Can't read parameters from file
  • Thread starter Thread starter madtraveller
    File Parameters
madtraveller
I'm trying to read parameters from a text file (format below) but actually my function didn't receive any parameters from read file function.
Number_of_points 80
Distance 10.0
Time_step 0.05
Velocity 5.0
Diff_coeff 50.0
Code:
#include <iostream>
#include <fstream>
#include <cmath>
#include <iomanip>
#include <cstdlib>
#include <string>
using namespace std;
class transfer {
    private:
        int n;
        double dx, dt, u, D;
        double* trans;
    public:
        transfer();
        bool get_parameter_from_file();
        void recalculate();
        bool write_value_to_file();
transfer::transfer() {
    n = 0;
    dx = 0;
    dt = 0;
    u = 0;
    D = 0;
bool transfer::get_parameter_from_file() {
	ifstream inputFile;
	inputFile.open ("parameter.txt");
    if ( !inputFile ) {   // check if file couldn't be opened
        cerr << "Error: file could not be opened" << endl;
        return false;
    string dummy_string;
    inputFile >> dummy_string >> n;
    cout << dummy_string << " " << n << endl;
    inputFile >> dummy_string >> dx;
    cout << dummy_string << " " << dx << endl;
    inputFile >> dummy_string >> dt;
    inputFile >> dummy_string >> D;
    inputFile >> dummy_string >> u;
    cout << dummy_string << " " << u << endl;
    inputFile.close();
    return true;
void transfer::recalculate() {
    delete[] trans;
    trans = new double[ n ];
    const double   PI = 3.14159;
    double c;
    double t;
    c = 5.0/3.0 * u;
    trans[0] = 0.0;
    for (int i=1; i < n; ++i) {
        double diffuse;
        t = dt * i;
        trans[i] = dx / ( 2.0 * sqrt( PI * D * pow(t , 3)));
        diffuse = dx - c * t;
        diffuse = exp ( - pow (diffuse, 2) / ( 4.0 * D * t ));
        trans[i] = trans[i] * diffuse;
        cout << setw(3) << t << setw(18) << trans[i] << endl;
bool transfer::write_value_to_file() {
    // Creat a file to store the result
    ofstream outdata;
    outdata.open ("0.result.txt", ios::out);
    if ( !outdata ) {   // check if file couldn't be opened
        return false;
     // Write result to file
    outdata << "Time" << setw (21) << "Transfer function" << endl;
    for (int i = 0; i < n; ++i) {
        outdata << setw(3) << i << setw(18) << trans[i] << endl;
    outdata.close();
    return true;
// Main program
int main ()
    transfer transferfunction;
    transferfunction.recalculate();
    transferfunction.write_value_to_file();
    // Terminate program
    return 0;
If I did it like this and my program worked fine
Code:
#include <iostream>
#include <fstream>
#include <cmath>
#include <iomanip>
#include <cstdlib>
#include <string>
class transfer {
    private:
        int n;
        double* trans;
    public:
        transfer();
        bool set_n_value(const int &new_n);
        int get_n_value();
        void set_dx_value(double new_dx);
        double get_dx_value();
        void set_dt_value(double new_dt);
        double get_dt_value();
        void set_u_value(double new_u);
        double get_u_value();
        void set_D_value(double new_D);
        double get_D_value();
        void recalculate();
    n = 0;
    dx = 0;
    dt = 0;
    u = 0;
    D = 0;
bool transfer::set_n_value(const int &new_n) {
    if ( n < 0 ) {
        cerr << "Error: non-physical meaning parameter" << endl;
        return false;
    n = new_n;
    return true;
int transfer::get_n_value() {
    return n;
void transfer::set_dx_value(double new_dx) {
    dx = new_dx;
double transfer::get_dx_value() {
    return dx;
void transfer::set_dt_value(double new_dt) {
    dt = new_dt;
double transfer::get_dt_value() {
    return dt;
void transfer::set_u_value(double new_u) {
    u = new_u;
double transfer::get_u_value() {
    return u;
void transfer::set_D_value(double new_D) {
    D = new_D;
double transfer::get_D_value() {
    return D;
    delete[] trans;
    double c;
    double t;
    c = 5.0/3.0 * u;
    trans[0] = 0.0;
        double diffuse;
        t = dt * i;
    ofstream outdata;
        return false;
    outdata.close();
    return true;
// Main program
int main ()
    transferfunction.set_n_value(80);
    transferfunction.get_n_value();
    transferfunction.set_dx_value(10.0);
    transferfunction.get_dx_value();
    transferfunction.set_dt_value(0.05);
    transferfunction.get_dt_value();
    transferfunction.set_u_value(5.0);
    transferfunction.get_u_value();
    transferfunction.set_D_value(50.0);
    transferfunction.get_D_value();
    return 0;
Btw, Could anybody explain to me how to read this type of text file (e.g handle space between words, separate year, month and date...). I tried to use stringstream but I don't know how to handle strings with different length. Example file is below
Number of point Ndata
Number of place Nplace
timestep dt
Date Hour Place 1 Place 2 ...
2010-01-01 1 a1 a2
2010-01-01 24 a24 a24
And actually, I'd like to call a read and write function using non-fixed file name.
Code:
 void transfer::get_parameter_from_file(string &filename)
But I don't know the syntax for open file as well as call it in main function
Code:
ifstream inputFile;
inputFile.open (filename);
Plz help me with this. Thank you
Kind regards,
MT
Number_of_points 80
Distance 10.0
Time_step 0.05
Velocity 5.0
Diff_coeff 50.0
I'm confused by your descriptions of the format of data in the input file. The things you list above don't seem to what you describe below. For example, above you have distance, velocity, and Diff_coeff (whatever that is), but below you have Ndata, Nplace, Date, Hour, Place 1, Place 2, etc.
What exactly is the format of data in the file? It would also be helpful to show a few of the lines of data as they appear in the file.
Also, your code is hard to follow, with so many single-letter variable names.
timestep dt
2010-01-01 1 a1 a2
Hi Mark44,
Thank you very much for your reply
Actually, as I wrote at the end of my post, I don't know how to read text file with space in between together with number as well as how to extract year, month and hour from that kind of format. So first, I created a text file with "_" connected word so that I can use one "dummystring" to read it. And hope that anyone can show me how to read a real input file afterward. My problem is that after read_parameter_from_file() executed, my recalculate() function still didn't receive any values from n, dx, dt, u and D
My first data file (with legend)
Number_of_points 80 // n
Distance 10.0 // dx
Time_step 0.05 // dt
Velocity 5.0 // u
Diff_coeff 50.0 // D
Here is the real input file
Number of data points 25
Number of places 6
Timestep 1
Date Hour Place1 Place2 Place3 Place4 Place5 Place6
1990-01-01 1 25.002 NA NA 16.265 6.231 9.680
1990-01-01 2 24.449 NA NA 16.265 6.231 9.551
1990-01-01 3 24.449 NA NA 16.265 6.231 9.551
1990-01-01 4 24.550 NA NA 16.265 6.231 9.551
1990-01-01 5 24.851 NA NA 16.265 6.130 9.551
1990-01-01 6 25.002 NA NA 16.099 6.130 9.421
1990-01-01 7 25.306 NA NA 15.933 6.130 9.421
1990-01-01 8 25.357 NA NA 15.933 6.130 9.421
1990-01-01 9 25.357 NA NA 15.933 6.029 9.389
1990-01-01 10 25.306 NA NA 15.769 6.029 9.260
1990-01-01 11 25.306 NA NA 15.769 6.029 9.260
1990-01-01 12 25.103 NA NA 15.605 6.029 9.132
1990-01-01 13 24.952 NA NA 15.605 6.029 9.132
1990-01-01 14 24.901 NA NA 15.605 5.905 9.132
1990-01-01 15 24.851 NA NA 15.442 6.004 9.132
1990-01-01 16 24.801 NA NA 15.442 5.905 9.003
1990-01-01 17 24.700 NA NA 15.442 5.905 9.003
1990-01-01 18 24.550 NA NA 15.442 5.905 9.003
1990-01-01 19 24.350 NA NA 15.442 5.905 9.003
1990-01-01 20 24.150 NA NA 15.279 5.905 9.003
1990-01-01 21 23.952 NA NA 15.239 5.806 8.875
1990-01-01 22 23.803 NA NA 15.078 5.806 8.875
1990-01-01 23 23.704 NA NA 14.758 5.806 8.875
1990-01-01 24 23.557 NA NA 14.758 5.806 8.875
1990-01-02 1 23.458 NA NA 14.758 5.684 8.875
The mathematical description of my function you can find in this post
https://www.physicsforums.com/showthread.php?t=430651
Thank you for your time
MT
Thank you, Mark44
Could you also show me the syntax to call a read and write function using anonymous file names.
E.g: in class
Code:
but the following code resulted in syntax errors
Code:
 ifstream inputFile;
Code:
int main ()
    transferfunction.get_parameter_from_file(filename);
    return 0;
It would be helpful to know what the errors are. If they are syntax errors, the compiler reports them and gives the line number at which they occur. Also, you don't show enough of your code for me to say for sure, but it looks like you are trying to pass variables that are undeclared or undefined.
In main, unless filename has been defined at global scope, the compiler won't know what to do with it.
Please include the compiler error messages. If there are a whole lot of them, just include the first five or so. Also, please include the current version of your code.
I found the correct syntax:
In my class, I should have
Code:
bool get_parameter_from_file(const string &filename);
In function outside class, the code should be
Code:
bool transfer::get_parameter_from_file(const string &filename)
    ifstream inputFile(filename.c_str());
Then in main function
Code:
int main ()
   transfer calling;
   calling.get_parameter_from_file(string("whatever_file_name_is.txt"));
MT
