Can you create a hydroelectric generator using a pump from a fire fighting pump
The discussion revolves around the feasibility of creating a hydroelectric generator using an old firefighting pump by replacing its motor with a generator or alternator. Participants explore the potential efficiency and suitability of different pump types for hydroelectric applications, focusing on the mechanics of water flow and energy generation.
  • Some participants question the efficiency of using a centrifugal pump for hydroelectric generation, suggesting it may not work effectively.
  • Others inquire about the specific type of pump needed, indicating that a turbine might be more appropriate than a pump for generating hydroelectric power.
  • Participants discuss the importance of matching the generating system to the water source's height difference and flow rate.
  • There is mention of the possibility that some pumps can operate in reverse as turbines, but this is not universally applicable.
  • One participant notes that the design must be right for the system to work efficiently, and they request performance data for the pump in question.
  • Concerns are raised about the complexity of modern fire pumps, which may include features that complicate their use as prime movers for hydroelectric generation.
  • A participant references a paper discussing the characteristics of centrifugal pumps working in direct or reverse mode, highlighting the potential for using such pumps in small hydroelectric power stations.
Participants express differing views on the suitability of a firefighting pump for hydroelectric generation, with no consensus on whether it can be effectively adapted for this purpose. The discussion remains unresolved regarding the best approach and the efficiency of the proposed system.
Participants note limitations in the discussion due to the hypothetical nature of the project, with some specifics about the pump's performance and characteristics remaining unclear.
paul wright
wanting to know if you could create a hydro system using an old firefighting pump discarding the old petrol or electric motor and replacing it with an generator or alternator. water would flow into the pump which would drive the generator
Welcome to the PF.
It sounds pretty inefficient. Can you post pictures and specs on the FF pump? What type of pump mechanism is it?
That looks like a centrifugal pump so I doubt you would be able to do anything with it.
what type of pump would you need?
Spinnor said:
In some cases, say a pumped storage hydropower plant, I think the pump also works as the turbine.
Some, but not all pumps will work in reverse as turbines.
Some, but not all turbines will work in reverse as pumps.
An introduction to the term “turbine” is critical to learning about hydroelectric power generation.
Yes you can
The real question is if the amount of work is worth doing
Crack that thing open show us what your working with.
That would depend largely on what type of fire pump you are looking at. Most modern fire pumps are a multistage device with sliding valves and auto pressure recirculation. This allows them to recirculate internally when there is no flow and increase the flow themselves as the requirements increase. They are also capable of delivery different pressures to separate outlets. Without defeating or bypassing these functions I do not think it would work as a prime mover.
If it is an older strictly single stage it should work relatively well.
Oops, followed the thread a little further and saw the picture. I agree that it is probably a centrifugal pump and would be very low efficiency if you could even get it to work.
If the design were right it might work but most likely only efficiently under a narrow range of operating conditions. Do you have a performance graph for the pump? Open her up and take pictures.
This paper addresses some issues, https://www.hindawi.com/journals/ijrm/2013/279049/
"Characteristics of Centrifugal Pumps Working in Direct or Reverse Mode: Focus on the Unsteady Radial Thrust"
"... On the other hand, a growing number of small hydroelectric power stations (5 to 100 kW [6]) are being developed due to their extremely attractive operating costs. However, the initial investment for the equipment is rather high. This is why the use of standard range centrifugal pumps operating in turbine mode has become a credible alternative to hydraulic turbines since their much lower cost and the wide variety of machines (in terms of operating points and dimensions) make it possible to significantly reduce equipment costs. ..."
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 29 ·
11K
