Can you do the double slit experiment with a laser pointer and foil?
  • Level: High School
  • Thread starter Cpac73322
    Double-slit Home
4 replies · 2K views · last reply
Cpac73322
So I am a sophmoore in high school and i am really interested in quantum physics and i am fascinated by the double slit experiment. So i wondered, is there a way that i could reproduce the same results using common materials such as a laser pointer and aluminum foil. Any point at all would be greatly appreciated
Not really, I think...the slits are normally done by fancy equipment so they're incredibly small. However, there's a neat trick you can do that gives the same results as the single slit experiment: shine a laser pointer on a single hair of yours (held taut so it doesn't curve or whatever). I think for some reason, the inverse of something that diffracts light will diffract the same way.
It works if you take a piece of transparent glass or plastic, cover an area of it with a sharpie, and then scratch out two parallel lines with a pin, very close together.
For safety, watch for specular reflections and make sure they don't go in your eye. Work with all the apparatus below eye level.
http://en.wikipedia.org/wiki/Babinet's_principle
If you don't insist on exactly two "slits", you can use a CD as a reflective diffraction grating.
Just tries the single hair thing and it actually works!
