Can you determine the relationship between 20+/4+ and 5+?
  • Thread starter Thread starter Spirochete
    Gre Symbol Weird
This problem involves comparing two expressions defined with a specific notation, where "+" indicates a range of values between integers. The expressions in question are 20+/4+ and 5+, with the task of determining their relationship based on the provided definitions.
  • Conceptual clarification, Problem interpretation
  • Participants discuss the meaning of the notation and how to interpret the defined range for the "+" operation. Some suggest reformulating the problem using simpler variables to facilitate comparison.
The discussion includes attempts to clarify the notation and explore the implications of the definitions provided. Some participants have offered insights into the bounds of the expressions, while others are still grappling with the initial setup.
The original poster expresses confusion about translating the notation into a workable mathematical operation. There is an acknowledgment that the relationship cannot be definitively determined from the information given.
Spirochete
This problem asks you to compare two values and say whether one is greater, they are the same, or the problem does not give you enough information to answer the question. In this question they give you a symbol, in this case "+" and then define what it does to a number.
The problem states:
If N is a positive integger, than N+ denotes a number such that N<N+<N+1
Then it asks you to compare:
20+/4+
and
5+
The correct answer is "The relationship cannot be determined from the information given"
I have no clue how to even start with this problem. I don't understand how to translate their meaning for "+" into an operation on those numbers.
This is funny notation no doubt. But you can change the notation. Is this problem simpler?
Let x, y, and z be numbers such that 20 < x < 21, 4 < y < 5, 5 < z < 6. Compare x/y to z.
According to the definition you provided,
N+ satisfies the relationship N < N+ < N + 1, where N is a positive integer. IOW, N+ is a number between N and N + 1. (It's helpful to add some spaces to make this expression more readable and maybe more understandable.)
In your problem, 20+ is between 20 and 21, and 4+ is between 4 and 5.
What can you say about the quotient 20+ / 4+? What's the largest value of this quotient? What's the smallest value? (It's 4.)
Compare your result with 5+, which you should realize by now as being between 5 and 6.
Oh i see now. thanks guys
  • · Replies 21 ·
