Can you work out power without knowing displacement?
The discussion focuses on calculating the power output of a cyclist riding a bike up an inclined plane at a constant speed, despite the absence of displacement data. Key equations include power as P = F ∙ v, where F is the applied force and v is the velocity. The net force is zero due to equilibrium, but the cyclist's applied force must counteract friction and gravitational components. It is essential to convert speed from km/h to m/s for accurate power calculations in watts.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of force, work, and power
  • Knowledge of inclined plane mechanics
  • Ability to convert units, specifically from km/h to m/s
  • Study the principles of static equilibrium in physics
  • Learn about the calculation of gravitational potential energy
  • Explore the concept of friction and its impact on motion
  • Practice problems involving power calculations in various contexts
Students studying physics, particularly those focusing on mechanics and energy, as well as educators looking for examples of power calculations in real-world scenarios.
jjones1573
I'm a bit confused by a question asking me to work out the power of a bike traveling up an inclined plane with a constant speed. I have the mass and friction and the speed but no displacement so I don't know how I could work out power if to find the work I need to factor in displacement to the equation. Any ideas?
Power is W/t, and work is F.d, thus P = F.(d/t).
Power can be found in terms of force and velocity; iff both are constant: P = Fv
Ah ok great!
So If the bike is moving up at a constant speed with a friction force of 320N, to calculate the net force do I simply do mg Sin theta - 700?
Also when working interms of km/h do we need to convert to m/s to do the calculations?
The speed is constant, so you know that the net force is zero. Therefore, whatever force is being applied by the cyclist is being countered by friction and by the component of the weight parallel to the incline. In other words, the sum of all forces acting parallel to the incline is 0. You can use this force balance equation to solve for what the cyclist's applied force has to be.
Draw a free body diagram for the bike if you're having trouble keeping track of the forces.
Yes, you have to convert to m/s IF you want your answer to be in watts (N*m / s). If you don't, then your answer will be in (N*km/h), which is still a unit of power, but is not the standard one (the watt).
Ah ok thank you. so if the sum of all the forces parallel equals zero then perpundicular forces also cancel each other out then the net force is 0? I am still a little confused.
Yes exactly. Let's just use tilted coordinate axes so that parallel to the incline is the x direction and perpendicular is the y direction. Then the condition for equilibrium gives you two equations 1. Sum of all forces in x-direction = 0
2. Sum of all forces in y direction = 0.
These two equations allow you to solve for your unknowns (friction, normal force) in terms of your knowns (mass, g, friction coefficient).
Think about the definition of velocity. What is in the numerator?
v = d/t
ahh I see what your saying that's why P = F.(d/t) or P = F.V because V = d/t of course!
But I'm still confused about the force calculation. if the net force is 0 then the power from the above equation p = 0 * velocity = 0
but that can't be right?
jjones1573 said:
v = d/t
It's true that there is no net work being done, and hence no net power output. Any power generated by the cyclist is 1. dissipated as heat due to friction OR 2. used up to increase the gravitational potential energy of the bike as it goes up the incline.
But the question is not asking you to compute the net power output. It is asking you to compute the power output of the cyclist. So don't use the net force in P = F*v. Use the applied force of the cyclist.
That's why you have to go through this whole rigamarole of applying the condition for static equilibrium and force balance -- to determine what force the cyclist has to apply to keep the bike moving.
Ah ok thank you for taking the time to explain this that makes complete sense now!
  • · Replies 56 ·
