Can voltage and current values be captured and logged in labview?
  • Thread starter Thread starter atlbraves49
    Current Voltage
1 reply · 4K views
atlbraves49
I'll describe our current set up:
http://img152.imageshack.us/img152/195/simplepicturegv9.th.jpg
We have energy being drawn from a thermoelectric module, to a resistor (just dumping it). We are acquiring the temperatures across the thermoelectric module, into labview, using thermocouples, but right now, current and voltage measurements are being done manually (using a voltmeter). Is there a product that allows you to acquire current/voltage data and send it to labview? Anything you can recommend for this current set up?
Check out the data aquisition modules from companies like National Instruments. Their USB-based data acq modules are especially handy. For current acquisition, you'll probably need to put in a shunt (low value) resistor, and do a differential voltage measurement across the shunt.
BTW, most of NI's data acq modules are built into LabView as drag-and-drop objects, IIRC.
