Can You Compute Fresnel Integrals?
  • Level: Undergrad
  • Thread starter unseenoi
    Integral
14 replies · 5K views · last reply
unseenoi
hi everyone can someone please help me out. This is not homework just getting ready for school
integral of sin(x^2)
Are you familiar with complex integration and the residue theorem?
unseenoi said:
no i am not
In that case, I would try a substitution.
Seeing as you say you're getting ready for school, are you still in high school? Also I just noticed that you didn't specify an interval to integrate over. Did you just make up this integral yourself? The reason I am asking this is that this function does not have a primitive function in terms of elementary functions.
Well noted Cyosis, I presumed that by 'school' the OP meant grad school, which looking back now may have not been a wise assumption.
[itex]\int \sin(x^2)\,dx[/itex] is not elementary.
So "hints" like "try substitution" are not helpful.
Indeed it is, as has already been pointed out.
Really? How about substituting u=x2, then expanding sin(u) about u=0 and performing term-wise integration? Does this not give the power-series definition of the Fresnel function S(x)?
I think your substitution hint implied either u-substitution or integration by parts. There is no need to make a substitution to expand sin(x2) out into its power series.
There is no systematic way to compute Fresnel integrals as I know.
But there are several approximation methods
I found Peter L. Volegov's code in Matlab central. It uses a method proposed in the following : (ith an error of less then 1x10-9)
Klaus D. Mielenz, Computation of Fresnel Integrals. II
J. Res. Natl. Inst. Stand. Technol. 105, 589 (2000), pp 589-590
Or simply wiki Fresnel Integrals
by the way it is suprising that nobody above heard of Fresnels.
It is useful if you want to derive an asymptotic expression for the case of the integral from zero to R for large R.
If you're integrating from 0 to R, then for small R, you simply integrate the Taylor expansion term by term.
If R is large, you write the integral as an integral from zero to infinity minus the integral from R to infinity. The former integral is is number which you ca easily obtaoin using contour integration methods. The latter you compute by doing the substitution x^2 = u as suggested by Hootenanny, and then you do a relpeated partial integration, where you integrate the sin and differentiate the 1/sqrt(u). You iterate this, each time integrating the trigonometric term and differentiating the 1/u^(n+1/2). This then yields an asymptotic expansion with the last unevaluated integral as an error term.
There is no systematic way to compute sine as I know.
thus it would be quite a surprize if fresnel integrals were easier
