Can You Solve This Physics Problem About a Cannon, a Cliff, and a Moving Ship?
  • Thread starter Thread starter Cassomophone
    Cannon
The discussion revolves around a physics problem involving projectile motion, specifically a cannon mounted on a cliff targeting a moving ship. The problem includes determining the required muzzle velocity of the cannon and how far it needs to be rolled back to adjust for the ship's movement.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to convert units for consistency, particularly from kilometers to meters. There are attempts to isolate variables and use equations of motion to find time and velocity components. Questions arise about the relationship between the horizontal and vertical components of the muzzle velocity and how to calculate them based on the given angle.
Participants are actively engaging with the problem, exploring various approaches to isolate time and velocity components. Some guidance has been offered regarding the vector nature of muzzle velocity and the need to express it in terms of its components. There is an ongoing exploration of how to apply the equations of motion effectively.
There are noted discrepancies in unit conversions and assumptions about the initial and final positions of the cannon and the ship. Participants are also questioning the implications of doubling the muzzle velocity and how that affects the calculations for part B of the problem.
Cassomophone
So here is the question my professor made up. I asked if the time was missing and once he thought about it, he said we should be able to figure it out. I need help.
A cannon is mounted on a railroad track on a cliff above the ocean. 300 m below, and standing off a 15 km, is a war ship.The cannon's elevation is fixed and designed to provide maximum range (which I know to be 45°).
a) What is the required muzzle velocity of the cannon?
b) The ship moves with it's range, (It moves to 5km from cliff), so the cannon is rolled back on the track and the projectile charge changed, doubling the cannon's muzzle velocity. How far away does the cannon need to be rolled back to target the ship?
Xf, Yf =X,Y final
Xi, Yi =X,Y initial
(Vx)i, (Vy)i= initial velocity of X, Y
(Vx)f, (Vy)f =final velosity of X,Y
g=gravity of 9.8 m/s^2
t=time
Vm=Muzzle Velocity
Equations (Eqn)
1) Xf=Xi+(Vx)i Δt
2) (Vx)f=(Vx)i= constant
3) Yf=Yi+(Vy)iΔt-(1/2)(g)(Δt)^2
4) (Vy)f=(Vy)i-gΔt
5) Vx+Vy=Vm
So first I drew out the problem, I have the cannon on top of the 300m (which equals 3km) cliff and the ship is 15 km out. Then at the muzzle of the cannon I put an angle of 45°. There will be an arch for the cannonball to hit the ship.
Part A
θ=45°
g=9.8 m/s^2
Xf=15km
Xi=0
Yf=0
Yi=3km
(Vx)f and (Vy)f=0
Δt=? (Initial time is 0)
(Vx)i or (Vf)i=?
So I need either the initial velocity of X or Y to solve for Δt, or I really need a Δt. I have no idea how for find the Δt with what I know. Since the arch of the cannonball is not a perfect triangle can I use Ax=Acosθ and Ay=Asinθ? If I can get help on the time then I know I can probably solve A.
Once I have the time I would:
-solve for (Vx)i using eqn. 1.
-Solve for (Vy)i using eqn. 4.
-Then I would add them both to get the muzzle velocity of the cannon
For B
So the muzzle velocity from part A would be doubled
The ship would be 5km from the cliff at this point.
So now I need to find the Xi, so how should I do that exactly?
Thank you so much, I tried to be as detailed as possible and that is all the information that was given for the question.
Without actually doing anything, 300 m is not 3 km. 3000 m = 3 km; so that would be an error right off the bat. Make sure you've converted all units appropriately (for example - I would make everything in m instead of km since acceleration due to gravity is often given in m/s etc.). I'll take a look at this in more detail and get back to you with more feedback.
Ah true, I didn't mean 3 km, I meant to type .3km. But you are right I should convert the km into meters so, 15km=15,000m and 5km is 5,000 m.
Thank you so much for looking at this.
Moreover, the muzzle velocity is a vector Vxi+Vyj. You need the muzzle speed, the magnitude of the velocity, which is Vm=√(Vx2+Vy2). Knowing the angle of the muzzle velocity, you can express Vx and Vy with Vm.
Eliminate the time: You can isolate Δt from eq 1) and then substitute into equation 3).
ehild
ehild
So I isolate the time from eq 1, but I still don't know the initial velocity of x, so how do I do that?
What are the components of the initial velocity (the nuzzle velocity) related to the magnitude and angle? You know the angle the ball is shoot. Unknown is the magnitude, but you know the initial and final positions, so you can determine it. ehild
Ok... I get that I can, but how do I do that then?
Ok so look at this real quick.
Since the equation is at 45 ° doesn't (Vx)i = (Vy)i? So if that is true...
then equation 1 gives:
15000m=(Vx)i Δt
equation 3 gives:
0=300+(Vy)iΔt-(1/2)(g)(Δt)^2
but since (Vx)i = (Vy)i then (Vy)iΔt = (Vx)i Δt = 15 so:
0=300+15000-(1/2)(g)(Δt)^2
so
15300=(1/2)(g)(Δt)^2
so
Δt=sqrt(30600/g)
giving:
(Vx)i =15000/sqrt(30600/g) = about 268m/sec
So the muzzle velocity would be 536 m/s right?
Now I am not sure where to go on part B. All i know is the muzzle velocity is doubled so that should be 2(536)= 1072 m/s
Now θ=45°
g=9.8 m/s^2
Xf=x+5
Xi=0
Yf=0
Yi=3km or is this 0 now since it's further back from the cliff?
(Vx)f and (Vy)f=0
(Vx)i and (Vf)i=536 m/s
Vm= 1072 m/s
So using
Xf=X_o + Vx_o (Change of T)
0=X+5 +536m/s (Change of T)
And now I just confused myself, am I on the right track?
ehild
Could I do this instead?
15000m=(Vx)i Δt
equation 3 gives:
so
so
Δt=sqrt(30600/g)
giving:
Now θ=45°
g=9.8 m/s^2
Xf=x+5
Xi=0
Yf=0
(Vx)f and (Vy)f=0
Vm= 1072 m/s
So using
15000m=(Vx)i Δt
equation 3 gives:
so
so
Δt=sqrt(30600/g)
giving:
Vxi=268 m/s, that is right. But the muzzle velocity is not Vxi+Vyi. Vxi and Vyi are the horizontal and vertical components of the velocity, a vector. Its magnitude is Vm=√(Vxi2+Vyi2).
Cassomophone said:
Now I am not sure where to go on part B. All i know is the muzzle velocity is doubled so that should be [STRIKE]2(536)= 1072 m/s [/STRIKE]
If the muzzle velocity is doubled, both the horizontal and vertical components are doubled, both become 536 m/s.
Cassomophone said:
Now θ=45°
g=9.8 m/s^2
Xf=x+5
Xf=x+5000(meter)
Cassomophone said:
Xi=0
Yf=0
Yi=300 m. The canon is still on the cliff, it has changed its horizontal position only.
Cassomophone said:
[STRIKE](Vx)f and (Vy)f=0[/STRIKE]
[STRIKE]Vm= 1072 m/s[/STRIKE]
The cannon ball has to cover x+5000 horizontal distance with the horizontal velocity 536 m/s. That takes time t. 536t=x+5000. Isolate t and substitute it into the equation for y.
ehild
  • · Replies 19 ·
10K
