Can't Figure out what I am doing wrong F=MA (easy problem)
  • Thread starter Thread starter lanzjohn
    F=ma Figure
The discussion revolves around calculating the maximum force a motor must exert on an elevator with a mass of 1020 kg and a maximum acceleration of 0.062 g. The initial calculation incorrectly omitted the gravitational force acting on the elevator. The correct approach involves using the formula F = mg + ma, where both the force due to gravity and the force due to acceleration must be considered. Participants emphasize the importance of understanding the dynamics concepts, particularly the interplay between gravitational force and motor force. Clarifying these concepts is essential for solving similar physics problems accurately.
lanzjohn
An elevator (mass 1020kg) is to be designed so that the maximum acceleration is 0.062 g. What is the maximum force the motor should exert on the supporting cable?
F=MA
(.062)(9.8 m/s^2) = .6076 m/s^2
F = (1020)(.6076)
F = 619.752 N
Why is that wrong?! Unless g means something else I don't understand what's up?
Thanks for your time.
The elevator accelerates upward. What force(s) act on it? Is it only the force of the motor?
ehild
You've missed out the force on the elevator due to gravity.
F=mg+ma
gives the required force 'F' that the motor must exert to accelerate upwards at acceleration 'a'
Well there is the force of gravity. But isn't that already incorporated into the acceleration of the motor?
I guess there is the Force of tension as well...
Ohh I gotcha. I guess I assumed the tension of the rope canceled out the force of gravity... So it just left the acceleration or Force rather due to the motor. We are just starting to learn dynamics so I am a little shaky on some concepts... Got to love summer classes- they move so damn fast.
Sorry, I realize I just gave an answer without helping lanzjohn to figure it out on his own.
But I think he just forgot, since I did that a lot when I was first doing these types of questions.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
