Can you check the solution for this second order ODE?
ecastro
The second order ODE is,
\begin{equation*}
\frac{d^2 x}{dt^2} = -\omega^2_g \frac{dx}{dt}
\end{equation*}
I tried solving this by substitution of the second order derivative into a variable and transforming the equation into a second order polynomial, and I get the solution involving an exponential. But, the solution includes a sinusoidal function, which I don't know how it got a sinusoidal function.
Hi ecastro:
Consider a substitution of y(t) = dx/dt to get a first order ODE, dy/dt = -ωg2 y
Hope this helps.
Regards,
Buzz
Hi @ecastro:
I was hoping my post would help you recognize that a sin or cos is NOT a solution. Did you get that? My guess is that the given sin or cos solution is a typo.
You are correct that an exponential is a solution, but there is also a second solution: x = t + const.
Regards,
Buzz
Mod note: Post referred to below is now deleted, as it contained a complete solution .
Thank you for your answer. It turns out I misunderstood the equation; I am sorry. The original equation is this,
\begin{equation*}
\ddot{v}_x = -\omega_g^2 v_x.
\end{equation*}
The ##v_x## is the velocity of the particle along the ##x## direction, and a dot above the function means a derivative with respect to time. So this equation should have a sinusoidal function as a solution. If I am not mistaken, the solution is
\begin{eqnarray*}
v\left(t\right) &=& C_1 e^{\pm i \omega_g t} \\
&=& C_1 \left(\cos \omega_g t \pm i \sin \omega_g t\right).
\end{eqnarray*}
From here, I can integrate the velocity component with respect to time to calculate the position of the particle; but it would seem that the position of the particle is real, how can I eliminate the imaginary component?
The general solution is
##v(t)=C_1 e^{i\omega_g t}+C_2 e^{-i\omega_g t}=C_1(\cos \omega_g t+i\sin\omega_g t)+C_2(\cos \omega_g t-i\sin\omega_g t)##.
Alternatively, by defining the new constants ##A_1=C_1+C_2## and ##A_2=i(C_1-C_2)##:
##v(t)=A_1\cos \omega_g t+A_2\sin\omega_g t##.
If ##A_1## and ##A_2## are chosen real, ##v(t)## will also be real.
Is this acceptable? The first constants, ##C_1## and ##C_2## can be calculated if initial conditions are given, right?
Here is the solution of the equation with respect to position,
\begin{equation*}
x - x_0 = r_g \sin \left(\omega_g t\right),
\end{equation*}
where ##\omega_g = q B / m##, ##r_g = m v_{\perp} / \left(|q| B\right)##, and ##x_0## is the initial position.
\begin{equation*}
\end{equation*}
The sets of constants, i.e. ##(C_1,C_2)## and ##(A_1,A_2)## are connected by a linear transformations. For given initial conditions you can either determine ##C_1## and ##C_2##, or ##A_1## and ##A_2##. I only introduced the constants ##A_1## and ##A_2## for convenience. As I said in my previous post ##A_1## and ##A_2## will be real if ##v(t)## is real. However, ##C_2## will not be. But, if you prefer you can keep using ##C_1## and ##C_2##.
From your solution I suppose your initial conditions are
$$x(0)=x_0$$,
and
$$v(0)=r_g\omega_g$$.
By integrating the expression for ##v(t')## from 0 to to ##t## on both sides we have
$$x(t)-x_0=(A_1/\omega_g)\sin\omega_g t -(A_2/\omega_g )(\cos\omega_g t -1) $$
So, the solution you posted is satisfied if
$$A_1=r_g \omega_g$$,
and
$$A_2=0$$.
You can also use the set ##(C_1,C_2)## but the solution becomes slight more cumbersome, I guess.
