Cantilevered and line-loaded steel beam
The discussion revolves around the analysis of a cantilevered steel beam subjected to various loads, including a distributed load and point loads. Participants are attempting to determine internal forces, bending moments, and cross-sectional areas relevant to the beam's structural integrity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants are discussing the calculation of internal forces and bending moments, with some attempting to clarify the definitions and formulas used. Questions about the interpretation of loads, the meaning of "internal force," and the application of specific formulas are prevalent. There are also requests for clearer diagrams and explanations of the steps taken so far.
The discussion is ongoing, with various participants providing insights and asking for clarification on specific terms and calculations. Some guidance has been offered regarding the interpretation of loads and the need for a general formula before determining maximum and minimum moments. However, there is no explicit consensus on the correct approach or formulas to use.
Participants are working under the constraints of homework guidelines, which may limit the amount of direct assistance they can receive. There are indications of confusion regarding the definitions of terms and the application of formulas, which may hinder progress.
Kalle
Cantilevered and line-loaded, steel cross section. IPE profile. Dimension the steel cross section and control stresses. Material properties. Fm 355N/mm2, fv = 204n/mm2, E = 210 000 N/mm2 Cross section not known. Length of beam 5 m, point load across beam 12kNm, point load 25 kn. Beam left to right 4, 5 m, right to left 0,5 m is point loaded
I found the internal force Vxy 25 +6 =31kn. , bending moment Mmin -qb2/2 , M min- 14 kNm. delta =M/W I can't find Mmax and tau= V/As. So I need help to find Mmax and As wall area, how to find.
Vxy 25 +6 =31kn, tau = V/As
Welcome, Kalle!
Could you show us a diagram of the beam and loads distribution?
That's very hard to read, and mostly blank space. Please post a better shot.
Lnewqban said:
Welcome, Kalle!
It would help if you were to explain exactly what you have done so far (all the steps).
E.g., I do not know how you are defining "internal force" or how you found Mmin.
What is the support force at B?
What is the bending moment at a point x to the right of B?
What is the bending moment at a point x to the left of B?
1.first I found the effect of the linear load on the total length of the beam q=0, 5 x 12 `= 6kNm
2.Total vertical force Vxy =25 +6=31kN.
3.I find Mz = ´- q(b)2/2 Mz `=12x 0,5 squared =1, 5kNm linear load, Mz point load -12,5kNm .Mz min total -1,5- 12,5 =-14kNm. Mz max don't know
4.I found the tension delta =M/W max is missing, then can't count. And can't find a suitable cross section for IPE.
4.I found tau =V/As , As can't find.
5x12=6?
I think you are misinterpreting " load across beam 12kNm".
The units kNm make no sense, so I read this as a distributed load of 12kN/m, for a total 5m x 12kN/m = 60kN.
Kalle said:
3.I find Mz =
What axis are you taking moments about?
This is very hard to parse. I can't tell where one mathematical statement ends and the next one starts. Use separate lines.
What is "q(b)2/2"?
How can you find a minimum without first finding the general formula?
Please try to answer my questions in post #6.
5x12=6?
Yes, the load over the beam is 5 x 12 =60 kN, and the point load on the right 25kN . The total vertical force is 85 kN. I need to find Vxy ?
vertical axis of the cantilever beam
Mzmin= − q(b) squared divided by 2.
M z min is the minimum bending moment,
q is the magnitude of the distributed load (linear load),
b is the beam height.
How can you find a minimum without first finding the general formula? Mzmin= − q(b) squared divided by 2.
Kalle said:
need to find Vxy ?
You have not defined it. What is it?
You referred to it as "internal force", but I don’t know what that means either.
What is "b"? Shouldn’t P be involved?
I say again, please try to answer my questions in post #6.
E.g., I do not know how you are defining "internal force" - Vxy is the internal force, denoted V. how you found Mmin. ------- the moment of compression Mmin was found by the formula - q(linear load) multiplied by b(beam length) squared and divided by 2. What is the bending moment at a point x to the right of B? - 12,5 kNm What is the bending moment at a point x to the left of B? 37,5 kNm
Telling me the internal force is the internal force gets me nowhere. What is meant here by "internal force"?
I would think that formula only applies in particular circumstances, e.g. for the case of a uniform load between two supports, and nothing else. That does not apply here.
You have not understood my questions.
If you consider a point of the beam at a position x to the right of B, what is the sum of moments about that point due to forces to the right of it? It will be a formula involving x, and it will contain a term due to the point load P as well as a term from that portion of the distributed load to the right of x.
What is meant here by "internal force"? -In mechanics, internal forces are often analyzed in structures like bridges or buildings, where the forces between different parts of the structure determine its stability and behavior.
lI would think that formula only applies in particular circumstances, e.g. for the case of a uniform load between two supports, and nothing else. That does not apply here.
Please suggest which formula I should use then.
Please give instructions on how and what to find.
Sure, but you referred to "the" internal force. Which one? And internal to what system?
You named it Vxy. Why that name? What do x and y refer to here?
Seems you do not know how to answer my questions, so I'll help you.
It will be clearer if I avoid numbers, so I'll call the point where P is applied C, and use ##\rho## for the force density of the distributed load
Consider a point D at distance x to the right of point B.
The point load at C exerts a torque ##-P(BC-x)## about D.
An element of the distributed load between ##y## and ##y+dy## to the right of x has weight ##\rho dy## and exerts a torque ##-y\rho dy## about D.
The distributed load over BC therefore exerts a torque ##\int_0^{BC-x}\rho y.dy=-\frac 12(BC-x)^2\rho## about D.
The total torque from forces to the right of x is therefore ##-P(BC-x)-\frac 12(BC-x)^2\rho##.
To find the minimum or maximum within BC, differentiate wrt x, etc.
Now, can you do the same for a point distance x to the left of B? It is a bit more complicated because you have to include the normal force from the support at B.
I'm trying to solve it step by step and figure it out.
I attach a table of the formulae that are required to solve.
Something is still wrong
That table is a dreadful way to solve such problems. Far better to understand the principles. But that does require some basic calculus.
Do you understand how I did it post #14?
I tried to understand, but since I have to keep track of the formulas, it gets confusing.
We would only be required to work with the formulas.
Since the formulas cannot cover every case specifically, you need some rules on how to combine the formulas in any given case.
Can you see two examples in the table which, in some sense, should add up to the case in this thread?
yes, with the help of these ready-made helpers I will try to solve it.
ok, but I really do not see how those cases can tell you what the minimum and maximum torque are.
11K
12K
15K
