C/C++ Can you append digits to a variable in c++ or python
The discussion centers on generating numbers by appending digits in C++. The initial approach involves using a loop to create sequences like 12, 123, and 1234 by multiplying and adding to an integer. Concerns about integer overflow are raised, suggesting that using strings might be a safer alternative for larger numbers. The conversation also explores converting between strings and integers using `std::istringstream` and `std::ostringstream`. Participants discuss methods for appending digits, including multiplying by 10 and adding a digit, as well as using logarithmic calculations for more complex appending. The need for arbitrary precision arithmetic libraries is highlighted for handling very large numbers. In Python, similar logic is applied, demonstrating the language's ability to handle arbitrary-length integers natively. The thread concludes with a note on correcting an array size error in the initial C++ code.
OrbitalPower
Say you have a variable x, that is of type int.
x = 1;
I just want to create a while or for loop so that each time it runs it adds another digit to it, such as:
1234
or 1, 11, 111, 1111, and so on.
Technology news on Phys.org
I know you can do this:
char y;
y = '1';
char test[2];
test[0] = y;
test[1] = y;
test[2] = '\0';
But I wouldn't know how to get it back to int in C++
Code:
int num=1;
for (int i=2; i<len; ++i)
   num*=10;
   num+=i;
Obviously though, you'd have to watch out for integer overflow.
You could also go with the string method, and if you don't need to actually perform operations on the number then it would work fine and you wouldn't have to worry about overflow. I'd use std::string instead of a char array, though.
Also, since you might need to convert a string to an integer or visa versa at some point:
Code:
#include <sstream>
int str_to_int(std::string str)
  int num=0;
  std::istringstream is(str);
  is>>num;
  return num;
std::string int_to_str(int num)
  std::ostringstream os;
  os<<num;
  return os.str();
These can be easily modified for use with other numeric types as well (for all the types std::*stringstream objects can handle anyways) You could even write a generic template function if you felt like it.
x = 1;
1234
To append at the low end, multiply by 10 and add [digit].
To append at the high end, add [digit] * 10 ^ floor(log_10(n)).
You can compute the log relatively quickly using shifts and a constant for 1/log_2(10).
Yes, thank you both JaWiB and Strilanc. I guess to do the 1111+ I'd so something like:
Code:
	int x;
	x = 1;
   int num=1;
for (int i=2; i<8; i++)
   num = num * 10;
   num = num + 1;
I guess I was so busy thinking about trying to convert between types I didn't think of the simple arithmetic solution.
I also like the append at the high end method.
I don't know how big you want your numbers, but if you want them really big you will need to download an arbitrary precision arithmetic library. There are a bunch available for C++, but I don't know about Python.
In Python, the above would become:
Code:
maxappends = 8   # actually its max appends -2
num = 1
for i in range(2,maxappends):
  num = num*10 + 1
You get the added benefit of arbitrary length integers: maxappends could be 1001 or more.
To add digits to the LHS (only makes sense if the digits are different, and if you are not prepending a zero):
Code:
maxappends = 20; num = 0
for i in range(maxappends):
  num = num + ((i % 9) + 1) * 10**(i)
  print i,num
- Have fun, Paddy :smile:
Code:
num = 1
  num = num*10 + 1
This is built in natively? What I was doing was constructing a program that return the remainder in a number composed entirely of ones with 50 or so digits. The idea was to determine the remainder by using the divisor only a few times into the dividend, as it was also composed entirely of ones. Obviously, to do that in C++ I'd perhaps need one of those libraries needed above. So, basically I just tested my method with smaller numbers.
*Also fixed an error I made, should be:
char test[3];
test[0] = y;
test[1] = y;
test[2] = '\0';
and not char test[2].
  • · Replies 16 ·
