Can You Generate Power from a Water Source Using Gears and Equations?
  • Thread starter Thread starter Aquadust
    Energy Water
The discussion revolves around generating power from a falling water source using a waterwheel or turbine connected through gears to a power generator. Participants explore the necessary equations and considerations for efficiency in this context, focusing on potential energy, kinetic energy, and gear dynamics.
  • Homework-related
  • One participant seeks guidance on equations for generating power from a falling water source, mentioning potential energy and kinetic energy formulas.
  • Another participant corrects a formula for kinetic energy and discusses the importance of efficiency in the system, suggesting that 100% efficiency is not achievable.
  • Concerns are raised about the suitability of using a dynamo for the prototype due to its stiffness and difficulty in operation.
  • Suggestions are made to look for generators used in gas-powered portable generators, along with a recommendation to search for hydropower generators online.
  • A link is shared to a resource discussing a hydropower generator and a Pelton Wheel, which may provide further insights into the topic.
Participants express varying opinions on the choice of generator and the efficiency of the system. There is no consensus on the best generator type or the specific equations to use, indicating multiple competing views remain.
Participants have not settled on specific assumptions regarding generator types or the efficiency of different systems. The discussion includes unresolved questions about the optimal design for the gears and the generator's operational characteristics.
Individuals interested in renewable energy generation, particularly those exploring hydropower systems, mechanical engineering, or energy efficiency in power generation.
Aquadust
Hi
I am writing a research paper in which I will receive no help with and am hoping for some suggestions / guidance with the equations and formulas I will need.
I am looking at generating power from a falling water source which will be connected to a waterwheel/turbine through a set of gears such as spur or Epicyclic gearing to a power generator such as a dynamo which can generate power. Probably around 5V is the target.I am guessing I will need to use equations with regards to Potential energy and possible torque and gear equations but any help or exact equations would be brilliant and much appreciatedPossible equations could be:
Potential Energy = MxGxH
Kinetic Energy = 〖1/2 x m x v〗^2
Driven gear / Driver Gear
Any help with this would be much appreciated and if more details are needed please let me know.
Many thanks in advance
Aquadust said:
Hi
Fixing your 2nd equation --> Kinetic Energy = 1/2 x m x v^2
And you are correct, if you could run this at 100% efficiency, you could recover the loss of PE in the falling water as energy out. Your waterwheel+generator will not be 100% efficient, but you should be able to get reasonable efficiency out of the system.
You should design your gears and whatever to try to run the generator at whatever its optimum RPM is for generating power. Generators should come with some curves showing how they operate at different RPMs. Do you have some generators in mind, and do you have their datasheets?
Hi
Thanks for your reply
I didn't have a generator in mind for the basic prototype, I was thinking about using a dynamo but I realize these can be stiff and difficult to turn and probably wouldn't be suitable, Do you know where I could find these kinds of generators and there data sheets?
Many thanks for your help and advice.
I don't know offhand which generators would be the best for your appliction. Maybe whatever is used in gas-powered portable generators, but with some gearing...
I googled hydropower generators, and got some reasonable hits. Maybe these will give you some ideas:
http://www.google.com/search?source...=1T4GGLL_enUS301US302&q=generators+hydropower
  • · Replies 74 ·
11K
  • · Replies 38 ·
