and deceleration take 0.5 seconds of proper time rather than time as measured in some inertial frame? Also, are you assuming the acceleration is constant over that that time as seen by the ships doing the accelerating (ie they feel a constant G-force)?
Since the S1' and S2' frames necessarily start out in the same frame as S1 and S2, they do not reach the S' frame until their acceleration stops. Yes it is true we can ignore this part of the problem, but then the entire problem is not entirely defined, it is just as easy to leave it in and have no confusion as to the origins of S1' and S2'.
S2' has the same motion as S1' in every aspect, so it is not true to say that they have different instaneous frames at any instaneous point in time as defined by either S1' or S2' since they will agree that all moments in time as measured by the other are simultaneous with their own clock. The entire point of having the two ships is that only S1 and S1' can communicate and likewise only S2 and S2' can communicate (that is, read each others clock by sending signals).
As has been shown, the time measured by the accelerating ship over the acceleration period is negligible when you consider the acceleration to be instaneous. We know that this time is not 0, but ignoring it does not give our approximation much of an error. The issue is not the acceleration.
Agreed.
Agreed, it is a stupid mission by the fact that it is stupidly simply. But the point is not about the usefulness of the mission as it was purposefully made this simple to keep the calculations to a minimum.
What is the purpose of this change to the problem as stated? Was there an error in the problem statement that makes the calcuations impossible? I don't think so or otherwise I am missing a very important concept of special relativity that you haven't pointed out (please do if it exists).
None, the contradiction does not lie within the acceleration - you've missed the point entirely. I've stated specificly if you do the calculations as I presented, S1' and S2' cannot have the same time at the end of the experiment. This is a claim I am making and asking you to disprove, please note it is not a simple matter of just saying "well of course they will have the same time, you are wrong...", you must either show that the problem statement is in error (it very well could be, though I don't believe it is) or that the calculations I asked for will not show a contradiction as I plainly stated they will. You must show all calculations asked for to prove this.
The acceleration is not essential as I've stated several times. I even told you the acceleration times were all measured as .5 units of time in the S frame, that is .5 units of proper time in the S frame (which can be considered instaneous as the coasting period was measured as 100 units of proper time in the S frame).
Your language is confusing--can you distinguish between frames and physical objects like ships? I thought S1' and S2' were the labels for the two scout ships, not "frames". So I think what you mean here is that the S1' and S2' ships start out in the same frame as S1 and S2, namely the frame S.
Why does it matter that the scout ships started out at rest relative to the mother ships? It's easier if you assume the two scout ships just whizzed by the mother ships at constant velocity, and at the moment they passed each other they synchronized their clocks to all read 0.
That's not what I meant--I didn't say they'd have different instantaneous frames from each other, just that each one would have different instantaneous inertial rest frames at different moments during the acceleration, since each one's instantaneous velocity is changing. And again, it's a lot easier to analyze the problem in SR if you look at everything from the point of view of two inertial frames S and S', including the acceleration.
Aer said:
Agreed.
OK, so can I treat the acceleration as instantaneous and thus skip the whole business of S1 accelerating and then immediately decelerating back to zero in S? In other words, can I rewrite the problem as follows?
"The clocks of S1 and S2 are ticking in sync with each other as they share a common rest frame S. When the clocks of S1 and S2 read 100 as defined by the frame S, S1' and S2' decelerate to the frame of S. My question to you is, what does the clock of S1 and S1' say right after S1' and S2' decelerate to the frame of S? And what is the time on the S2 and S2' clock right after the S2' ship is decelerated back to the S frame."
The purpose is just that instantaneous accelerations are a lot easier to deal with mathematically than accelerations over a finite period, if you insist on making the acceleration finite we have to do an integral to see how much time elapses on the clock of S1 during the acceleration (assuming it lasts for 0.5 seconds of coordinate tiem in frame S).
Why? Didn't they both decelerate at exactly the same position and time? In that case they will definitely have the same time at the end of the experiment. This calculation is simple if you assume instantaneous acceleration, if not it will be a bit complicated, but either way I'm willing to do it if you tell me which one you want.
Your language is confusing again--"proper time" only refers to time as measured by a clock along some worldline, if S1 accelerates then his proper time will not match up with time as measured in the S frame. If you want to refer to time in the S frame, that's coordinate time, not proper time. But again, if the acceleration is not essential, then why can't we drop this business with the acceleration lasting for a finite time period of 0.5 seconds?
Yes, I should have said "Since the S1' and S2' ships necessarily start out in the same frame..."
Yes, the calculation is the same either way since we are ignoring the time it takes to accelerate. If you want, the problem can be changed - but this change is only a change in the problem statement, not a change in the end result or the calculations required for the end result.
Ok.
Regarding specificly "can I treat the acceleration as instantaneous and thus skip the whole business of S1 accelerating and then immediately decelerating back to zero in S". No, this part of the problem can not be left out. Again, if you want the problem could be changed so that S1 does not immediately accelerate back to the frame of S, that is, it coasts in the S' frame for a finite amount of period before decelerating back. But I do not see the point of this requirement, and unless you can prove that it is in fact required, then I do not see any reason to change the problem. The point is that the clocks of S1 and S1' should read ~100 and ~230 right before the deceleration back to frame S. That was the entire point of which I wanted to make and you want to leave out.
JesseM said:
The purpose is just that instantaneous accelerations are a lot easier to deal with mathematically than accelerations over a finite period, if you insist on making the acceleration finite we have to do an integral to see how much time elapses on the clock of S1 during the acceleration (assuming it lasts for 0.5 seconds of coordinate tiem in frame S). Why? Didn't they both decelerate at exactly the same position and time? In that case they will definitely have the same time at the end of the experiment. This calculation is simple if you assume instantaneous acceleration, if not it will be a bit complicated, but either way I'm willing to do it if you tell me which one you want.
Are you considering the problem I stated or the problem you redefined which I've pointed out is not the same problem I stated.
Again, the proper times I noted were all measured by S2 which is always in the S frame, S2 never moves. I think your argument about S1 accelerating is irrelevent.
OK, how about this--at time t=100 in the S-frame, S1 instantaneously accelerates to velocity v so it's at rest in the S' frame, and coasts there for 1 second in the S-frame (0.229 seconds in the S' frame), then instantaneously decelerates back to velocity 0 at t=101.
If that's acceptable, then when do you want S1' and S2' to decelerate to velocity 0 in the S frame, at t=100 or t=101?
I wasn't making an argument, just saying that the problem would involve less messy calculations if we assumed instantaneous acceleration. See what you think of the modification I just suggested. Also, "proper time" can really only be measured along an observer's own worldline, if S2 is measuring the times of distant events not on its own worldline, then this should still be called coordinate time (in frame S) rather than proper time.
I'm afraid I can't keep up with this thread, there are just too many long detailed posts for me to keep trying to follow it.
I do think that Aer is off on the wrong track and making the problem unnecessarily complicated, but I'm not quite sure how to communicate this and get things on the right track - especially with the large number of posts flying by, I feel like I'm about a week behind the discussion. Anyway, good luck to all participants.
This is an acceptable change to the problem but I don't see why it is necessary.
t=101 as for the case you outlined above. The point has always been that S1, S1', and S2' decelerate from the S' frame to the S frame simultaneously as seen by the S frame, that is the S2 mother ship. All I've asked for are the time for S1' before it instantaneously decelerates and the time for S2' after it instantaneously decelerates. Do not forget the details of the problem when you make these calculations.
This is an irresponsible post on your part.
No one has presented a valid contradiction to the problem statement as I presented it. The problem statement has only been changed in terminology, not it any substantial way that changes the calculations required to answer the problem statement. Only if you can show the problem statement to be in error in this fashion, then you may post that I am off on the wrong track.
Besides, the discussion JesseM and I have been having is irrelevant to the discussion between you and I which ended with this:
Aer said:
Do you disagree with these mathematical statements:
x' = γ ( x - vt )
t' = γ ( t - v/c^2x )
x = γ ( x' + vt' )
t = γ ( t' + v/c^2x' )
If so, can you show me a derivation of the lorentz tranformation that doesn't require this? Please not that most derivations will not explicitly show this, but nevertheless, I have not found a derivation that does not make the same assumptions that require this to be true, but then proceed to do it in a similar but not explicitly same way. This includes Einstein's derivation. I have found derivations that don't require this, but all of those have contained errors that I can prove if necessary. I did not intend this discussion to go into the issue of whether reciprocity is required by special relativity. I thought this was a generally accepted fact. Maybe you can elaborate on how the above equations are not in fact the reciprocity that special relativity requires or that these equations do not imply what "my rule" says they imply.
This link mentions the concept of reciprocity.
Here is Einstein's derivation
It isn't "necessary", but as I said a few times, it makes the math simpler. If you wanted a period of finite acceleration, you'd have to first find the velocity as a function of time in some inertial frame during the acceleration, then integrate [tex]\int^{t_1}_{t_0} \sqrt{1 - v(t)^2/c^2} \, dt[/tex] in that frame to find out how much time will elapse on the ship's clocks during the acceleration. If you specify constant acceleration from the point of view of the ship, then the rate of acceleration will not be constant from the point of view of an inertial reference frame, so v(t) won't just be a*t.
Sounds good. Assuming all three decelerate at the same moment in frame S, the clock of S1 will read 100 + (0.4359)(1) = 100.4359 seconds, while S1' and S2' will read (101)*(0.4359) = 44.025 seconds. In frame S', the event of S1 decelerating (I'll keep calling it 'decelerating' even though in this frame the velocity increases) happens at a different time than the event of S1' and S2' decelerating; S1 decelerates at time t'=229.852 in this frame (found by doing a Lorentz transform on the coordinates x=0.9, t=101 in the S-frame), while S1' and S2' decelerate 185.827 seconds earlier at t'=44.025 (found by doing a Lorentz transform on the coordinates x=90.9, t=101 in the S frame). Since they run at 0.4359 the normal rate after decelerating in this frame, they will read 44.025 + (0.4359)*(185.827) = 125.025 at the moment S1 decelerates, in the S' frame.
On the other hand, you might want to specify that all three decelerate at the same moment in frame S' instead. In this case, it's still true that the clock of S1 will read 100.4359 seconds, but now S1' and S2' will read 229.852 seconds at the moment they decelerate (again, found by doing a Lorentz transform on x=0.9, t=101 in the S frame). Now in the S frame these events no longer happen at the same moment--instead, at the moment S1 decelerates, S1' and S2' have not yet decelerated, and they only read (0.4359)*(101) = 44.025 seconds at that moment.
So, S1' and S2' decelerate to the S frame before S1 enters the S' frame according to an observer stationary in the S' frame. Meanwhile, while S1 is in the S frame before accelerating to the S' frame, an observer in the S frame will say that S1' and S2' are still in the S' frame. So no matter what, over this infintesimally small instant of acceleration, S1 managed to escape being in the same frame as S1' and S2' even though S1' and S2' didn't decelerate to the S' frame at the same time according to either an observer in the frame S or S' as S1 accelerated to the S' frame. I am not saying this is a contradiction per say, I am only asking if this is an accurate assessment of the situation or if it needs to be revised.
Let's not consider two different scenarios.
Yes.
It's a little ambiguous to talk about what happens over an infinitesimally small period of time--the velocity is really undefined at the exact moment of an instantaneous acceleration, and so the instantaneous inertial rest frame at that moment is also undefined. If you made the acceleration non-instantaneous, then S1 would have a different instantaneous rest frame at each moment during the acceleration, and each of these instantaneous rest frames would have a velocity midway between S and S'. Note that this would be just as true in Newtonian mechanics as it is in relativity.
Sorry you feel that way. I'm about 5-10 posts behind, so perhaps you and Jesse have already addressed the things that were bothering me. I just don't know, because I don't have time to follow this thread in the amount of detail that it would take me to figure out whether or not you two had already covered my misgivings or not.
I thought I'd just let everyone involved know that I had to "abandon ship" due to time constraints, rather than just walk away from the thread without telling anyone.
JesseM said:
Yes. It's a little ambiguous to talk about what happens over an infinitesimally small period of time--the velocity is really undefined at the exact moment of an instantaneous acceleration, and so the instantaneous inertial rest frame at that moment is also undefined. If you made the acceleration non-instantaneous, then S1 would have a different instantaneous rest frame at each moment during the acceleration, and each of these instantaneous rest frames would have a velocity midway between S and S'. Note that this would be just as true in Newtonian mechanics as it is in relativity.
Very well, my purpose to this thread was to gather a better understanding of all the implications of special relativity as I've merely only had an introductory lecture on it many years ago. I still have concerns about the notions of space contraction as described by the lorentz transformations as I alluded to in another thread as well as the issue of simultaneity as illustrated in this thread. These concerns originated from an idea (I would hesitate to refer to it as any type of theory at this point) on the fundamental nature of matter which would be a better topic for the Strings, Branes, & LQG forum. This idea would explain a lot of the experiments on special relativity but I noticed right away it would not allow for some of the ideas purported by special relativity. Anyway, thank you for your time.
I can understand time restraining anyone from delving deeply into a certain topic, there is no need for you to apologize for this.
